Rear Main Engine Seal NEEDED, New Clutch and Flywheel Replacement- need beefier seal |
Str1974 |
Oct 20 2021, 10:40 PM
Member Group: Members Posts: 90 Joined: 23-January 19 From: Dallas Member No.: 22,820 Region Association: Southwest Region |
I'm in the process of replacing my clutch while my engine is out. I have studied the procedure somewhat, but have never done it on my 914. I see mention of a thicker seal compared to a less beefy stock. When trying to order the rear main seal from various vendors, it only lists one type of seal (ie. erhling,sabo etc.). None of the available seals mention their thickness. All seem to list the rear main seal as part# 029105245B. And that part number seems to fit various vehicles, Bus , Type 4 VW and 914. Does anyone know where I can purchase the beefier main seal and what is the correct thickness? Is the beefier one a different part# ? Any help would be greatly appreciated, THX
jcd914 |
Oct 20 2021, 11:10 PM
I have no recent experience with rear main seals but here is a link to an article that discusses them.
Gowesty Main Seal Article Jim |
914sgofast2 |
Oct 20 2021, 11:23 PM
Senior Member Group: Members Posts: 613 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Over on the Bay Window Forum at the Samba.com they tend to claim that the only good rear main seals are the all black ones made by Sabo.
iankarr |
Oct 20 2021, 11:33 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hey there. You can see it in my video at about 11:20..
https://youtu.be/pETd03F1Os4 Sabo 029-105-245 I believe Pelican carries these now. I used the Ehlring on my green car and no leaks yet! I think the main thing is that the bore is smooth and clean and that the seal fits as it should. Also don't forget to put some oil on the inside lip so the seal doesn't fail on startup. |
euro911 |
Oct 21 2021, 01:30 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I tend to like the Victor Reinz brand. Had leaks with the Elrings (IMG:style_emoticons/default/dry.gif)
Str1974 |
Oct 21 2021, 11:40 AM
Hey there. You can see it in my video at about 11:20.. https://youtu.be/pETd03F1Os4 Sabo 029-105-245 I believe Pelican carries these now. I used the Ehlring on my green car and no leaks yet! I think the main thing is that the bore is smooth and clean and that the seal fits as it should. Also don't forget to put some oil on the inside lip so the seal doesn't fail on startup. Ian, thanks for the reply. I have watched your video many times to get the nerve to do it myself (great video)! In your video you mention that you put in the "10mm" seal, but wished you had ordered the "12mm" seal. That's where I came into trouble. I checked the 029-105-245 part number and it always comes up that it is the rear main seal, but does not distinguish between if it is a 10mm or a 12mm. Gowesty also mentions the various seals but never shows if its 10mm or 12mm. Is there a way to distinguish between the 10 or 12mm by part number or exclusive brand? Mark |
Str1974 |
Oct 21 2021, 11:41 AM
I have no recent experience with rear main seals but here is a link to an article that discusses them. Gowesty Main Seal Article Jim thanks, will look at it. |
mmichalik |
Oct 21 2021, 11:54 AM
MikeM Group: Members Posts: 689 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I ordered this seal from Gowesty for my '75: 029-105-245: Flywheel / Flexplate Seal (Rear Main) when I read that the smaller seals didn't always provide the best fit. I wish I could remember who, on this board, made that recommendation to me.
Definitely larger than the Victor Rienz seal that came with the clutch kit. |
Str1974 |
Oct 21 2021, 12:18 PM
I ordered this seal from Gowesty for my '75: 029-105-245: Flywheel / Flexplate Seal (Rear Main) when I read that the smaller seals didn't always provide the best fit. I wish I could remember who, on this board, made that recommendation to me. Definitely larger than the Victor Rienz seal that came with the clutch kit. Yes, it looks like that one is the best bet. Per the Gowesty article, the old style German made Sabo seal was best, but now made in Brazil (not as good, bad mold). So they ended up recommending only the Erling one, over the Victor Reinz. |
iankarr |
Oct 21 2021, 02:20 PM
The Sabo /gowesty one is deeper than the elring. I think you're watching my clutch replacement video, which shows the elring with the (appropriately) rust colored ring. That's where I say I didn't have time to order the beefier one. In the link I posted above, from my 2056 build, you can see the sabo. I didn't mesure it, but I beileive it is 12mm. It's certainly beefier than the elring.
Glad you found the videos helpful! |
Str1974 |
Oct 21 2021, 08:01 PM
The Sabo /gowesty one is deeper than the elring. I think you're watching my clutch replacement video, which shows the elring with the (appropriately) rust colored ring. That's where I say I didn't have time to order the beefier one. In the link I posted above, from my 2056 build, you can see the sabo. I didn't mesure it, but I beileive it is 12mm. It's certainly beefier than the elring. Glad you found the videos helpful! Thanks. I was afraid that the Sabo was the one that was the 12mm one. Gowesty has sold all their German made Sabo seals. They aren't selling the new ones that are made in Brazil because of the mold that they are using has caused failures down the road. The only ones they sell nowadays is the Elring one. |
Lo-Fi Version | Time is now: 25th April 2024 - 09:47 PM |
