Turn signal troubleshooting, Looking for tips where to look/start first... |
campbellcj |
Jul 11 2021, 03:38 PM
I can't Re Member Group: Members Posts: 4,593 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Hey everyone - I have a problem I've been meaning to get resolved for some time but I'm not sure where things went wrong. Once I reinstalled the lights in my car after they had been out for several years of dedicated track use, the turn signals aren't working right; however, the puzzling part is the hazards blink fine, parking lights work, and the lever-actuated 'park mode' also works on both sides. This leads me to believe I pretty much connected things right and the stalk switch seems OK too, but obviously I went astray somewhere.
It's been a while but IIRC I did already try swapping in a different flasher relay to no avail. Also FWIW the stalk switch and dash wiring had not been removed/reinstalled, only the actual lamps up-front and their fuses. So the interior wiring should be basically unmolested (by me at least). This car is painful to work inside due to full rollcage and immovable seats. If any of you has seen this specific fault before I would massively appreciate a tip before I start poking around at every single wire (again)! Thanks! |
914-Kazoo |
Jul 17 2021, 07:12 PM
Newbie Group: Members Posts: 45 Joined: 19-August 20 From: Kalamazoo, MI Member No.: 24,609 Region Association: Upper MidWest |
Hey everyone - I have a problem I've been meaning to get resolved for some time but I'm not sure where things went wrong. Once I reinstalled the lights in my car after they had been out for several years of dedicated track use, the turn signals aren't working right; however, the puzzling part is the hazards blink fine, parking lights work, and the lever-actuated 'park mode' also works on both sides. This leads me to believe I pretty much connected things right and the stalk switch seems OK too, but obviously I went astray somewhere. It's been a while but IIRC I did already try swapping in a different flasher relay to no avail. Also FWIW the stalk switch and dash wiring had not been removed/reinstalled, only the actual lamps up-front and their fuses. So the interior wiring should be basically unmolested (by me at least). This car is painful to work inside due to full rollcage and immovable seats. If any of you has seen this specific fault before I would massively appreciate a tip before I start poking around at every single wire (again)! Thanks! Try pulling the bulbs and bending out the contacts in the sockets. Worked for me |
campbellcj |
Jul 18 2021, 12:40 PM
Thank you! I plan to put some time into this later today and/or next few days. Also going to put the horns back in which should be simple, hopefully.
bbrock |
Jul 18 2021, 01:01 PM
Also, make sure your grounds are all good. After finishing my bare metal resto, I had a strange problem with the right front turn signal. Turned out that the signal bucket bracket was not piercing through the bedliner I sprayed for undercoating so that bucket was not properly grounded. Instead, it was grounding through the other turn signal bulb cause weird light behavior. Once I tightened the bracket enough to make good contact with the chassis metal, everything worked perfectly.
Not saying that is your problem, just pointing out one of those weird things that can be hard to track down. |
mlindner |
Jul 18 2021, 02:34 PM
Senior Member Group: Members Posts: 1,591 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Chris my 914 was apart for 25 years, everything worked fine when taken off the street. Then this last year putting it all back together I had many electrical problem. But the last was like yours, ended up just replacing the direction assembly in the steering wheel stalk, very easy. All good. Best, Mark
Lo-Fi Version | Time is now: 26th December 2024 - 08:09 PM |
