51 Pages V « < 4 5 6 7 8 > »
> First of the Texas Twins, First Build
Puebloswatcop
post Nov 4 2021, 04:50 PM
Post #101
I am trying to figure out if the undercoating was all from the factory or if someone added more? Did the heat shield come from the factory or dealership with undercoating on it....I would think that might be an aweful smell when it got hot.
Puebloswatcop
post Nov 4 2021, 04:54 PM
Post #102
At least I didnt have to scrape the undercoating from half of the floor since I replaced it I will have to grind and add another bead of weld to the seam though, now that I dont have to do it laying upside down....I hate overhead welding.
Puebloswatcop
post Nov 4 2021, 04:57 PM
Post #103
After getting about 90% of the front half cleaned off, it was time for lunch. Only took about 3 hours...lol
Puebloswatcop
post Nov 4 2021, 05:00 PM
Post #104
I did find a few dents in the floor pan of the frunk that need some attention. Also was wondering if it would be better to re-seal the floor plugs or just weld them in? anyones thoughts would be appreciated.
Puebloswatcop
post Nov 4 2021, 05:03 PM
Post #105
Allot of the seam sealer is still pretty well adhered. There was a short strip that was peeling so I removed it. Question would it be better to remove it all and reseal all of the seams, Or just spots where it needs attention?
Puebloswatcop
post Nov 4 2021, 05:08 PM
Post #106
Got some of the heavy stuff off of the suspension mounts and the heat shield....Then it was Busch time (IMG:style_emoticons/default/beer3.gif)
Puebloswatcop
post Nov 5 2021, 04:32 PM
Post #107
Another day of stripping under coating, yee ha,
Puebloswatcop
post Nov 5 2021, 04:33 PM
Post #108
Still a long way to go to get it cleaned up:
Puebloswatcop
post Nov 5 2021, 04:35 PM
Post #109
I did get the muffler heat shield removed and of course allot more undercoating under that.
Puebloswatcop
post Nov 5 2021, 04:39 PM
Post #110
Still a few questions...
1. What is the reccomendation for removing and re-applying the seam sealer? All or just where it was coming off?
2. As for the body plugs, leave them, reseal or weld them in?
3. Any recommendations on what to use to remove the glue from the rear firewall?
Thanks for any input...or recommendations.
bkrantz
post Nov 5 2021, 07:32 PM
Post #111
I was pretty aggressive about removing original seam sealer. I tried prying under the edge of each section. If it came off easily, or if I saw rust, I kept going.
I welded some of the body plugs, but I am not fussy about originality.
Puebloswatcop
post Nov 6 2021, 07:45 AM
Post #112
QUOTE(bkrantz @ Nov 5 2021, 06:32 PM) *
Thanks for your input Bob. I'm not fussy about originality either. I just want a sound car that will look good and last and be the fun to drive 914 we all love.
Puebloswatcop
post Nov 8 2021, 04:19 PM
Post #113
Another day of welding up holes. The P/O had installed a makeshift oil cooler that vented up into the trunk, so I had to fill all the holes he drilled. About a dozen.
Puebloswatcop
post Nov 8 2021, 04:28 PM
Post #114
Then figured I would go to work on the heat shield. I really liked the idea that a couple of guys had about making the shield removable. So I fabricated 2 brackets using the design that Bob Krantz did in his build. Then bolted them where I wanted them to be located on the body and the shield. I left the cut off brackets on both so I could line everything up so the shield would be at the same height and in the exact same location as when it was welded in. Then clamped it back in place with vice grips to mark the locations for the brackets.
Puebloswatcop
post Nov 8 2021, 04:30 PM
Post #115
Then welded the brackets in place on the body.
Puebloswatcop
post Nov 8 2021, 04:33 PM
Post #116
After confirming the fit I went through and cut off all of the old brackets.
Puebloswatcop
post Nov 8 2021, 04:37 PM
Post #117
In the end, I am pleased with the fit. Now i can go back to cleaning all the undercoating and dirt. Hopefully soon it will be time to have the body blasted. 47 years of dirt is waring on me...lol
Puebloswatcop
post Nov 9 2021, 09:23 AM
Post #118
So, over the weekend I got frustrated about not having my work manuals in the garage where they are readily handy. So I built a bookshelf to add to the wall specifically for workshop manuals.
And I picked up a white board to help keep me on task. I've already identified several things that need doing, hopfully it will help me stay focused.
Puebloswatcop
post Nov 9 2021, 05:33 PM
Post #119
BAck to working on the car, or should I say playing, I love retirement. Decided to repair a rust issue below the drivers side het tube. This area is a PITA to get to because none of my cutting wheels would fit without cutting into the heater tube. Luckily the rust area was very small.
Puebloswatcop
post Nov 9 2021, 05:37 PM
Post #120
So between metal sheers, a 2" cutoff wheel and borrowing my wife's dremmel tool, I was able to cut out the spot till I hit solid metal again. Not the straight lines I had envisioned, but will just have to adust the patch to fit.
- Lo-Fi Version Time is now: 4th April 2025 - 04:36 PM
