willieg |
Member ![]() ![]() Group: Members Posts: 133 Joined: 13-August 18 From: Pleasant Hill Member No.: 22,389 Region Association: Northern California ![]() ![]() |
I use a battery cutoff switch with a removable handle. I seem to always be working on some electrical upgrade/problem and it is so easy just to turn and remove the handle. At this point even those pesky electrons cooperate. I have used both types of battery cutoff switches, the type that simply disconnects the battery from ground and the type that also connects to the alternator, to try to save the alternator diodes in the event of an emergency battery disconnect. Pegasus Racing has always been my source for these.
Lo-Fi Version | Time is now: 25th June 2024 - 09:07 PM |
