@#$%ing Dimmer Relay Tried to Kill Me |
bbrock |
Oct 21 2021, 09:59 AM
Two weeks ago I was coming home after dark at the end of a long 250 mile round trip through SW Montana for work. [Side note: if you pull up to a Montana rancher's house in a 914, he WILL get a kick out of it.] I noticed my lights were occasionally having trouble switching between dim and bright which required a double pull on he switch, but it wasn't consistent. I made a note to myself to look into it. I then crested a fairly remote and very dark mountain pass and dimmed my lights for an oncoming car. Then as I headed down the back side at 70+ mph into a sweeper on the descent, I tugged the switch to go back to brights. Instead of brights, I got total blackness... on a pitch black night in the middle of a curve on a remote mountain pass at high speed (IMG:style_emoticons/default/yikes.gif) I hit the brakes to scrub speed while feeling for the shoulder and flicking that dimmer switch with furry. After a half dozen tugs, the brights popped on. [side question: anyone know how to clean shit out of brick weave vinyl? (IMG:style_emoticons/default/blink.gif) ] Needless to say, I was not happy.
I finally got a chance to dig into the problem and started with the relay. This is not a 50 year old part. It was purchased new from Pelican less than a year ago as part of my bare metal restoration, and has seen less than 5 hours of service. Popping the cover off quickly revealed what shit build quality these new relays are despite being rather spendy. The relay pulls a thin metal finger into a 2-part (plastic and brass) rocker mechanism with two valleys and a splitter tooth between. Each cycle of the relay is supposed to position the splitter so the finger slides into the other valley on the next cycle. But the build tolerances were crap and there was so much float in the relay plate that the metal finger didn't line up consistently with the splitters. Often it wouldn't switch positions and sometimes it would miss the brass part of the splitter completely and get hung up on the plastic. When that happens, it's lights out! I was able to use a pair of needle nose pliers to squeeze the notches that guide the relay plate closed a little more to reduce the slop in the plate travel, and bend the tang holding the metal finger so it consistently engaged the brass splitter. After that, I was able to reliably cycle between bright and dim with no blackouts. The only question I have is if there are new replacements that are good quality and reliable. I think I paid $40 for this one and it tried to kill me. Most importantly, I wanted to warn people to beware of faulty dimmers. A jinky dimmer relay can go from just annoying to potentially deadly very fast! |
Oct 21 2021, 10:10 AM
Resident German Group: Admin Posts: 41,609 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
tygaboy |
Oct 21 2021, 10:19 AM
914 Guru Group: Members Posts: 5,279 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Holy moly. That is some scary stuff. Words fail to begin to cover how relieved we are to hear nothing bad happened.
914Sixer |
Oct 21 2021, 10:37 AM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I know exactly what you are talking about, I had a new 1973 911 Targa that had the switch go South. I was cruising about 85 on the Texas High Plains near Lubbock and dipped to low beam for on coming traffic, when the "Oh shit" moment hit. The full moon saved my ass after my eyes adjusted.
76-914 |
Oct 21 2021, 11:12 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Note to Chinese Manufacturer's: Just because you can doesn't mean you should. Which brings this question to mind. If that faulty relay caused a fatality who would be blamed, aka sued? Pelican or an overseas manufacturer? ps, I have an extra seat bottom if you need a replacement! (IMG:style_emoticons/default/happy11.gif)
Oct 21 2021, 11:27 AM
914-6 GT in waiting Group: Members Posts: 19,247 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Do you have led bulbs. With the good ones, you won’t even need your high beams.
trick-e |
Oct 21 2021, 11:28 AM
Still Learning Group: Members Posts: 111 Joined: 7-July 12 From: Traverse City, MI USA Member No.: 14,644 Region Association: Upper MidWest |
…or the company that sent the inferior specs to the manufacturer.
