Need input from the brain trust,, I'm having no luck finding...... |
Jamie |
Jul 10 2021, 05:19 PM
Senior Member Group: Members Posts: 1,074 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
.....15mm wheel spacers for the front of my 73 teener. I want to eliminate a slight rub inside the wheel well from my 205x65 15" tires, have plenty of outboard room to widen the track up front. Only ones I have found were not hubcentric and created significant shimmy at speed. Do y'all have any trusted sources to recommend?
Front yard mechanic |
Jul 10 2021, 05:42 PM
Senior Member Group: Members Posts: 1,243 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Try not to turn so sharp
sixnotfour |
Jul 10 2021, 05:49 PM
914 Wizard Group: Members Posts: 10,681 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
914Sixer |
Jul 10 2021, 06:03 PM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
NEVER liked wheel spacers. Compare the length of your tie rods side to side. You might have a little adjustment room there. 914's bodies are KNOWN to be a little off side to side causing tire rub.
Jamie |
Jul 11 2021, 06:46 AM
Thanks "sixnotfour," that is just exactly the info I needed, and the price is right! (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 26th December 2024 - 08:25 PM |
