1970 914/6 GT Replica Build |
eric9144 |
Apr 27 2022, 05:48 PM
Advanced Member Group: Members Posts: 2,744 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
As we say in SoCal DUUUUUUUUUUUUUUUUUUUUUDE! (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/wub.gif)
Amazing build and only 2 pages deep, holy cow (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/first.gif) |
lesorubcheek |
Apr 27 2022, 08:25 PM
Member Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States |
Thanks to the fine folks at 914 Rubber for contacting Mittlemotor about the cables: longer ones are on the way. You're right Mark, filing the bike barrels to size was easy, so now we have a bunch of spares. More progress this week: engine access cut, handbrake relocation and driver's seat rails complete, body got mud and some finish sanding, and just for fun the engine grill was dropped into place. The next 4-6 weeks will be little stuff like harness brackets, auxiliary lighting mounts and paint prep. Moving along nicely. Don't know how I've missed your posts, but glad to see them now. Absolutely amazing work! Thanks for sharing. I've seen a few references to doing the handbrake relocation but can't remember anyone showing the tube locations where the cables exit the lower firewall. Are you using the tubes for the heater flappers or were new tubes added for the center e-brake? Dan |
Apr 27 2022, 10:10 PM
Custom Member Group: Members Posts: 24,645 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Oh my….well done
LefthandRev |
Apr 29 2022, 01:37 PM
Member Group: Members Posts: 76 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
Thanks to the fine folks at 914 Rubber for contacting Mittlemotor about the cables: longer ones are on the way. You're right Mark, filing the bike barrels to size was easy, so now we have a bunch of spares. More progress this week: engine access cut, handbrake relocation and driver's seat rails complete, body got mud and some finish sanding, and just for fun the engine grill was dropped into place. The next 4-6 weeks will be little stuff like harness brackets, auxiliary lighting mounts and paint prep. Moving along nicely. Wow, I really want a bar like that for mine. |
Bullethead |
May 1 2022, 02:49 PM
Oil Cooled heart Group: Members Posts: 910 Joined: 24-June 10 From: South Florida Member No.: 11,875 Region Association: South East States |
Don't know how I've missed your posts, but glad to see them now. Absolutely amazing work! Thanks for sharing. I've seen a few references to doing the handbrake relocation but can't remember anyone showing the tube locations where the cables exit the lower firewall. Are you using the tubes for the heater flappers or were new tubes added for the center e-brake? Dan Thanks Dan, moving the handbrake was much easier than you might think, and regular 911 cables run through existing (heat flapper) tubes. At first I was unsure but since they're equal length it looks like no other mods will be needed. Update on that at assembly time. Almost forgot: remove the old e-brake tube and handle mount to the left of the driver's seat. BTW, for windshield defrost I'm using a small inline heater... no cabin heat otherwise. At least that's the plan. (IMG:style_emoticons/default/idea.gif) |
Bullethead |
Oct 2 2022, 12:53 PM
rgalla9146 |
Oct 3 2022, 03:35 AM
Advanced Member Group: Members Posts: 4,652 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Goodness gracious !
So good to see the process ......and the parts !!! WOW ! Beautiful. The 'GT' World is watching.....and growing. Great work Rory |
Dion |
Oct 3 2022, 08:25 AM
RN Group: Members Posts: 2,801 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
BillJ |
Oct 3 2022, 10:05 AM
Senior Member Group: Members Posts: 1,188 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Thanks to the fine folks at 914 Rubber for contacting Mittlemotor about the cables: longer ones are on the way. You're right Mark, filing the bike barrels to size was easy, so now we have a bunch of spares. More progress this week: engine access cut, handbrake relocation and driver's seat rails complete, body got mud and some finish sanding, and just for fun the engine grill was dropped into place. The next 4-6 weeks will be little stuff like harness brackets, auxiliary lighting mounts and paint prep. Moving along nicely. Are you planning to add a headrest? If this is display only thats fine but unless wearing a helmet or adding a headrest (or both) this is dangerous. Most any back or forward accident force will have occupants smashing skulls on the rollbars. That design is meant for a fully caged track car. |
Bullethead |
Oct 3 2022, 12:13 PM
QUOTE Are you planning to add a headrest? If this is display only thats fine but unless wearing a helmet or adding a headrest (or both) this is dangerous. Most any back or forward accident force will have occupants smashing skulls on the rollbars. That design is meant for a fully caged track car. Obviously... looking for Scheel 914 headrests now, but will have something by the time it's rolling. Will also wrap the bars. And believe it or not, the factory GTs weren't fully caged. The roll hoop plus chassis reinforcements were it... as we all know, everyone added more and more. My old car: |
BillJ |
Oct 3 2022, 06:16 PM
Ok good to hear and for sure safety took a back seat (pun intended) to speed back then.
Bullethead |
Nov 2 2022, 08:01 AM
Bullethead |
Nov 2 2022, 08:05 AM
Bullethead |
Nov 2 2022, 08:13 AM
NS914 |
Nov 2 2022, 10:02 AM
Member Group: Members Posts: 198 Joined: 9-June 09 From: Dartmouth, Nova Scotia Member No.: 10,455 Region Association: Canada |
Russ, the work is awesome and the car...well, just WOW!!!
I am doing a center mount brake set up as well. Could you possibly post some pics of what you have done to your car? I was looking at a more elevated set up but yours looks really clean. Regards, Grant |
simonjb |
Nov 2 2022, 06:21 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
wow. Just amazing. well done.
mb911 |
Nov 3 2022, 07:28 AM
914 Guru Group: Members Posts: 7,254 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
looks really nice. I see one of my oil line covers in the picture
Bullethead |
Nov 3 2022, 08:40 AM
Indeed you do, Ben... nice piece! Using your hard lines as well. (IMG:style_emoticons/default/beerchug.gif)
Grant, I'll take a few detail pics of the handbrake with dimensions. Or you can go to Armando's site for that and much more. He's devoted a huge amount of time and energy covering all the nuanced details of both factory and privateer GT builds. He's the GT guru and deserves props. https://pbase.com/9146gt/root |
Bullethead |
Dec 5 2022, 02:59 PM
Bullethead |
Dec 5 2022, 03:00 PM
Lo-Fi Version | Time is now: 25th November 2024 - 03:25 AM |
