> MPS Case Leaks...., Ideas on how to seal?
tvdinnerbythepool
post Jul 10 2021, 01:10 PM
Hey all,
I rebuilt my MPS last year with the tangerine kit. I fought getting the case to stop leaking after the rebuild as I've seen a few others have this issue too.
I used grease on the gasket which seemed to do the trick...that lasted about a year and now yet again I have the case leak.
Anyone figure out a permeant solution to this? I am wondering if I can RTV or something to seal the bastard shut. In theory it won't need to be disassembled for a long time.
Let me know what you guys think!
-R
p.s. I've checked the vacuum and hoses to make sure they aren't the culprit. I also checked a used MPS I bought on ebay with the same vacuum setup and it holds steady at 15". Definitely the case 1/2 seal.
914_teener
post Jul 10 2021, 01:29 PM
Are you running a properly working Decell Valve with your D-jet setup?
tvdinnerbythepool
post Jul 10 2021, 01:49 PM
QUOTE(914_teener @ Jul 10 2021, 12:29 PM) *
It's a 1970 which I believe did not come with one.
tvdinnerbythepool
post Jul 11 2021, 09:38 AM
JeffBowlsby
post Jul 11 2021, 02:03 PM
914 Wiring Harnesses
They can leak at several locations:
At the diaphragm perimeter gasket
At both center diaphragm screws
At the diaphragm to center fixture perimeter
At the case halves
At the electrical plug perimeter and contacts
At the rear check valve
At the hose to case connection
If you try to fix all these and the leak persists them it’s a defective core.
- Lo-Fi Version Time is now: 26th December 2024 - 05:58 PM
