M/C size for Volvo calipers, Is the 19mm m/c large enough for Volvo calipers. |
willieg |
Jul 8 2021, 11:09 PM
Member Group: Members Posts: 138 Joined: 13-August 18 From: Pleasant Hill Member No.: 22,389 Region Association: Northern California |
I have a 1974 914 and with a couple of spare struts have started to put on calipers from a 1982 Volvo 240. It is certainly not a bolt on and if successful, I will do a write-up on 914World. I currently have a 19 mm m/c. My question for those who have done this conversion or those who know more about brakes than me (a large portion of the planet), is the 19 mm m/c large enough to push the fluid in these Volvo calipers? Or how can I tell if the 19 mm m/c is large enough?
914Sixer |
Jul 9 2021, 06:09 AM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
How many pistons per caliper and what is the diameter of pistons ? That will determine the amount of volume you are going to need.
infraredcalvin |
Jul 9 2021, 07:52 AM
Distracted Member Group: Members Posts: 1,575 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
This will help you a little bit, do the math to find the correct size …
https://www.pelicanparts.com/techarticles/9...brake_calc2.htm |
Lo-Fi Version | Time is now: 26th December 2024 - 02:09 PM |
