7 Pages V « < 3 4 5 6 7 >
> nditiz1's mediocre 6 conversion, SOLD at auction, off to a new home
mb911
post Sep 22 2021, 08:01 PM
Post #81
Just saw your oil leak video. Thinking a cam seal or rocker shaft on the one side then the other looks like the case thru bolt. That is an ugly proposition.. hope that's not the case.. I know mine has few leaks..
nditiz1
post Oct 1 2021, 09:16 AM
Post #82
What goes in must come out, now I can fix those trans mounts (IMG:style_emoticons/default/biggrin.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1633101391.1.jpg)
Root_Werks
post Oct 1 2021, 12:14 PM
Post #83
Village Idiot
Oil leaks suck, I feel your pain.
nditiz1
post Oct 4 2021, 09:32 PM
Post #84
So I think I found the culprit (fingers crossed) on the 4/5/6 side. A new gasket with locktite 574 and a recheck of the cam timing will hopefully seal that up.
Also, I wasn't thrilled about the run out on the rear rotors. I had them turned and they went out of spec so new Sebro's it is.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1633404752.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1633404753.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1633404753.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1633404753.4.jpg)
nditiz1
Post #85
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1633404753.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1633404754.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1633404754.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1633404754.4.jpg)
ClayPerrine
post Oct 5 2021, 10:48 AM
Post #86
Why did you use a coarse wood screw to pull the cam pin? You probably messed up the threads in it.
Just take the cap off a spark plug and use that. It is the exact same threads.
Clay
nditiz1
post Oct 5 2021, 12:48 PM
Post #87
Only you would spot that Clay Hahahaha. I did have one and I mistakenly threw it out while cleaning. I had another spark plug, but the cap was glued or pressed on. I gently threaded it in only so far. It came out with no force all threads still in tact.
nditiz1
post Nov 11 2021, 04:03 PM
Post #88
I'm slowly working on the 2.7 to address oil leaks. I decided to do the right thing and buy a different engine (IMG:style_emoticons/default/biggrin.gif)
This one needs two exhaust studs fixes and I'll perform a health check. Then it's onto some RHD ITBs from X-faktory.
nditiz1
post Apr 20 2022, 01:37 PM
Post #89
Haven't updated this thread for awhile
Updates:
In talks of picking up some Zenith Carbs to simplify testing the 2.7 for leaks I ended up trading down? er sideways? I don't which way, but at least towards a drivable 914 again. So the ITB twin plug 2.7 is turning into a 73 2.4 carb'd engine. Leak down numbers were almost perfect. With it I needed to move away from FI setup.
So here is the new Fuel Pump almost fully installed.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1650483465.1.jpg)
Also got my GT lid finished, not perfect, but looks presentable.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1650483466.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1650483466.3.jpg)
New front bumper mounting as well. I didn't realize how much fiberglass sucks. I thought when I ripped off the weird shelf screwed to the front for the other fiberglass bumper it was because they didn't know what they were doing. Now, I see it was there to prevent the dip down in the center. Once I get something back in place it should look right. Also, mounted some fresh horns - but wiring is now preventing them from workie.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1650483466.4.jpg)
Superhawk996
post Apr 21 2022, 05:27 AM
Post #90
QUOTE(nditiz1 @ Apr 20 2022, 03:37 PM) *
Nice progress. What is the black big canister before the fuel pump? a Pre-filter?
You seem to be collecting more engines than me (IMG:style_emoticons/default/biggrin.gif)
Shivers
post Apr 21 2022, 08:32 AM
Post #91
I love the short stroke engines, The 2.4, if I can pull it off will be the engine I run. Very cool build
mskala
post Apr 21 2022, 12:11 PM
Post #92
R
QUOTE(Shivers @ Apr 21 2022, 10:32 AM) *
2.4 (standard) is not a short stroke. The 2.0 and 2.2 are short stroke. Bigger cylinders
can be run on the 2.2 to get a short-stroke 2.5. Also, what I run is AA 86mm for a 2.3L
size.
nditiz1
post Apr 21 2022, 07:41 PM
Post #93
Here is the 2.4 that will ship to me tomorrow.
Phil - I traded the one I started this thread with. Also sold the 1.8, that gets picked up Sunday. That black cyl is a 100 micron fuel filter. I picked it up as a reusable filter and the cb performance pump came with a mini pre filter so I decided to keep it. This should ensure the zeniths stay clear.
nditiz1
post Apr 26 2022, 05:07 PM
Post #94
I got the new fuel system plumbed and ready. Ran a fused wire off number 8 fuse, ya know, for extra fuseage. Got rid of that horrid AC box. Which leaves me with a gapping hole that will receive a sheet of aluminum (temporarily). Also got my horns working so that's a good thing. Engine could be here tomorrow.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1651014423.1.jpg)
nditiz1
post May 3 2022, 04:44 PM
Post #95
Engine is in!
First start video. Running good. Just need to hook all the cables back up, reattach shift rod, adjust clutch and throttle, reattach and torque axles, little tidying up and she should be good for her maiden voyage. Got to this point last year prior to Okteenerfest only to be stunted by some major oil leaks.
2.4 first start
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1651618116.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1651618117.2.jpg)
Root_Werks
post May 3 2022, 05:08 PM
Post #96
Village Idiot
Sounds pretty good! That much closer to driving!
Cairo94507
post May 4 2022, 06:52 AM
Post #97
Michael
Wow, she starts right up. You will have her back on the road in no time. Congratulations. (IMG:style_emoticons/default/beerchug.gif)
jaredmcginness
post May 4 2022, 08:25 AM
Post #98
Looks great Nick,
Let me know if you want me to patch up/replace that front trunk pan this summer or when driving season is over. RD makes a nice replacement piece.
BillJ
post May 4 2022, 08:42 AM
Post #99
Awesome! Looking forward to first drive i bet
Dion
post May 4 2022, 11:02 AM
Post #100
RN
Way to go Nick! A good feeling for sure. Happy for ya.
- Lo-Fi Version Time is now: 31st October 2024 - 10:27 PM
