27 Pages V « < 16 17 18 19 20 > »
> Another 914-6 GT Tribute Project
Tom1394racing
post May 11 2024, 05:55 AM
Post #341
Finally got my rods back from Ollies. They did a nice job balancing them so that each rod is within 1/2 gram of each other. They expedited the job with one day turn around in their shop. UPS messed up on the return shipping, so it took 10 days for the package to get to me. I installed the rods on the crank with ARP rod bolts using my micrometer to set the rod bolt stretch. Then I fit the crank in the case. I'll make up a new set of tools to hold the rods and chains up while mating the case halves. Should be ready to seal it up early next week.
Tom1394racing
post May 16 2024, 05:37 AM
Post #342
More engine build progress. Sealed up the case and installed the head studs.
Dion
post May 17 2024, 08:25 AM
Post #343
RN
The engine looks amazing. Beautiful work ! Like the rubber band mechanism, that gets it done. No flopping about. Look forward to more.
Tom1394racing
post May 17 2024, 10:44 AM
Post #344
QUOTE(Dion @ May 17 2024, 10:25 AM) *
Yeah...The rubber bands keep the rods from getting caught on the spigot bores and allow the engine to be rotated with no hang ups.
Tom1394racing
post May 17 2024, 02:28 PM
Post #345
I installed the flywheel and crank pulley today. Being new to the 914 world, I am wondering where to make the ignition timing and TDC marks. I understand that the 914-6 had the timing marks on the flywheel in line with the crank pulley as there is no visual access to the crank pulley when the engine is installed. I am guessing that I should paint a fine white line on the edge of the flywheel at the case parting line when the same mark is lined up with the case parting line at the crank. One for TDC, one for my timing mark and one each at TDC for the other cylinders to enable setting the valve lash.
Am I on the right track?
Tom1394racing
post May 18 2024, 02:07 PM
Post #346
QUOTE(Tom1394racing @ May 17 2024, 04:28 PM) *
After doing a little research on this timing topic, I concluded that I will mark the flywheel at TDC for each cylinder with a white paint marker and at my timing location with a yellow paint marker. I am hoping that the access panel in my firewall will allow me to see the crank pully and easily access the distributor, making the flywheel marking redundant.
mb911
post May 18 2024, 04:58 PM
Post #347
QUOTE(Tom1394racing @ May 18 2024, 12:07 PM) *
Ok dumb question as I have no personal experience with anything over a 2.7 engine in a 914-6 what pressure plate and transmission are you using with that flywheel? Every 6 conversion I have dealt with is a cup style flywheel and what you have would not work.
Tom1394racing
post May 19 2024, 08:23 AM
Post #348
Hi Ben
I am using a Kennedy Engineering 228 mm stage 2 clutch package. It allows conversion of the 915 9 bolt flywheel to the 901 type clutch and pressure plate.
rgalla9146
post May 19 2024, 06:05 PM
Post #349
QUOTE(Tom1394racing @ May 18 2024, 04:07 PM) *
Tom you're on the right track.
Use the pulley marks as your guide on the flywheel. I don't know if you'll have proper flat surfaces to mark with those KEP parts.
You're using a conventional dizzy ? If you adjust the timing through the access hole
in the bulkhead be very careful ! Fans/fanbelts have no mercy.
It's awkward but very convenient.
Tom1394racing
post May 20 2024, 09:10 AM
Post #350
Thanks Rory
I am using a JB Racing twin plug dizzy. I think if I mark both the flywheel and the KEP ring gear adapter, I will have something that will show up with my timing light.
Tom1394racing
post May 20 2024, 02:42 PM
Post #351
Today I did the deck height check using both the vernier at TDC and the solder method. I did the check on cylinders #1 and #4. Ollie's had supplied 0.5 mm base gaskets based on their resizing of the case. Using these gaskets, deck height as measured on the crushed solder came out at 1.2-1.3 mm. That along with my measured combustion chamber and piston dome volumes results in a 10.0:1 compression ratio. Right on target so I will move forward on the assembly.
Tom1394racing
post May 21 2024, 05:27 PM
Post #352
Pistons and cylinders went in today.
Tom1394racing
post May 28 2024, 01:23 PM
Post #353
Continuing to move forward on the engine build. Heads and cam towers are now installed, and the cams test fitted.
post May 28 2024, 02:46 PM
Post #354
914-6 GT in waiting
Looks great.
Tom1394racing
post May 28 2024, 05:53 PM
Post #355
I applied JB Weld to seal the chain rail and tensioner posts on the backside of the chain boxes. I also used the JB Weld to seal the case oil line webbing on the RHS of the case behind the oil cooler.
Tom1394racing
post Jun 1 2024, 04:22 PM
Post #356
Ready for sprocket alignment check.
Tom1394racing
post Jun 5 2024, 10:40 AM
Post #357
Here is my homemade setup for the sprocket alignment. Works well. Very accurate and repeatable. I ended up with (3) shims per side. Next up will be the cam timing.
Tom1394racing
post Jun 6 2024, 07:26 AM
Post #358
I did the cam timing yesterday. DC-60 cams with a spec of 4.8-5.2 mm at overlap. I set them at 5.25 mm.
gereed75
post Jun 6 2024, 07:49 AM
Post #359
That is some sweet work right there. Wow
mb911
post Jun 6 2024, 02:15 PM
Post #360
Looks great
- Lo-Fi Version Time is now: 19th April 2025 - 07:48 AM
