> Out side mirror replacement mirror
jims914
post Jul 21 2021, 09:52 PM
Any one have a good time replacing the mirror on the outside mirror.
any replacement parts ?
dhuckabay
post Jul 21 2021, 09:56 PM
QUOTE(jims914 @ Jul 21 2021, 08:52 PM) *
914 Rubber has the glass, doesn't seem to be a project to replace. Gaskets if you are replacing the entire mirror are readily available.
IronHillRestorations
I. I. R. C.
Check out one of our sponsors: 914 Rubber
jims914
post Jul 21 2021, 11:19 PM
QUOTE(IronHillRestorations @ Jul 21 2021, 08:56 PM) *
Thanks for the respond.
The glass is no problem, it's the the inner mirror grommet and outer black retainer seal.
914Sixer
post Jul 22 2021, 06:04 AM
Check over at Auto Atlanta, thinking George had those parts. If not listed call and check with them.
Arno914
post Jul 22 2021, 09:49 AM
Region Association: Germany
There is a difference between early (up to 71) and later side mirrors.
Early ones are about 5mm shorter (less wide). Should have different glass, too.
I finally "found" a ´71 914 with the stock mirror to prove this. Also note that the 90° arm is not "round" but more "angular".
(IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1626968976.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1626968980.2.jpg)
- Lo-Fi Version Time is now: 26th December 2024 - 01:56 PM
