Rubber suspension bushings, Thinking of switching from poly |
Mowog4 |
Jul 14 2021, 10:55 AM
Member Group: Members Posts: 316 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I can tell I am quickly getting old, the poly bushings in my car squeak while I drive the car which is driving me nuts. I had a shop pull them out and grease them inside and out, worked for a couple days then the noise was back.
Any choices other than rubber, or is the rubber a good alternative? |
914Sixer |
Jul 14 2021, 11:00 AM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
914Rubber has a kit. URO did make 2 different hardness ones. Rubber is the way to go in my opinion unless your tracking the car.
Shivers |
Jul 14 2021, 11:05 AM
Senior Member Group: Members Posts: 2,824 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I have read around here that 914 rubber makes a nice rubber bushing.
I gave up chasing squeaks years ago, I found it easier to replace the 7 parts that didn't squeak with 7 that did. (IMG:style_emoticons/default/smile.gif) |
ClayPerrine |
Jul 14 2021, 11:20 AM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I tried all the various suspension bushings out there. Rubber, Delrin, and Needle Bearing. The Needle Bearing ones are great, but I got a really harsh ride. The Delrin bushings would stick and squeak. I tried grease fittings but that didn't fix it. I reamed the Delrin bushings, but to get them to not squeak, they got really sloppy tolerances.
I put in Elephant rubber bushings and the ride is acceptable, and the bushings don't squeak. Clay |
bbrock |
Jul 14 2021, 11:41 AM
I have 914Rubber bushings in the front, but their bushings fit way too loose in my rear trailing arms, so I put Elephant Racing bushings in the rear. Probably worth checking out this post: http://www.914world.com/bbs2/index.php?s=&...t&p=2888749
Mowog4 |
Jul 14 2021, 11:50 AM
I tried all the various suspension bushings out there. Rubber, Delrin, and Needle Bearing. The Needle Bearing ones are great, but I got a really harsh ride. The Delrin bushings would stick and squeak. I tried grease fittings but that didn't fix it. I reamed the Delrin bushings, but to get them to not squeak, they got really sloppy tolerances. I put in Elephant rubber bushings and the ride is acceptable, and the bushings don't squeak. Clay Seems to be a huge price difference between Elephant and the others, any idea why? |
willieg |
Jul 14 2021, 01:03 PM
Member Group: Members Posts: 138 Joined: 13-August 18 From: Pleasant Hill Member No.: 22,389 Region Association: Northern California |
I had a Sunbeam Tiger that was 98% road and 2% SCCA. I thought poly bushings would be better. NOT! Much firmer ride which is good for the track but not for the street. Also, with poly bushings, you hear all of the other noises.
Cairo94507 |
Jul 14 2021, 01:09 PM
Michael Group: Members Posts: 10,130 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Another vote for the Elephant Racing rubber bushings. That is what I have in my car along with Bilstein shocks/strut inserts, 140 pound rear springs, stock torsion bars and stock (later) F&R sway bars. Car rides and handles great. (IMG:style_emoticons/default/beerchug.gif)
76-914 |
Jul 14 2021, 04:34 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I have no experience with 914rubber's bushings but I can say that Elephant's product, albeit pricey, works great. And I can say with absolute certainty that I would never again install Delrin bushings. What an annoyance those things are. (IMG:style_emoticons/default/ar15.gif)
Root_Werks |
Jul 14 2021, 05:22 PM
Village Idiot Group: Members Posts: 8,508 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
914Rubber has a kit. URO did make 2 different hardness ones. Rubber is the way to go in my opinion unless your tracking the car. (IMG:style_emoticons/default/agree.gif) Ran all variants of suspension bushings in 914's. Depends what you want. For any street driving, rubber is the way to go. Much easier on the senses. |
Mikey914 |
Jul 14 2021, 08:18 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I tried all the various suspension bushings out there. Rubber, Delrin, and Needle Bearing. The Needle Bearing ones are great, but I got a really harsh ride. The Delrin bushings would stick and squeak. I tried grease fittings but that didn't fix it. I reamed the Delrin bushings, but to get them to not squeak, they got really sloppy tolerances. I put in Elephant rubber bushings and the ride is acceptable, and the bushings don't squeak. Clay Seems to be a huge price difference between Elephant and the others, any idea why? I think it may be somewhat their business model. They make a great product. At the end of the day unless there is an exotic formulation of the rubber, they are basically the same. We are less expensive in that we do hundreds of sets and are not in the business of trying to command a premium. Speaking for our design we simply tried to get as close to factory as we could on these. Mark |
