Wiring diagram, Which one |
NARP74 |
Jul 14 2021, 01:18 PM
Senior Member Group: Members Posts: 1,300 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I am watching the GeorgeKopf thread and did not want to jack his. I need to look at a wiring diagram and when I searched on the wiring diagrams site, 2 options came up, 74 with L jet and 74 with D jet. My 74 model year car has a date of 10/73, so which is it for me?
My FI is long gone, turned into carbs. The previous 3 or 4 owners made all of my decisions for me. Thanks for the help. |
JeffBowlsby |
Jul 14 2021, 02:34 PM
914 Wiring Harnesses Group: Members Posts: 8,780 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The chassis harness is the same for a given model year, no difference whether its D-Jet or L-Jet.
StarBear |
Jul 14 2021, 03:56 PM
Advanced Member Group: Members Posts: 2,084 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
The VIN number is a good start. On window trim and in frank. The paint code on the decal on the drivers door jam too but they’re often missing.
914Sixer |
Jul 14 2021, 04:30 PM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Karmann started the next year build in August, SO the 1974 model year run started then. The 1974 run should the first year of the seat belt interlock.
StarBear |
Jul 14 2021, 06:19 PM
Also first year of the dual relay under the battery tray. Mine’s Nov 73 and early mid 74 production number.
Jul 15 2021, 12:01 AM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The L-Jet was used on the 1.8 liter 914s. D-jet was used on the 2.0 914s.
D-jet used a silver "hand grenade" (MPS) with a single vacuum hose and a four-wire plug on it on the right side of the engine bay under the battery. L-jet used a "barn door" air flow meter attached to the air filter, with a quarter-circle "bump-out" on the side of it. --DD |
NARP74 |
Jul 15 2021, 09:01 AM
All good info, thank you.
barefoot |
Jul 15 2021, 11:19 AM
Senior Member Group: Members Posts: 1,334 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Lo-Fi Version | Time is now: 26th December 2024 - 04:46 AM |
