Type 4 engine on bug transmission? |
PatrickB |
Jul 11 2021, 07:44 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
I've got a bug guy asking and I can't answer the question, will it bolt up?
Thanks |
914sgofast2 |
Jul 11 2021, 07:53 AM
Senior Member Group: Members Posts: 655 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Yes. There are lots of Bugs powered by Type 4 engines; that’s why people do upright cooling conversions to Type 4’s. Gene Berg and Jack Ruby used to sell kits at one time.
Mark Henry |
Jul 11 2021, 08:52 AM
Yes and IIRC the 914 clutch bolts up, if not you can buy a conversion 200mm flywheel from AA Performance.
Yes. There are lots of Bugs powered by Type 4 engines; that’s why people do upright cooling conversions to Type 4’s. Gene Berg and Jack Ruby used to sell kits at one time. Gene Berg never did anything type 4 related. ...and Jack Ruby shot Lee Harvey Oswald. (IMG:style_emoticons/default/wink.gif) |
PatrickB |
Jul 11 2021, 09:32 AM
Yes and IIRC the 914 clutch bolts up, if not you can buy a conversion 200mm flywheel from AA Performance. Yes. There are lots of Bugs powered by Type 4 engines; that’s why people do upright cooling conversions to Type 4’s. Gene Berg and Jack Ruby used to sell kits at one time. Gene Berg never did anything type 4 related. ...and Jack Ruby shot Lee Harvey Oswald. (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/biggrin.gif) Thanks everyone, that's what I thought but wasn't sure. He wants my stuck 1.7 if he can bolt it to the bug trans. Not the way I'd go but that's up to him. |
porschetub |
Jul 11 2021, 04:50 PM
Advanced Member Group: Members Posts: 4,754 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Yes and IIRC the 914 clutch bolts up, if not you can buy a conversion 200mm flywheel from AA Performance. Yes. There are lots of Bugs powered by Type 4 engines; that’s why people do upright cooling conversions to Type 4’s. Gene Berg and Jack Ruby used to sell kits at one time. Gene Berg never did anything type 4 related. ...and Jack Ruby shot Lee Harvey Oswald. (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/biggrin.gif) Thanks everyone, that's what I thought but wasn't sure. He wants my stuck 1.7 if he can bolt it to the bug trans. Not the way I'd go but that's up to him. You need to bore the T4 flywheel out and press in a pilot bearing as the VW box has a shorter input shaft,my repop speedster had a swingaxle box so I had to modify to later IRS box type thrust bearing setup for T4 pressure plate. Mine was a late swing axle box from a 69 1500 so I retained the factory "Z" bar by mounting that to my box section steel subframe,made the drop links adjustable and it worked really well to combat the dreaded wheel tuck. So no its not plug and play but the mods are pretty easy to do. |
Mark Henry |
Jul 11 2021, 05:41 PM
Yes and IIRC the 914 clutch bolts up, if not you can buy a conversion 200mm flywheel from AA Performance. Yes. There are lots of Bugs powered by Type 4 engines; that’s why people do upright cooling conversions to Type 4’s. Gene Berg and Jack Ruby used to sell kits at one time. Gene Berg never did anything type 4 related. ...and Jack Ruby shot Lee Harvey Oswald. (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/biggrin.gif) Thanks everyone, that's what I thought but wasn't sure. He wants my stuck 1.7 if he can bolt it to the bug trans. Not the way I'd go but that's up to him. You need to bore the T4 flywheel out and press in a pilot bearing as the VW box has a shorter input shaft,my repop speedster had a swingaxle box so I had to modify to later IRS box type thrust bearing setup for T4 pressure plate. Mine was a late swing axle box from a 69 1500 so I retained the factory "Z" bar by mounting that to my box section steel subframe,made the drop links adjustable and it worked really well to combat the dreaded wheel tuck. So no its not plug and play but the mods are pretty easy to do. That's why I said the 914 flywheel might be good to go, as its pilot bearing presses into the flywheel. You are correct on the bus flywheel they have to be machined for the pilot bearing. But now days I'd just get the 200mm adapter flywheel from AA, it is plug and play and will accept a T1 KEP pressure plate. |
Al Meredith |
Jul 13 2021, 12:59 PM
Senior Member Group: Members Posts: 969 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I got a flywheel, PP and clutch kit from the Type 4 store (LN Engineering)
IronHillRestorations |
Jul 13 2021, 01:14 PM
I. I. R. C. Group: Members Posts: 6,792 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You can modify the '75/76 exhaust stub pipes pretty easily for a type 4 in a Bug, and they usually sell for around $75, or less
Lo-Fi Version | Time is now: 26th December 2024 - 10:40 AM |
