2 Pages V < 1 2
> Questions about wiring harness for 1974
914Sixer
post Jul 11 2021, 06:20 AM
Post #21
Took me a minute because the harness is missing plug but it a a heated back window harness.
GeorgeKopf
post Jul 11 2021, 09:27 AM
Post #22
Thank you Ian!
I'm having a bit of trouble reading the wiring diagram.
The wiring diagram has:
the door switches as brown/white (both wires to both switches?)
If both wires go to both switches, in parallel, won't both doors have to be open to break the circuit?
the parking brake as brown/yellow
the interior light as black/red
Do the door switches ground through the chassis?
Does the parking brake switch ground through the chassis?
Thanks.
George
GeorgeKopf
post Jul 11 2021, 09:30 AM
Post #23
Thank you Mark.
I'm fairly sure that my rear window doesn't have any wires hanging off of it. (It is wrapped up and in storage right now.)
I also don't have a switch to turn it on. I'm guessing that I don't need to install that harness.
Thanks.
George
iankarr
post Jul 11 2021, 04:43 PM
Post #24
@GeorgeKopf the wiring on my 73 harness doesn't follow that color scheme. Or the colors have faded. With regard to the door switches, I'm not sure exactly how the circuit works, but I know there are 4 connections on each switch. Looks like your diagram only has two, so it may not be for a 73. Recommend picking up a diagram from prosperos garage - http://www.colorwiringdiagrams.com. They seem easier to read. At least for me!
ejm
post Jul 12 2021, 08:52 AM
Post #25
I can see the light at the end of the tunnel
When a door is open the switch closes completing the circuit to ground
From '74 on they ground thru the switch body
Correct, thru the '73 model year the switch had 4 contacts and grounded thru a wire.
Yes on all years
@GeorgeKopf @iankarr
GeorgeKopf
post Jul 12 2021, 10:58 AM
Post #26
Thank you Ed.
It occurs to me that using just the two pole switches should work just fine. Grounding through the chassis or the brown wires should be identical.
Thanks.
George
GeorgeKopf
post Jul 13 2021, 01:05 PM
Post #27
I've traversed the entire harness and am now deep into the dash components. It looks like at some time the wire from the light switch to the parking light indicator completely melted. The sheathing is stuck to multiple wires and there are brown marks everywhere.
Any idea what could have caused that melt down? I'm wondering if the wire rubbed through the light holder and grounded to the gauge. If so, I'm thinking of replacing all of the little bulb holders with ones that have an attached male flat connector. (Instead of the kind where the wire goes through the end of the bulb holder.)
Editors note: I was reading the 1973 fuse box wiring diagram and found this gem.
"High Beam indicator (Tach) and parking light indicator (Speedo) are unfused…"
So that explains that. (IMG:style_emoticons/default/idea.gif)
Thanks.
George
914werke
post Jul 13 2021, 04:20 PM
Post #28
QUOTE(GeorgeKopf @ Jul 10 2021, 10:56 PM) *
What is this harness for? It was in the box of electrical parts. I have no idea what year it is from.
George
That is the accessory harness to control the optional defrost R. glass. Its missing the relay board connector (hard to find) (IMG:style_emoticons/default/smile.gif)
It normally threads through the snorkle at the firewall, yours has been removed.
GeorgeKopf
post Jul 13 2021, 10:50 PM
Post #29
Thanks Rich.
Now I'm working through the gauges and I think I've got it figured out.
My combo gauge looks like this:
Gauge wiring for 1973 Porsche 914.
Here are some pictures of the tangled mess of wires. I left off the gauge illumination (blue/black) because it was cluttering the pictures.
Combo GaugeAttached ImageAttached Image
TachometerAttached Image
SpeedometerAttached Image
Please let me know if I've got this wrong!!! If so, I'll update the drawing for posterities sake.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 27th December 2024 - 12:15 PM
