51 Pages V « < 31 32 33 34 35 > »
> First of the Texas Twins, First Build
CCE
post Jun 27 2022, 04:15 PM
Post #641
CCE
That is an epic Build! Thanks for sharing
Puebloswatcop
post Jun 28 2022, 07:16 PM
Post #642
So over the past several days between company and working not allot has been done, however I received some goodies via UPS thanks to Finishing and plating services in Wisconsin.
To start with I got my rear brake calipers back....All plated and ready for re-assembly.
Before and After
Puebloswatcop
post Jun 28 2022, 07:18 PM
Post #643
Miscellaneous clear hardware from things such as the suspension consoles
Puebloswatcop
post Jun 28 2022, 07:24 PM
Post #644
Misc parts, emergency brake parts, Brake parts, pedal cluster parts and the engine lid latch
Puebloswatcop
post Jun 28 2022, 07:25 PM
Post #645
Misc specialized hardware
Puebloswatcop
post Jun 28 2022, 07:28 PM
Post #646
The black fasteners from the brake calipers
Puebloswatcop
post Jun 28 2022, 07:31 PM
Post #647
And also some seat mount hardware, FI parts, other misc clamps and brake hardware all done in clear zinc
Puebloswatcop
post Jun 28 2022, 07:48 PM
Post #648
And then to top things off I got this as well, Thanks Bob (BKrantz) for turning me on to this tool. it is the perfect tool for setting the air gap on the rear brakes
bkrantz
post Jun 28 2022, 07:50 PM
Post #649
Freshly replaced parts are inspirational. I hope you had better luck remembering to send all the parts to the plating shop than me.
bkrantz
post Jun 28 2022, 07:51 PM
Post #650
QUOTE(Puebloswatcop @ Jun 28 2022, 07:48 PM) *
Yep, that's the ideal tool. I often reach for that when I can't make up my mind about using a wrench or a socket.
Puebloswatcop
post Jun 29 2022, 07:42 AM
Post #651
QUOTE(bkrantz @ Jun 28 2022, 06:50 PM) *
Funny you say that Bob. I always send off the box just to discover I missed 1 or 2 pieces. So I just save them up for the next batch....which of course costs me more $$$$
Jamie
post Jun 29 2022, 08:18 AM
Post #652
QUOTE(Puebloswatcop @ Jun 24 2022, 06:47 PM) *
QUOTE(Literati914 @ Jun 24 2022, 04:40 PM) *
Hey Slacker (IMG:style_emoticons/default/av-943.gif) , that color is gonna be nice, good choice. One thing to think about if you haven't already.. is at the bottom horizontal seam of the firewall make sure you've got the holes drilled for the little black plastic air diverters. If I recall, they're bigger holes than just sheet-metal screw size because of the way they mount.
Yep they are already drilled. Measured those out and drilled them quit awhile back....I think they are hard to see in the pic. I was pretty excited when I was finally able to do a side by side comparison on the colors. Light green, ravenna green and the Acid green....acid green was definitely the hands down winner.....
There will be no excuse when people say they didn't see ya' coming! (IMG:style_emoticons/default/agree.gif)
Puebloswatcop
post Jun 29 2022, 07:31 PM
Post #653
So although I didn't have allot of time today I decided to at least put the E-brake handle back together. All new or replated parts. The part at the yellow pointer was listed as NLA, but a lot of checking around and I was able to find it...although I am sure I could have come up with an alternative fix.
The black arrow shows the orientation of the rod that goes inside the handle it is the only way to get the rod in. this rod is what activates the pawl that locks the brake handle in the locked position.
Puebloswatcop
post Jun 29 2022, 07:50 PM
Post #654
The spring that goes over the rod and inside the handle consists of 4 parts, the first is a flat washer, then the spring, then a collar of the same ID and OD as the washer, but about 4 times thicker, and last the button screws on to hold it all in place.
Puebloswatcop
post Jun 29 2022, 07:53 PM
Post #655
Next you move down to where the pawl has to be installed. You have to push the button to alighn the rod with where the pawl installs. then slide in the pawl with the teeth facing the base of the housing and line up the hole to install the retaining pin.
Puebloswatcop
post Jun 29 2022, 07:57 PM
Post #656
Then you slide the ratchet portion into the base of the housing, push the button to pull the pawl away from the ratchet and push the ratchet up inside.
Puebloswatcop
post Jun 29 2022, 08:00 PM
Post #657
Last thing for the e-brake handle assembly is sliding the actual handle in place. I have heard that on some you have to heat them up to get them on. Mine is an actual Porsche part and it slides right on, in fact I will have to glue it in place.
Puebloswatcop
post Jun 29 2022, 08:06 PM
Post #658
I also installed the cable that runs to the e-bake handle as well as the bushing that goes inside the e-brake handle and the mount post in the car. The bushig fits very tightly inside the handle base, so I very gently hammered into the base with a plastic mallet.
And with that the assembly is complete.
Puebloswatcop
post Jul 1 2022, 06:28 PM
Post #659
This weekend is going to be spent on body work. So today I started on the passenger side flares. First was to fill over the top of the joint line.
Puebloswatcop
post Jul 1 2022, 06:29 PM
Post #660
First coat of filler on the rear fender
- Lo-Fi Version Time is now: 25th November 2024 - 06:18 PM