bdstone914 |
Jul 14 2021, 08:20 PM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I can tell I am quickly getting old, the poly bushings in my car squeak while I drive the car which is driving me nuts. I had a shop pull them out and grease them inside and out, worked for a couple days then the noise was back. Any choices other than rubber, or is the rubber a good alternative? @Mowog4 Are you referring to front or rear bushings? The rear bushing are now carried b Restoration Designs. They come from the same company that supplies Elephant Racing. Not as pricey as Elephant. Installing the rears is quite a chore. I will be posting a thread with the tools I made to install them. 914 Rubber front bushing are good. I would not use Uro fronts again. Had too man problems with them. @76-914 |
914Toy |
Jul 14 2021, 09:23 PM
Senior Member Group: Members Posts: 737 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
I have no experience with 914rubber's bushings but I can say that Elephant's product, albeit pricey, works great. And I can say with absolute certainty that I would never again install Delrin bushings. What an annoyance those things are. (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/agree.gif) |
Mowog4 |
Jul 14 2021, 10:16 PM
I can tell I am quickly getting old, the poly bushings in my car squeak while I drive the car which is driving me nuts. I had a shop pull them out and grease them inside and out, worked for a couple days then the noise was back. Any choices other than rubber, or is the rubber a good alternative? @Mowog4 Are you referring to front or rear bushings? The rear bushing are now carried b Restoration Designs. They come from the same company that supplies Elephant Racing. Not as pricey as Elephant. Installing the rears is quite a chore. I will be posting a thread with the tools I made to install them. 914 Rubber front bushing are good. I would not use Uro fronts again. Had too man problems with them. @76-914 I am going to do both front and rear. The car has become a nice driver, but the creaking is driving me nuts |
Mikey914 |
Jul 14 2021, 11:23 PM
We do sell the tool for the fronts with the bushings . Ian did a video with how to install that is worth checking out.
Removal https://youtu.be/qa-apYYIjlg Install https://youtu.be/5AysZlHr2lM TAKE NOTE as to what he says at 2:50 --- This is important Not a super easy job, but you can get a good idea of what you will be in for. |
ClayPerrine |
Jul 15 2021, 07:57 AM
@mikey914 I am not knocking 914Rubber's bushings. It is just that I have never used them. I bought Elephant's bushings years ago, before you put yours out. If your bushings follow form with the rest of your products, then they will be great.
The bushings in Frody (Betty's 914) and Igor (My Six conversion) are from Elephant. I bought two complete sets when they first came out and did both cars, just to get rid of the delrin bushings on Frody, and the needle bearings on Igor. I bought one set of the install tools, and I still have them. The installation was easy, as long as you used lots of lube. Putting the rubber bushings in both cars made them nice to drive on the street again. The bushings in Elwood (Our factory six) are 50 year old factory bushings. I am not touching them until they actually fail. Clay |
brant |
Jul 15 2021, 08:19 AM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
just a point of reference to squeaking....
I put Weltmeister (hard poly like) bushing into my street car front and rear this was around 1986 the squeaks were significant I grooved (with a dremel) a spiral channel that goes around the bushing for the length of the bushing... installed grease Zerks... right over the groove. no more squeaks in 35 years. also I experienced more sticktion.... in the suspension before the zerks the race car runs roller bearings front and rear |
Mowog4 |
Jul 15 2021, 07:18 PM
just a point of reference to squeaking.... I put Weltmeister (hard poly like) bushing into my street car front and rear this was around 1986 the squeaks were significant I grooved (with a dremel) a spiral channel that goes around the bushing for the length of the bushing... installed grease Zerks... right over the groove. no more squeaks in 35 years. also I experienced more sticktion.... in the suspension before the zerks the race car runs roller bearings front and rear I ordered rubber bushings from 914 rubber and RD today, I may try the spiral grooves beforehand. Thanks for all of the suggestions |
Lo-Fi Version | Time is now: 26th December 2024 - 02:01 PM |
