oil pressure switch, wiring help needed! |
mobymutt |
Jul 11 2021, 08:11 PM
Senior Member Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I just swapped out my 1.8L for a 1.7L (so I could rebuild the 1.8L), and I can't find the wire that goes to the pressure switch.
I've got carbs, so the wire harnesses have a zillion unused wires. But I thought there would be a wire with a dangling connector somewhere nearby... apparently not. The car is a '74. From the wiring diagram, it looks like the wire should be green with red stripes, but I can't find that either. Can anybody tell me how I might go about finding the correct wire to hook up? Maybe the physical location of the wire run to start? Or where it comes from, or what other wires it would be with? Any help is appreciated, thank you! |
76-914 |
Jul 11 2021, 11:15 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC, that wire is attached to the rear of the engine case and goes towards the right side then stops close to the edge of the engine case.The connecting wire is below the battery and may have a plastic cover over the female spade.
iankarr |
Jul 12 2021, 12:30 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,526 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I'm away from the garage, but pretty sure oil pressure switch wire is part of the ignition harness, which connects via the large plug on the relay board. The oil temp wire sprouts from the main harness near the battery tray.
Jul 12 2021, 10:51 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I believe that Ian has the right answer here.
--DD |
GregAmy |
Jul 13 2021, 05:48 AM
Advanced Member Group: Members Posts: 2,411 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Gents, my notes indicate the OP switch wire is green/red and comes from the T12-1 pin on the relay plate (mine's a '74.)
If you were standing over the relay plate from the rear, the T12 plug is the 12-pin connector on the lower right, and the -1 pin is its upper left pin. Edit, actually a picture is worth a thousand of something... Attached thumbnail(s) |
mobymutt |
Jul 13 2021, 10:16 AM
914world to the rescue again! Thank you everyone!
Found the relevant wire wrapped under layers of extremely old black tape. This tells me a couple of things: -the PO's mechanic didn't concern himself with irrelevancies like oil pressure -the current owner was too daft to notice that it had never been hooked up before. So I now have new pretty green light on my dash when I turn the power on! With the engine running, should that green light turn off, or stay on? |
IronHillRestorations |
Jul 13 2021, 10:20 AM
I. I. R. C. Group: Members Posts: 6,792 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
930cabman |
Jul 13 2021, 10:49 AM
Advanced Member Group: Members Posts: 3,779 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
914world to the rescue again! Thank you everyone! Found the relevant wire wrapped under layers of extremely old black tape. This tells me a couple of things: -the PO's mechanic didn't concern himself with irrelevancies like oil pressure -the current owner was too daft to notice that it had never been hooked up before. PO might qualify in the DAPO category, you have to wonder about some of this stuff So I now have new pretty green light on my dash when I turn the power on! With the engine running, should that green light turn off, or stay on? |
76-914 |
Jul 13 2021, 11:09 AM
I'm away from the garage, but pretty sure oil pressure switch wire is part of the ignition harness, which connects via the large plug on the relay board. The oil temp wire sprouts from the main harness near the battery tray. You're right. I was thinking Oil Temp. (IMG:style_emoticons/default/headbang.gif) |
iankarr |
Jul 13 2021, 11:18 AM
914world to the rescue again! Thank you everyone! Found the relevant wire wrapped under layers of extremely old black tape. This tells me a couple of things: -the PO's mechanic didn't concern himself with irrelevancies like oil pressure -the current owner was too daft to notice that it had never been hooked up before. So I now have new pretty green light on my dash when I turn the power on! With the engine running, should that green light turn off, or stay on? Great that you're on the road to restoring things back to stock. it's entirely possible that the PO had an aftermarket oil pressure gauge installed and didn't use the stock wiring. A lot can happen in 50 years (IMG:style_emoticons/default/wink.gif). The green light should be on until the engine starts running, then turn off...assuming you have good oil pressure. If the light stays on, and your engine hasn't seized, the sender is probably bad. |
Lo-Fi Version | Time is now: 26th December 2024 - 07:42 AM |
