BIGKAT_83 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States ![]() ![]() ![]() |
Tom............Now that you have been driving the car for a few weeks how does it compare with the rotary that was in the car??
Looks good can't wait to see it in black. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
lybones |
Member ![]() ![]() Group: Members Posts: 159 Joined: 26-April 05 From: Garden Grove, CA Member No.: 3,986 ![]() |
Tom............Now that you have been driving the car for a few weeks how does it compare with the rotary that was in the car?? Looks good can't wait to see it in black. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) That's funny you asked. I've been getting a lot on this subject. My turbo rotory setup seems a lot faster untill I got the v8 motor dialed in. The turbo 13b-rew was pushing about 350+ horses. The v8 on the other hand has no turbo lag so they both have there plusses. I love the throttle response of the v8 at ANY rpm range, but I loved the smooth gut wrenching pull of the turbo rotory once it got on boost pulling all the way to 12,000 rpms. Fuel comsumption are also quite similar. I just saw my brother inlaw's 3rd gen rx7 project yesterday. It has a 20b motor (3rotor) with a single t-04 turbo setup. Man, the 650 horses sounds so sweet. |
lybones |
A coolant hose popped off while on the freeway last night and I had to tow the car home. (IMG:style_emoticons/default/headbang.gif) Today I filled the whole system with distilled water and a bottle of "hyper lube" water wetter with anti corrosion. This stuff dropped the temp down 5 degrees to 180! I'm making sure all the clamps are on TIGHT this time.
914-8 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None ![]() |
Hey Tom, you still around?
Any progress on the car? |
drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
A coolant hose popped off while on the freeway last night and I had to tow the car home. (IMG:style_emoticons/default/headbang.gif) Today I filled the whole system with distilled water and a bottle of "hyper lube" water wetter with anti corrosion. This stuff dropped the temp down 5 degrees to 180! I'm making sure all the clamps are on TIGHT this time. Sorry to here that, I have had 3 tows, one when I broke my transmission mounts, 2 when I bent the water pump impellers, 3 when my throw out barring tangs snapped off. No fun! (IMG:style_emoticons/default/dead horse.gif) I went through things like that, I didn't blow any hoses off but did bend up a water pump impeller. I decided to go with no thermostat and use a re-stricter along with aluminum peaces to cover the radiator. This way I can keep it around 180 and let the fans cool it down. In Ca. now I have to cover over 1/2 the radiator to keep it around 175 to 190. I am going to install a electric bypass soon to regulate the temp. If I didn't have the radiator covered it would run below 150 on the freeway. |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Tom, your double clamping all the hoses.. right?
if not. DO IT. |
lybones |
A coolant hose popped off while on the freeway last night and I had to tow the car home. (IMG:style_emoticons/default/headbang.gif) Today I filled the whole system with distilled water and a bottle of "hyper lube" water wetter with anti corrosion. This stuff dropped the temp down 5 degrees to 180! I'm making sure all the clamps are on TIGHT this time. Sorry to here that, I have had 3 tows, one when I broke my transmission mounts, 2 when I bent the water pump impellers, 3 when my throw out barring tangs snapped off. No fun! (IMG:style_emoticons/default/dead horse.gif) I went through things like that, I didn't blow any hoses off but did bend up a water pump impeller. I decided to go with no thermostat and use a re-stricter along with aluminum peaces to cover the radiator. This way I can keep it around 180 and let the fans cool it down. In Ca. now I have to cover over 1/2 the radiator to keep it around 175 to 190. I am going to install a electric bypass soon to regulate the temp. If I didn't have the radiator covered it would run below 150 on the freeway. Wow!, 150 degrees is really cool, even on the freeway. Where are you reading your coolant temp at? |
lybones |
wbergtho |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 ![]() |
That looks like the A.I.R. rear deck lid w/ integrated spoiler???
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
With the top off can you see out of the tinted back window?
lybones |
QUOTE That looks like the A.I.R. rear deck lid w/ integrated spoiler??? The rear deck is one piece FG lid purchased from Rennspd.com With the top off can you see out of the tinted back window? It is a little hard to see out the back with the top off, but you can just stand up and turn your head. (IMG:style_emoticons/default/laugh.gif) |
ernestj911@gmail.com |
Newbie ![]() Group: Members Posts: 24 Joined: 20-July 06 Member No.: 6,472 ![]() |
Tom
Your v8 has turned out great. Do you have any more pics or videos to post? Give us an update! |
JB 914 |
Daddy! Finish my car NOW!!! ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 ![]() |
<!-- quoteo(post=828353:date=Dec 2 2006, 09:51 PM:name=JB 914) --><div class='quotetop'>QUOTE(JB 914 @ Dec 2 2006, 09:51 PM) ![]() Tom, your project is looking great. i'd be interested in talking to you about how you did the exaust. i've got to dump my current exaust since it's a 1/2 assed job and it won't work with the ceramic headers. whatever info you can provide would be appreciated. <!-- QuoteEnd --></div><!-- QuoteEEnd --> Thanks for the kudos! Do you have a pic of your headers? If they are hugger style headers, I can sell you my 2 1/2 inch mid pipes and you can just weld up some 2 1/2 " mufflers to them. I have 3" mufflers in the rears but I think 2 1/2" mufflers would sound better. Or I can just take a full pic of my exhaust system for you to see if you plan on welding one up yourself. Let me know either way. Tom, you still got the mid pipes? i had to go with headman hugger style headers. maybe i can come by some time? assuming you still have them. |
lybones |
She's Back!, finally. Ended up going with a 4 stage PPG chrome yellow with Orange pearl over white base coat. (IMG:style_emoticons/default/shades.gif)
(IMG:http://i228.photobucket.com/albums/ee67/lybones/My%20Toys/IMG_1276.jpg) (IMG:http://i228.photobucket.com/albums/ee67/lybones/My%20Toys/IMG_1279.jpg) (IMG:http://i228.photobucket.com/albums/ee67/lybones/My%20Toys/IMG_1280.jpg) |
jd74914 |
That is beautiful (IMG:style_emoticons/default/clap56.gif) Did you spray the paint yourself?
JB 914 |
Hey Tom looking good PM me your brothers # and address. can i come by and see it?
BIGKAT_83 |
Damn.........Looks great
Bob |
drive-ability |
Beautiful !!!
Is the rear bumper a standard 916 ? |
lybones |
Thanks folks. I had the work done by Kevin, my brother in-law at his body shop. I had the rear targa molding shaved, rear spoiler cropped, targa top smoothed down for paint, and full rubber front windshield rubber installed. There was a lot of issues with the fiberglass components that I purchased from www.rennspd.com. Never buy from this guy, Nothing I purchased from him fit properly and had the be really reworked to fit. Very poor workmanship. Over all I am quite pleased with the work Kevin did. Hey Tom looking good PM me your brothers # and address. can i come by and see it? Give me a call, joe when you are around my "hood". You are welcomed to take a look in person any time. Here's Kevins Body shop info: P.S. His shop isn't the cleanest, but the work is great. K&E auto body 3701 Tyler Ave El Monte, CA 91731 (626) 444-5575 |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
QUOTE She's Back!, finally. Ended up going with a 4 stage PPG chrome yellow with Orange pearl over white base coat. Wow. (IMG:style_emoticons/default/drooley.gif) Black, and that tone of yellow are my favorite two colors on a 914. Love the shaved targa lips - I'm doing that too. And black windshield rubber & side-window bars with all the shiny trim gone... Looks absolutely awesome! Nicely done. (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 1st July 2024 - 01:24 AM |