Justinp71 |
Oct 21 2021, 11:29 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Scary, glad you're ok. I have the same issue with my hi/low relay. It's never gone dark on me the though. I also would like to get a new higher quality one. |
bbrock |
Oct 21 2021, 01:38 PM
Do you have led bulbs. With the good ones, you won’t even need your high beams. I do. I think they are the same ones that you use - Truck Lites. They are great, but with the critters we have running around here, you want all the light you can get driving at night. |
ClayPerrine |
Oct 21 2021, 02:13 PM
Life's been good to me so far..... Group: Admin Posts: 15,423 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Brent,
How much basketweave cloth have you (IMG:style_emoticons/default/stromberg.gif) since then? (IMG:style_emoticons/default/lol-2.gif) Glad you and your car aren't hurt. FYI.. sometimes new is not better. You might consider getting an used OEM relay from an old harness. The relay in Betty's 914 is the original 50 year old one and it is still working. It's going back in the car when I put it back together. Clay |
burton73 |
Oct 21 2021, 03:07 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Brent buddy,
Thank the lord that you are OK. Lights, my kingdom for lights. Best Bob B |
EdwardBlume |
Oct 21 2021, 03:22 PM
Brent buddy, Thank the lord that you are OK. Lights, my kingdom for lights. Best Bob B (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
Dion |
Oct 21 2021, 04:04 PM
RN Group: Members Posts: 2,764 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Bloody hell Brent! Glad you are ok.
Have to concur with Clay. Find another “original” one . Most likely better in the quality area. (IMG:style_emoticons/default/idea.gif) |
Oct 21 2021, 04:33 PM
Do you have led bulbs. With the good ones, you won’t even need your high beams. I do. I think they are the same ones that you use - Truck Lites. They are great, but with the critters we have running around here, you want all the light you can get driving at night. Yea, I do like the truck lites. |
bbrock |
Oct 21 2021, 04:53 PM
I think I still have the original relay somewhere around here. I'll see if I can clean it up. It looked a bit crusty so I figured I'd play it safe and replace with new. That didn't go so well.
I'm actually fairly confident this new one will be reliable after I tuned it up. It doesn't wobble all over the place anymore. |
ClayPerrine |
Oct 22 2021, 09:34 AM
Another thought.....
Make sure you can turn your fog lights on separate from the headlights. If the relay fails again, just turn the fog lights on. They may not be the best lights for the situation, but they are better than nothing. |
MM1 |
Oct 22 2021, 12:58 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
Glad you made it through that dark curve, Brent - good thing, though, is that you just made my Top 20 Pucker Story List.
Please accept my remote-vid prize: (IMG:style_emoticons/default/smilie_pokal.gif) |
bbrock |
Oct 22 2021, 01:21 PM
Another thought..... Make sure you can turn your fog lights on separate from the headlights. If the relay fails again, just turn the fog lights on. They may not be the best lights for the situation, but they are better than nothing. Good thought. My 2L is a little unusual in not having appearance group so no fog lights. I've waffled between adding them and staying original. This is more food for thought. No question they would have made a world of difference in those few seconds. Glad you made it through that dark curve, Brent - good thing, though, is that you just made my Top 20 Pucker Story List. Please accept my remote-vid prize: (IMG:style_emoticons/default/smilie_pokal.gif) Thanks! This makes it all worth it. Ever since I was a little girl of dreamed of one day winning the Pucker Award. I have so many people to thank.... (IMG:style_emoticons/default/lol-2.gif) |
Arno914 |
Oct 22 2021, 02:35 PM
Member Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany |
After more than 100 entries in your restauration project thread (which I read with great interest btw.) your guardian angel decided that you really deserve to keep this beautiful 914 forever! Thankfully everything turned out ok for you!
I have a good longtime friend who works for a big german automotive supplier. He also drives a 87 Carrera and is a real Porsche guy. His main work is examining car parts that have failed out in the field on contemporary vehicles. I am not going into details here, but he always tells us: "Keep your old original stuff as long as you can, even rework if possible." There is a lot of real cheap crap out there, even in cars with a star on the hood. Cost reduction is everything. For example, take a look at your old cylinder head temperature sensor (strong cable, good insulation and wear protection) and then look at the new ones they sell nowadays. I would trust the old one more on a cold, dark and rainy drive home. Drive careful (IMG:style_emoticons/default/driving.gif) |
emerygt350 |
Oct 22 2021, 07:42 PM
Advanced Member Group: Members Posts: 2,081 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I have the original lights, I like the warm hues. My high beams still work, but nobody can tell. Therefore, I don't have to stress the relay by switching them on and off with traffic. Problem solved.
Lo-Fi Version | Time is now: 1st May 2024 - 03:43 PM |
