51 Pages V « < 36 37 38 39 40 > »
> First of the Texas Twins, First Build
Puebloswatcop
post Jul 30 2022, 05:06 PM
Post #741
So it was a matter of removing the damaged brush from the bore. On one side of the bore there is an opening that you can look at to see the brush. Using a fine pick and a jewelers screwdriver I was able to carefully pick out the remnants of the brush. Then using a fine pointed jewelers file i cleaned up the bore to make sure nothing remained. Then I took the motor to my local hardware store and found the appropriate sized carbon brush. Fit is very important, too loose and the brush wears quickly, to snug in the bore and it doesnt make contact with the stator in the motor and the motor doesn't work.
Since the lead will be soldered to the attachment point and this brush comes with a disc and spring (wich is not the right size) I just snipped off the disc and discarded the spring.
Puebloswatcop
post Jul 30 2022, 05:10 PM
Post #742
I then seated the brush into the bore and soldered the new lead in place...note that the old lead is still there. I wasn't sure if the new lead was long enough at first so I kept the old lead in place in case I needed to solder them together.....After confirming there was plenty of lead wire, I just cut the old one off.
Sorryfor the quality of the pictures, not able to use my phone so am trying to use a spare to take the pics.
Puebloswatcop
post Jul 30 2022, 05:15 PM
Post #743
After repairing the damaged brush I put the original springs and retainers back on. Then hooked it up to my car battery and (IMG:style_emoticons/default/piratenanner.gif) SUCCESS.....
So I cleaned up the rest of the motor casing and reinstalled it into the cage.
Puebloswatcop
post Jul 30 2022, 05:21 PM
Post #744
Then turned to the fan itself... during my examination of the fan I found several areas where the ring had fractured away from the fins...out of 17 fins, 7 were cracked at the ring joint. I marked each one of them with a black dot and the one by one repaired them with JB plastic weld. Worked fantastic. I noticed that there were several metal clips attached at random to the fins. I am guessing these were used to balance the fan, so left them in place.
Puebloswatcop
post Jul 30 2022, 05:23 PM
Post #745
Then I re-mounted the fan to the motor. Looks like it might actually blow fresh air now. Have to wait on complete re-assembly until the seals I ordered from 914 Rubber arrive.
Puebloswatcop
post Aug 3 2022, 07:43 PM
Post #746
The seals cor the fresh air intake box came in today, minus the two flapper seals. One quick call to 914 Rubber and the shortage was solved and the seals sent. In the mean time I installed the fan seal and the box seal. The fit on both was spot on.....
Puebloswatcop
post Aug 3 2022, 07:46 PM
Post #747
Then I went ahead with cleaning the flapper assemblies. They were much worse than I thought.
Puebloswatcop
post Aug 3 2022, 07:48 PM
Post #748
On the up side, when you take them apart, the inside surfaces are pretty clean....however These will make the next trip to the plater......
Puebloswatcop
post Aug 3 2022, 07:56 PM
Post #749
So I blasted them and they are ready to go.
Puebloswatcop
post Aug 3 2022, 07:57 PM
Post #750
But to make the package to the plater worth while I decided I had better blast a bunch more to go with the flappers.
Puebloswatcop
post Aug 8 2022, 08:12 AM
Post #751
Since bringing out the 2nd 914 has now overwelmed my garage space I have been working to re-organize my space. So in the meentime I am working on small projects to keep things moving forward. I haven't decided on any engine upgrades yet, but figured I would clean and rebuild the distributor. I will either use it or if I upgrade, I will sell it.
Puebloswatcop
post Aug 8 2022, 08:19 AM
Post #752
While the distributor looks like hell, it is actually in pretty good shape mechanically. The nut on the hold down bracket is frozen in place though, so I soaked it and all the other little screws with some PB Blaster.
While waiting for that to soak in I removed the vacuum canister. Tested it and both sides hold vacuum....The removed the trigger points for the EFI.
Puebloswatcop
post Aug 8 2022, 08:31 AM
Post #753
The inside of the distributor is dirty with a combination of old lube, dirt and some minor rust. After removing the breaker points I removed the mounting/advance plate as well. (sorry for the poor pic quality)
Puebloswatcop
post Aug 8 2022, 08:39 AM
Post #754
As you can see, the centrifugal weights are pretty dirty and have a fair amount of rust as well. To facilitate their cleaning I will have to remove the shaft from the housing.
Puebloswatcop
post Aug 8 2022, 08:43 AM
Post #755
In order to remove the shaft the retaining spring must be removed in order to access the retaining pin. I just used a pick tool to walk the spring out og the groove.
Puebloswatcop
post Aug 8 2022, 08:46 AM
Post #756
After carefully driving out the retaining pin, the distributor drive easily slides (falls) off of the shaft and the shaft can be pulled out of the distributor. That leaves only the lubricating block for the trigger points in the bottom of the housing.
Puebloswatcop
post Aug 8 2022, 08:51 AM
Post #757
Once dis-assembly is complete, it leaves you with a mess of dirty parts and sub components, waiting to be cleaned and checked....
Puebloswatcop
post Aug 8 2022, 09:04 AM
Post #758
So starting with the distributor body the cleaning began. After about a half hour of scrubbing, brushing and polishing it was at least clean....inside and out.
Puebloswatcop
post Aug 8 2022, 09:08 AM
Post #759
Then on to the points mount /vaccum advance plate. It can be further broken down by removing the tension mount that holds the small bearing onto the top of the plate.
Puebloswatcop
post Aug 8 2022, 09:19 AM
Post #760
The two plates can be separated for cleaning and re-lubing. Be careful not to pull the grounding wire off of either plate. The ring on each plate act as a bearing surface and need to be lubed.
- Lo-Fi Version Time is now: 25th November 2024 - 07:48 PM
