Replacement Fuel Injectors, Have an injector leaking |
SteveL |
Aug 19 2021, 07:14 PM
Senior Member Group: Members Posts: 663 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
I installed one side (2 injectors) to replace the one that was leaking. Car runs smoother than before. I'll install the other side tomorrow.
The only issue I have is that I had to lengthen the fuel lines to the fuel rail to allow for the straight shorty hoses on the injectors. It looks like AA usually sells the curved injector lines, but they are out of stock. Once I get the other side done, I'll send my Bosch injectors to Mr. Injector to have a backups. OK, fuel geyser resolved. Now to find why fuel pressure suddenly drops to 0 intermittently... Thanks all! |
ClayPerrine |
Aug 19 2021, 09:32 PM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
For those of you running L-Jet on a 1.8, go to FLAPS and get 4 injectors for a 1980 Datsun 280ZX. Nippondenso built the L-Jet system for Nissan/Datsun under license from Bosch, and the injectors for the Z are mechanically and electrically the same ones used on the 912E. The 912E was L-Jet on a 2.0 914 engine, and the injectors are interchangeable.
Here is some info on them: Beck/Arnley Part Number 158-0099 Used on Alfa Romeo, Fiat, Jaguar, Nissan, Opel, Porsche, Renault, Triumph Hope that helps. Clay |
FlacaProductions |
Aug 20 2021, 09:54 AM
Senior Member Group: Members Posts: 1,840 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Here are the FJ67's I'm running - 74 2.0 - same stubby appearance but they seem to work great. Stock/standard seals fit as normal.
wonkipop |
Aug 21 2021, 02:56 AM
Advanced Member Group: Members Posts: 4,667 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
For those of you running L-Jet on a 1.8, go to FLAPS and get 4 injectors for a 1980 Datsun 280ZX. Nippondenso built the L-Jet system for Nissan/Datsun under license from Bosch, and the injectors for the Z are mechanically and electrically the same ones used on the 912E. The 912E was L-Jet on a 2.0 914 engine, and the injectors are interchangeable. Here is some info on them: Beck/Arnley Part Number 158-0099 Used on Alfa Romeo, Fiat, Jaguar, Nissan, Opel, Porsche, Renault, Triumph Hope that helps. Clay i'm filing this info, thanks. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 22nd December 2024 - 07:05 PM |
