51 Pages V « < 3 4 5 6 7 > »
> First of the Texas Twins, First Build
Puebloswatcop
post Nov 1 2021, 08:52 AM
Post #81
The next thing I unboxed was the climate controls. Years of grime and dirt and dried grease. Overall it was in pretty good shape though.
Puebloswatcop
post Nov 1 2021, 08:56 AM
Post #82
One thing I did find is that it appears there is a piece missing from the upper slide control. There are 3 detents on the top of the unit and what looks like two mounting holes on the slide, which lead me to believe that there should be something that slides into these detents, Can anyone tell my if this is the case?
Puebloswatcop
post Nov 1 2021, 08:59 AM
Post #83
So I spent about an hour dis-assembling parts of the control unit, cleaning and re-lubing all of the slides and cables. and cleaning all of the electrical contacts.
Puebloswatcop
post Nov 1 2021, 09:02 AM
Post #84
Then re-assebled the clean product. Everything seems to work much better. Still need to find out about the detent issue on the top slide and obtain parts if necessary.
Puebloswatcop
post Nov 1 2021, 09:11 AM
Post #85
Cleaned up the passenger side B pillar trim, couldn't find the driver's side, must be hiding in another box somewhere...
Puebloswatcop
post Nov 1 2021, 09:14 AM
Post #86
Then cleaned and checked the center console. Hooked the clock up to my wifes car battery and low and behold it works...yeah.
Puebloswatcop
post Nov 1 2021, 09:17 AM
Post #87
To finish up the weekend, I cleaned the entire guage cluster. To include dis-assembling the guages, cleaning inside and repainting the needles etc. Also changed all of the cluster lights to LEDs
Cornerlot
post Nov 1 2021, 10:11 AM
Post #88
Welcome to Texas. I had to look up Mineola, wasn't familiar with it. We retired and moved here from Michigan last December, now down in New Braunfels. Lovin' it!
Puebloswatcop
post Nov 1 2021, 02:02 PM
Post #89
QUOTE(Cornerlot @ Nov 1 2021, 09:11 AM) *
Thanks Steve, wish we were closer.
Puebloswatcop
post Nov 3 2021, 03:23 PM
Post #90
Since today was a rainy and cold I decided to lift the car onto the rotisserie. I left in on the rolling cart and started lifting first at one end then the other, 5 inches at a time.
Puebloswatcop
post Nov 3 2021, 03:25 PM
Post #91
Only had 20 inches to get it onto the mounts
Puebloswatcop
post Nov 3 2021, 03:27 PM
Post #92
Then after getting it onto the rotisserie had to remove all of the lifting block materials and the rolling cart
Puebloswatcop
post Nov 3 2021, 03:30 PM
Post #93
And some 5 hours after starting, Its finally on the rotisserie, a day I wasn't sure I'd ever see. (IMG:style_emoticons/default/piratenanner.gif)
Literati914
post Nov 3 2021, 04:38 PM
Post #94
I feel ya on this.. I did kinda the same song and dance, raising the car a little at a time until it was in place. Took more effort than I expected. I may add a lifting/lowering mechanism of some type, would probably be easy enough.
bkrantz
post Nov 3 2021, 07:18 PM
Post #95
QUOTE(Puebloswatcop @ Nov 3 2021, 03:30 PM) *
Now you can look forward to the day it comes off! Mine was on the rotisserie 6 months.
Puebloswatcop
post Nov 4 2021, 07:43 AM
Post #96
QUOTE(bkrantz @ Nov 3 2021, 06:18 PM) *
Yes Bob, I was already out there planning new work strategy. I think I need to go get a white board like you used, that will help keep me on track.
Puebloswatcop
post Nov 4 2021, 04:38 PM
Post #97
QUOTE(Literati914 @ Nov 3 2021, 03:38 PM) *
Wouldnt have been so bad, but it was raining outside so I couldnt back the Hot Rod out of the garage....wife told me if my car touched that hot rod I was a dead man...lol...kinda wanted to live to work on my car....
Yeah I think I will try to find a different way of raising it when I do the second twin. Maybe a maintenance lift or something....
Puebloswatcop
post Nov 4 2021, 04:41 PM
Post #98
So today was spent stripping the undercoating from the car. I had started doing that in Colorado, but will be much happier now that I dont have to lay underneath it to get the job done.
Puebloswatcop
post Nov 4 2021, 04:44 PM
Post #99
At least some of it was already done, but there are places where it is about a quater of an inch thick
Puebloswatcop
post Nov 4 2021, 04:47 PM
Post #100
The good thing is the engine compartment is pretty much scrapped clean where it had undercoating. Does anyone have any pointers though on removing the glue that was used to hold in the pad on the firewall?
- Lo-Fi Version Time is now: 4th April 2025 - 12:16 AM
