51 Pages V « < 32 33 34 35 36 > »
> First of the Texas Twins, First Build
Puebloswatcop
post Jul 1 2022, 06:34 PM
Post #661
After sanding out the first coat, I found I still had some pretty deep low spots in the seam, so I put on a second coat. I am using Evercoat Rage Optex filler.. It nice because it starts out pink and then as it hardens turns a green color. Not that I am in a hurry to start sanding, but it lets me know when its ready....
Puebloswatcop
post Jul 1 2022, 06:35 PM
Post #662
After about 10 minutes...
Puebloswatcop
post Jul 1 2022, 06:41 PM
Post #663
First coat of filler on the front fender....starting to take shape.
Puebloswatcop
post Jul 1 2022, 07:07 PM
Post #664
After the initial sanding of the second coat on the rear fender, I am much happier with the contour....
9146C
post Jul 2 2022, 06:03 AM
Post #665
Looks really good Kevin! I remember this part caused me a lot of frustration to try to get it right. I recall it wasn't until after the 3rd coat of primer that I was happy with it. Not trying to discourage you...it's all about patience.
One thing that worked well for me...on the contour areas, I hand-sanded using sandpaper wrapped around a foot long section of 2" PVC. While sanding, I just rotated the PVC "block" to the contour.
The other key for me...maybe I'm just getting old and my eyes aren't what they used to be...rolling my car into natural light (outdoors) helped to easily see imperfections after I thought I was "done" (with single color primer applied for visual contrast).
When you pay a bodyshop to do this, remember the difference between a quality job and a "Maaco job" is the time spent in prep.
Keep up the good work...it's coming together nicely!
Puebloswatcop
post Jul 2 2022, 06:32 AM
Post #666
QUOTE(9146C @ Jul 2 2022, 05:03 AM) *
Thanks Rob, Not discouraging at all. In fact encouraging. I never liked doing bodywork before but I am actually enjoying it at this point. I knew this part was going to be the most challenging, blending in the flares, but I feel I am up to the challenge and am learning allot along the way. I'm certainly going for the quality and have plenty of time. When I get frustrated I just stop, have a beer and then move along....I love retirement....lol
Puebloswatcop
post Jul 2 2022, 04:56 PM
Post #667
Today I decided to concentrate on the right rear fender...I started off by identifying the more obvious low spots and sanding off any old existing paint. Some of the paint was original but some was very chalky looking and I think it had been painted later in its life with very cheap paint, so all traces of green had to go.
Puebloswatcop
post Jul 2 2022, 04:59 PM
Post #668
That included all traces of green from the door handle area, what a PIA. All had to be done by hand because of the tight confines, so about an hour of sanding....
Puebloswatcop
post Jul 2 2022, 05:00 PM
Post #669
The entire rear panel was stripped down to bare metal or good solid primer...
Puebloswatcop
post Jul 2 2022, 05:04 PM
Post #670
I addressed the obvious low spots and did a thin fill coat of body filler to those areas as well as building the contour of the flares.
Puebloswatcop
post Jul 2 2022, 05:06 PM
Post #671
Then sanded this until the dings, dents and contours were to my liking....
Tomorrow it will be on to a complete skim coat of the fender.....
914Sixer
post Jul 2 2022, 06:14 PM
Post #672
Looking good (IMG:style_emoticons/default/popcorn[1].gif)
oldie914
post Jul 3 2022, 12:12 AM
Post #673
Work looks good but I recommend you drape a couple of painter drop cloths over the boxes stored against the wall. Will save you a lot of dust clean up later.
Puebloswatcop
post Jul 3 2022, 06:43 PM
Post #674
Today the goal was to get the rear fender skimmed out and sanded. An early start made it fairly comfortable, before the heat hit.
I got the skim coat on and then started sanding....
Puebloswatcop
post Jul 3 2022, 06:47 PM
Post #675
Still some sanding left to do, but the wife reminded me it was laundry day and our dryer vents into the garage...crap. Oh well, I am happy with the progress and just decided to go inside and do a few other things that need doing.
Puebloswatcop
post Jul 3 2022, 06:51 PM
Post #676
So since I can't work in the garage I moved to the kitchen table....I am lucky that my wife lets me work there as long as I cover the table and I am working on new / clean parts. So rear brakes were on the agenda.
Puebloswatcop
post Jul 3 2022, 06:53 PM
Post #677
I started by laing out all of the hard parts, and then layed out the parts from the rebuild kit from PMB Brakes....
Puebloswatcop
post Jul 3 2022, 07:04 PM
Post #678
Once I confirmed I had all of my parts it was time for the build process. Now, this isn't my first brake re-build, but it has been awhile. So I reviewed the most awesome rear brake rebuild video on You Tube, again posted by Eric Shea at PMB Brakes, https://www.youtube.com/watch?v=dm_DnizKOZM , If you have never done a brake build but want to give it a shot, or just need to refresh your skills I highly recommend this video.
One thing to note is all of the internal parts do need to be lubricated, so I use Permatex ceramic extreme brake parts lube for all the internals.
Puebloswatcop
post Jul 3 2022, 07:07 PM
Post #679
Since the e-brake arms and caliper bodies had all been re-plated I checked to insure the fit was good with no binding...It was perfect, so I lubed up the e-brake arm and installed it.
Puebloswatcop
post Jul 3 2022, 07:11 PM
Post #680
Then I had to install the retaining ring for the e-brake arm. I tried pushing it in but it kept giving me problems. Then I remembered I had a special pair of ring pliers that are actually for installing the ring on the snout of the crank....but hey... a ring is a ring...just much smaller. They worked like a charm.
- Lo-Fi Version Time is now: 25th November 2024 - 06:43 PM
