51 Pages V « < 14 15 16 17 18 > »
> First of the Texas Twins, First Build
Puebloswatcop
post Jan 8 2022, 04:18 PM
Post #301
But after wiping them with several rags, most of the goo is gone so you can inspect the individual parts...
Puebloswatcop
post Jan 8 2022, 04:20 PM
Post #302
Just a quick look at the outer race (housing) and you can see it showes very little wear.
Puebloswatcop
post Jan 8 2022, 04:27 PM
Post #303
For the ease of cleaning and not losing parts I reassembled the CV joint and dropped it into a can of diesel for the night.
Puebloswatcop
post Jan 8 2022, 04:30 PM
Post #304
As you can see, after cleaning just 1 CV joint, it creates allot of greasy rags and a couple of pairs of gloves....If you are inclined to do this nasty chore for yourself I will post the step by step outline tomorrow since it is going to be another rainy day in Texas....
Puebloswatcop
post Jan 9 2022, 11:58 AM
Post #305
So I know I said I would post the step by step on how to rebuild your CV joints on your rear axles. However I don't believe in re-inventing the wheel, and I see that Ian Karr has already done a great video on the subject. I guarantee Ian is allot more fun to watch than people listening to me ramble. Here is the link:
https://youtu.be/F-5Xpug52Qw
The only thing I would recommend is when you remove the stub axle, is to partially thread the bolts back into the holes and use a soft hammer (I prefer a plastic end) to tap the stub axle loose rather than use a screwdriver. I can't tell you the number of joints that I have seen that are all gouged up because of screwdriver use.
The other thing is to pay close attention to getting the narrow part of the cage alligned with the wide part of the housing. Believe it or not it can be assembled with the narrow and wide parts alligned, but if you run it that way on your car it will destroy the the joint and probably allot of other things in the process.
The best way to insure you have it correct is to see if you can deflect the cage in and out of the housing (both ways) without it falling out. If you can't deflect the cage, look closely and you probably have the wide portions alligned with the large and the small with the small.....
Literati914
post Jan 9 2022, 12:07 PM
Post #306
Good tips, another job I'll be benefitting from you doing first ! (IMG:style_emoticons/default/biggrin.gif)
Puebloswatcop
post Jan 14 2022, 09:09 AM
Post #307
Well after a totally wasted day yesterday searching for a lost animal, I am back at it today. Spent the past few days cleaning parts and finshed blasting a bunch for powder coating.
Hopefully the parts I am waiting on will be delivered today and I can get back to work....and if you were wondering the animal in question decided to return on his own when he got hungry...
Puebloswatcop
post Jan 15 2022, 07:48 AM
Post #308
While I was waiting I decided to tear down the last 2 axle sets that I have. These were from my 1973 fireball parts car. As you can see, there is some fire damage to the boots, but it doesnt appear to have caused extensive damage to the actual axle assemblies.
Puebloswatcop
post Jan 15 2022, 08:09 AM
Post #309
After tearing down the first joint, the one with the most heat exposure, I was fairly pleased with what I saw. The cage and bearings were in pretty good shape. They dont appear to have any heat damage. Some of the ball bearings have some discoloration from being exposed to moisture, but I have several extras.
Puebloswatcop
post Jan 15 2022, 08:14 AM
Post #310
The housing and inner race show no signs of heat damage and are in remarkably good shape, probably because the car had not been used all the years after the engine fire....But I don't know exactly when that happened. Change found in the car was from the early 80's, so I am guessing somewhere around that time.
Puebloswatcop
post Jan 15 2022, 08:17 AM
Post #311
I also chased the mounting threads on all of the stub axles I have. A couple of them have some minor thread damage on the end threads of the stubs, so I will order a die and clean those up as well.
And with the preliminary inspection done, all these can go into the soaker for the day.
Puebloswatcop
post Jan 15 2022, 08:24 AM
Post #312
Finally, all of the axle parts arrived from Autohaus Arizona, so I can start rebuilding the axles that will actually go back into this car. All new boots, gaskets, and the retaining clips. I always replace the clips with new ones, cheap insurance that the joints will stay on the axle shafts.
Puebloswatcop
post Jan 15 2022, 08:31 AM
Post #313
And then a short time later my seat hinge brackets arrived from R.D. They are very nice reproductions of the originals..
I have already marked these where the hinge will be located.
Puebloswatcop
post Jan 15 2022, 08:36 AM
Post #314
And of course I couldn't wait to weld the hinges on. I forgot that I had welded some thicker steel the other day, so I bet you can tell which one got welded before I re-adjusted the wire feed....not the most beautiful welds....but surely functional.
Puebloswatcop
post Jan 21 2022, 06:36 PM
Post #315
Has been a bit of a crazy week. Son came down with COVID so kinda had to put things on the Porsche on hold. He got better and came up negative today...yeah. So I did get a small thing done today. Finished installing the driver's side seat brackets. I really do like this new welder. That and more practice are getting me back into the hang of things.
I spaced the welds 1 inch apart and skipped where the lower ribs in the floor were. It definitly is solid.
Puebloswatcop
post Jan 21 2022, 06:40 PM
Post #316
The welds are so much smoother and cleaner.
Puebloswatcop
post Jan 21 2022, 06:42 PM
Post #317
Smothed out the inner welds, but think I'll skip doing that to the outer weld since reaching them is harder and I don't want to chance grinding away too much material.
Puebloswatcop
post Jan 21 2022, 06:44 PM
Post #318
I am hoping to start setting up for blasting the underside of the body next week. So trying to figure out how to tent the car so my garage isn't full of media after blasting it.
Any Ideas?
Puebloswatcop
post Feb 5 2022, 09:10 AM
Post #319
So I just returned from a short trip to Colorado, Sorry Texas, I seemed to have brought the cold weather and snow back with me....
Puebloswatcop
post Feb 5 2022, 09:19 AM
Post #320
While in Colorado I decided to box up a small box of parts to send back to Texas, I specifically needed the passenger side seat slider so i could finsh installing the seat brackets. Figured I might as well send some other things along with it.
Won't do that again...$53 dollars to send them back. That would have gotten me a partial drive to load a whole truck of parts, but oh well.
29 User(s) are reading this topic (29 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 25th November 2024 - 06:26 AM
