Over my head with my 914, Need help |
NJTom |
Jul 20 2021, 02:13 PM
Member Group: Members Posts: 96 Joined: 16-July 14 From: NJ Member No.: 17,643 Region Association: None |
Hello, the forum has been a great asset in the past and I’m hoping it will be again. My mechanic passed away and he rebuilt my 1972 swapping out the 1.8 and putting in a 74 2.0. The last thing he told me before he left this earth was get a new Weber carburetor which I did and I installed, that was pushing my mechanical ability. I don’t race or beat my car it’s strictly a Sunday driver. Here’s my situation, when I start and drive the car ir runs and drives smooth and purrs like a kitten! After about 15 minutes it back fires cuts out and jerks like a bronco! Odd that it can go from one extreme to the other. One other thing the coil gets HOT! Like so hot you can’t touch it. I was wondering if the coil might be bad and that was the cause a lack of voltage??? In that 15 minute window the car idles fine. Any thoughts or suggestions are greatly appreciated. Thanks in advance! Tom
RiqueMar |
Jul 20 2021, 02:17 PM
Enrique Allen Mar Group: Members Posts: 2,179 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
NJTom - I'm sorry to hear about your mechanic passing away. While I don't have any input on this specific subject, I'm sure that with the help of the forum as well as some self-determination, you'll get there. Using myself as an example, I was not mechanically inclined when I embarked on my project. However, everything I've learned about cars has been out of a desire to create / build my own.
You can do it! |
NJTom |
Jul 20 2021, 02:39 PM
NJTom - I'm sorry to hear about your mechanic passing away. While I don't have any input on this specific subject, I'm sure that with the help of the forum as well as some self-determination, you'll get there. Using myself as an example, I was not mechanically inclined when I embarked on my project. However, everything I've learned about cars has been out of a desire to create / build my own. You can do it! Thanks for the vote of confidence! Very much appreciated!!! |
Pops71Por |
Jul 20 2021, 03:27 PM
Newbie Group: Members Posts: 15 Joined: 30-December 20 From: NC Member No.: 25,032 Region Association: South East States |
NJTom - I'm sorry to hear about your mechanic passing away. While I don't have any input on this specific subject, I'm sure that with the help of the forum as well as some self-determination, you'll get there. Using myself as an example, I was not mechanically inclined when I embarked on my project. However, everything I've learned about cars has been out of a desire to create / build my own. You can do it! Symptoms of a bad coil or condenser back fire and hot are top of their lists. Both very easy to exchange. make sure you take pictures of the wiring you have now and note the + and - of the coil. and usually the green wire going over to condenser on outside of your Dizzy. Condenser is the cheapest first test and available at your local auto store. if you have same issue, then coil needs to be replaced. again, note +/- and hook up wires accordingly. should fix your issues, coils should not run so hot you can't touch them. |
dr914@autoatlanta.com |
Jul 20 2021, 03:30 PM
914 Guru Group: Members Posts: 8,110 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
a guess would be a bad condenser, I would replace points and condenser and set the dwell and timing
Hello, the forum has been a great asset in the past and I’m hoping it will be again. My mechanic passed away and he rebuilt my 1972 swapping out the 1.8 and putting in a 74 2.0. The last thing he told me before he left this earth was get a new Weber carburetor which I did and I installed, that was pushing my mechanical ability. I don’t race or beat my car it’s strictly a Sunday driver. Here’s my situation, when I start and drive the car ir runs and drives smooth and purrs like a kitten! After about 15 minutes it back fires cuts out and jerks like a bronco! Odd that it can go from one extreme to the other. One other thing the coil gets HOT! Like so hot you can’t touch it. I was wondering if the coil might be bad and that was the cause a lack of voltage??? In that 15 minute window the car idles fine. Any thoughts or suggestions are greatly appreciated. Thanks in advance! Tom |
IronHillRestorations |
Jul 20 2021, 03:36 PM
I. I. R. C. Group: Members Posts: 6,792 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Make sure the coil is hooked up properly. Black/Red wire goes to + black/purple & wire to distributor goes to -
Justinp71 |
Jul 20 2021, 04:08 PM
Senior Member Group: Members Posts: 1,606 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
When you installed the carburetor did you go to a low pressure fuel pump or was the car already carbureted? Running a carb on fuel injection pressure is dangerous. |
NJTom |
Jul 20 2021, 05:00 PM
a guess would be a bad condenser, I would replace points and condenser and set the dwell and timing Hello, the forum has been a great asset in the past and I’m hoping it will be again. My mechanic passed away and he rebuilt my 1972 swapping out the 1.8 and putting in a 74 2.0. The last thing he told me before he left this earth was get a new Weber carburetor which I did and I installed, that was pushing my mechanical ability. I don’t race or beat my car it’s strictly a Sunday driver. Here’s my situation, when I start and drive the car ir runs and drives smooth and purrs like a kitten! After about 15 minutes it back fires cuts out and jerks like a bronco! Odd that it can go from one extreme to the other. One other thing the coil gets HOT! Like so hot you can’t touch it. I was wondering if the coil might be bad and that was the cause a lack of voltage??? In that 15 minute window the car idles fine. Any thoughts or suggestions are greatly appreciated. Thanks in advance! Tom Thanks!!! |
NJTom |
Jul 20 2021, 05:44 PM
NJTom |
Jul 20 2021, 05:45 PM
Shivers |
Jul 20 2021, 05:48 PM
Senior Member Group: Members Posts: 2,824 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
"One other thing the coil gets HOT! Like so hot you can’t touch it."
That is textbook of a coil going bad. |
bbrock |
Jul 20 2021, 08:10 PM
I'm going through something similar. I installed a dizzy with new points and condensor but only had an old coil of questionable condition to pair with it. Car ran like a top for a couple weeks but then started missing and backfiring and the coil got too hot to touch. New coil should be here tomorrow.
930cabman |
Jul 21 2021, 05:31 AM
Advanced Member Group: Members Posts: 3,780 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I cannot recall, but checking the resistance would be a simple check.
https://www.google.com/search?q=ignition+co...=490_i142k_wQnM I am sure there is a spec somewhere in Haynes or ... |
NARP74 |
Jul 21 2021, 10:12 AM
Senior Member Group: Members Posts: 1,300 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
In the Land Rover world there is a saying, Land Rover, making mechanics out of owners for 50 years! Same in the 914 world. Don't fight the process, it will happen over time. Learn what you can, know your limits and find a new mechanic if your can. Sorry yours passed away. Sad to see all the knowledge disappear, but this site is a database to be used.
seatosummit |
Jul 21 2021, 12:14 PM
Newbie Group: Members Posts: 19 Joined: 23-December 20 From: Berkeley Member No.: 25,012 Region Association: None |
I had similar symptoms with my carbed two liter and replaced the coil. Fixed my issue.
Relatively inexpensive to try! Second what others have said re verifying wiring. Good luck! |
Lo-Fi Version | Time is now: 26th December 2024 - 04:22 PM |
