| 930cabman |
Sep 20 2021, 05:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,886 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
It seems like yesterday, but I recall running an engine at WOT for a short time, cutting off the power and coasting to a stop. These days we have air/fuel readers fed information from 02 sensors, with mapping, blah, blah. I suppose some of us older guys have gotten up to speed with tech, but not this guy. Our recent 914 purchase had previously received a Holley 2V carb conversion. It was starting/running decent, but pulled the engine to repair a bad oil leak. The front (hub) seal was loose in the case, so it seems as though I found the oil leak and also decided to pull the plugs for a quick clean. I was pleasantly surprised to find all the plugs a light tan color.
| 914e |
Sep 20 2021, 05:57 PM
Member ![]() ![]() Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region
It seems like yesterday, but I recall running an engine at WOT for a short time, cutting off the power and coasting to a stop. These days we have air/fuel readers fed information from 02 sensors, with mapping, blah, blah. I suppose some of us older guys have gotten up to speed with tech, but not this guy. Our recent 914 purchase had previously received a Holley 2V carb conversion. It was starting/running decent, but pulled the engine to repair a bad oil leak. The front (hub) seal was loose in the case, so it seems as though I found the oil leak and also decided to pull the plugs for a quick clean. I was pleasantly surprised to find all the plugs a light tan color. Computer engine control has around 40 years now (hard to believe time flies). I'm sure any mechanic that doesn't have gray hair may have never seen anything but a perfect burn. Maybe points, carburetors, and mechanical fuel injection caused the gray hairs. I still tell my kids they caused it, I didn't have gray hair before they existed, ever since they were born I am grayer every year. |
| 930cabman |
Sep 20 2021, 06:02 PM
It seems like yesterday, but I recall running an engine at WOT for a short time, cutting off the power and coasting to a stop. These days we have air/fuel readers fed information from 02 sensors, with mapping, blah, blah. I suppose some of us older guys have gotten up to speed with tech, but not this guy. Our recent 914 purchase had previously received a Holley 2V carb conversion. It was starting/running decent, but pulled the engine to repair a bad oil leak. The front (hub) seal was loose in the case, so it seems as though I found the oil leak and also decided to pull the plugs for a quick clean. I was pleasantly surprised to find all the plugs a light tan color. Computer engine control has around 40 years now (hard to believe time flies). I'm sure any mechanic that doesn't have gray hair may have never seen anything but a perfect burn. Maybe points, carburetors, and mechanical fuel injection caused the gray hairs. I still tell my kids they caused it, I didn't have gray hair before they existed, ever since they were born I am grayer every year. Have any grandkids added to the snow on the roof? |
| tom.esh |
Sep 20 2021, 06:14 PM
Member ![]() ![]() Group: Members Posts: 64 Joined: 6-March 14 From: Canton Ohio Member No.: 17,083 Region Association: North East States
Oh thanks. Now I'm an old guy. Just pulled the plug on a 4 wheeler to see how it looked after a carb rebuild.
| Rand |
Sep 20 2021, 07:30 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
No matter the engine control, plug reading never lies. (IMG:style_emoticons/default/smile.gif)
| windforfun |
Sep 20 2021, 08:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,115 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
| Rand |
Sep 20 2021, 09:03 PM
All current competitive racers still read plugs!
of course these days, everyone wants to just run their transportation thoughtlessly and never do anything except refuel and only because they have to, or use an app to try and find the nearest plugin |
| 930cabman |
Sep 21 2021, 12:28 PM
Thanks for the replies, my gut was telling me the old tried/true method still works.
This works for the main circuit, how about the idle/transition circuits? |
| Rand |
Sep 21 2021, 03:43 PM
| 930cabman |
Sep 21 2021, 04:25 PM
Might be a task to get this old dog to change, but I am considering either twin Webers or cobbling together a L jet system from several boxes of parts. I know the carbs will work, and I have many concerns with 50 years old parts/sensors/ECU/...
| porschetub |
Sep 22 2021, 04:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,203 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Might be a task to get this old dog to change, but I am considering either twin Webers or cobbling together a L jet system from several boxes of parts. I know the carbs will work, and I have many concerns with 50 years old parts/sensors/ECU/... L-jet is fine as not too much to go wrong,ecu's seem to be pretty robust but the real issue that comes up is the AFM which can be worn out and the air gate (flap) sticks up ,appears to be a few reman units around for reasonable money however. FI looms suffer with the heat but can be repaired,my next build will be with L-jet and I have otherwise good parts except for the AFM which is the reason the last owner of the system went to carbs. Its a good system IMO problem it just came with a really gutless motor (IMG:style_emoticons/default/sad.gif) ,the fact you can bore and stroke the motor and not change the system is good. |
| 930cabman |
Sep 23 2021, 05:52 PM
Might be a task to get this old dog to change, but I am considering either twin Webers or cobbling together a L jet system from several boxes of parts. I know the carbs will work, and I have many concerns with 50 years old parts/sensors/ECU/... L-jet is fine as not too much to go wrong,ecu's seem to be pretty robust but the real issue that comes up is the AFM which can be worn out and the air gate (flap) sticks up ,appears to be a few reman units around for reasonable money however. FI looms suffer with the heat but can be repaired,my next build will be with L-jet and I have otherwise good parts except for the AFM which is the reason the last owner of the system went to carbs. Its a good system IMO problem it just came with a really gutless motor (IMG:style_emoticons/default/sad.gif) ,the fact you can bore and stroke the motor and not change the system is good. The consensus here is FI, almost exclusively. I probably have three boxes full of D jet and L jet parts from a few parts cars and are semi considering going with an L jet on a current build. Several years ago an '85 Alfa spider came my way and I fought with it's L jet system until I finally ditched it and went with twin Weber 40 DCOE's. Still running great. In a couple hours I can have this current build running with twin Weber 40 IDF's, but I sense it will take weeks or more if I attempt L jet. |
| roblav1 |
Sep 23 2021, 06:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I'm one of those old dogs... been reading plugs since 1974. Even though I put 46 PMO's on my GT build, I'd still recommend sticking with FI in yours.
| Superhawk996 |
Sep 24 2021, 06:40 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,186 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
In a couple hours I can have this current build running with twin Weber 40 IDF's, but I sense it will take weeks or more if I attempt L jet. @930cabman And you could take the easy way out and be driving a Boxter too. (IMG:style_emoticons/default/happy11.gif) |
| 930cabman |
Sep 24 2021, 12:10 PM
In a couple hours I can have this current build running with twin Weber 40 IDF's, but I sense it will take weeks or more if I attempt L jet. @930cabman And you could take the easy way out and be driving a Boxter too. (IMG:style_emoticons/default/happy11.gif) I considered that option several years ago, but have an allergy to computers. My '16 F150 is enough vehicle computer for me. Hence, my hesitation to unbox a bunch of L jet parts and get her running. BTW: still using a flip phone |
Lo-Fi Version | Time is now: 22nd November 2026 - 05:10 AM |
