Shifter Alignment, Were can I find a picture of 3rd gear under the tranny? |
eyecolor |
Jul 4 2021, 01:26 PM
Eyecolor Group: Members Posts: 80 Joined: 15-August 08 From: Wilmington,DE Member No.: 9,425 Region Association: None |
I have a 1975 914 that recently cannot get into 3 rd gear. Reverse , 1st and second are fine.
I am trying to align the shift coupler but cannot seem to still get to 3rd. It would help if I could somehow know I was in 3rd and work backwards. I have searched this site and many others for a photo of the different displacements that are apparent looking under the trans as we enter the different gears.. My bushings are fine . Any advice quite welcome. I have been a learner and lurker for over 10 years. Thanks in advance George O. |
michael7810 |
Jul 4 2021, 02:46 PM
Senior Member Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
So looking at the rod that connects to the shift rod on 1 end and the other end goes into the tranny, inside the black, oval dust boot on the transmission. When in neutral, the rod will easily slide up and down (into and out of the transmission). Place the rod half way in and rotate it forward and that will be 3rd gear. I hope that makes sense.
iankarr |
Jul 4 2021, 09:02 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,526 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
There are three “planes” the shifter fork passes through, with fore and aft gear engagements in each plane. The plane closest to the trans is 1/R, the middle plane is 2/3 and the plane furthest away from the case is 4/5….with the first number in each pairing pointing rearward. Think of the shift rod/fork working in opposition to the shifter itself. |
jim_hoyland |
Jul 5 2021, 08:30 AM
Get that VIN ? Group: Members Posts: 9,559 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
To visualize the gears and there planes, I would like to see a video made while a car in on a lift and the console cover off.
PanelBilly |
Jul 5 2021, 09:12 AM
914 Guru Group: Members Posts: 5,864 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
We’ll you’re in luck. I have mine pulled apart to install Chris’ linkage mod and will make a video this morning. I’m just starting to adjust everything
jim_hoyland |
Jul 5 2021, 10:24 AM
We’ll you’re in luck. I have mine pulled apart to install Chris’ linkage mod and will make a video this morning. I’m just starting to adjust everything Thanks! (IMG:style_emoticons/default/smile.gif) Great,I am a visual learner, despite setting my shifter many times and reading many threads; I still can't see how the arm in the console moves between gears. |
maf914 |
Jul 5 2021, 11:02 AM
We’ll you’re in luck. I have mine pulled apart to install Chris’ linkage mod and will make a video this morning. I’m just starting to adjust everything PanelBilly, That's great. I hope you post plenty of photos of your installation. I do like the Tangerine linkage concept. |
eyecolor |
Jul 5 2021, 11:49 AM
We’ll you’re in luck. I have mine pulled apart to install Chris’ linkage mod and will make a video this morning. I’m just starting to adjust everything PanelBilly, That's great. I hope you post plenty of photos of your installation. I do like the Tangerine linkage concept. You all are amazing! I can move forward(pun intended) Thank you! George Wilmington,DE |
eyecolor |
Jul 5 2021, 11:51 AM
(IMG:style_emoticons/default/agree.gif) There are three “planes” the shifter fork passes through, with fore and aft gear engagements in each plane. The plane closest to the trans is 1/R, the middle plane is 2/3 and the plane furthest away from the case is 4/5….with the first number in each pairing pointing rearward. Think of the shift rod/fork working in opposition to the shifter itself. Thanks Ian The check is in the mail. George |
eyecolor |
Jul 5 2021, 11:52 AM
So looking at the rod that connects to the shift rod on 1 end and the other end goes into the tranny, inside the black, oval dust boot on the transmission. When in neutral, the rod will easily slide up and down (into and out of the transmission). Place the rod half way in and rotate it forward and that will be 3rd gear. I hope that makes sense. It certainly does! Thanks! |
PanelBilly |
Jul 5 2021, 07:10 PM
Here's the segment that shows how the linkage works. I need to edit together all the short videos I did of the install before I'm ready to share that part. I'll post it as a stand alone thread when its ready. Just drove the car and its fantastic. Money well spent!
Sorry I didn't embed it properly https://www.youtube.com/watch?v=m-vjTcmaop4 |
Dr Evil |
Jul 8 2021, 10:36 AM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Click the link for the notes in my signature. I have a method I use with some simple graphics to explain.
Dr Evil |
Jul 8 2021, 10:38 AM
Double post. Oopse.
gereed75 |
Jul 8 2021, 02:25 PM
Senior Member Group: Members Posts: 1,315 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
As posted before, I am a big proponent of this set up from Tangerine and this video demonstrates exactly why.
By constraining the movement o f the shifter rod in the console, this double bearing setup translates the typical wig wag shifter rod movement into exactly the rotation and direct fore aft movement that the trans shifter arm needs to efficiently select gears Billy, you gonna like it! |
jim_hoyland |
Jul 8 2021, 02:41 PM
As posted before, I am a big proponent of this set up from Tangerine and this video demonstrates exactly why. By constraining the movement o f the shifter rod in the console, this double bearing setup translates the typical wig wag shifter rod movement into exactly the rotation and direct fore aft movement that the trans shifter arm needs to efficiently select gears Billy, you gonna like it! We’ll said ! I had the Tangerine kit installed too and shifting is 100% better; make sure the firewall bushing is good. Or better, install the Tangerine bushing |
euro911 |
Jul 8 2021, 03:29 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Here's the segment that shows how the linkage works. I need to edit together all the short videos I did of the install before I'm ready to share that part. I'll post it as a stand alone thread when its ready. Just drove the car and its fantastic. Money well spent! Sorry I didn't embed it properly https://www.youtube.com/watch?v=m-vjTcmaop4 https://www.youtube.com/watch?v=/m-vjTcmaop4 |
Dr Evil |
Jul 9 2021, 01:41 PM
I really like the example above of the external modifications, but I will keep saying that internally there is slop that will always make this not precise. I modify the internal bits to remove slop see video 1 stock amount of slop, which you can also see when gears are selected in Marks video above with the kit installed.
https://www.youtube.com/watch?v=vb2lBHNAVk0 |
Dr Evil |
Jul 9 2021, 01:43 PM
And same set up with my mods.
https://www.youtube.com/watch?v=P2SmpwTKYvY |
eyecolor |
Jul 10 2021, 09:26 AM
Here's the segment that shows how the linkage works. I need to edit together all the short videos I did of the install before I'm ready to share that part. I'll post it as a stand alone thread when its ready. Just drove the car and its fantastic. Money well spent! Sorry I didn't embed it properly https://www.youtube.com/watch?v=m-vjTcmaop4 That is really a "KEEPER" Thanks so much George |
Lo-Fi Version | Time is now: 26th December 2024 - 05:20 PM |
