Biggles |
Member ![]() ![]() Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England ![]() |
I think it all depends on your setup. When I had carbs with one feed line, I didn’t notice it. After installing the 3.2 with injection and return line, it was really horrible. I installed a charcoal canister in front of the battery tray, stock expansion chamber on tank and no more vapors. Thats interesting Steve. I have the same 3.2 on injection and after a while it stinks but i dont have the expansion tank and charcoal filter as i thought it was more weight i didnt need ! The seals to my tank are new and pipes are all ok so where could it be coming from? Where do you suspect it was coming from in your car? If you don’t have an expansion tank and charcoal canister, best practice is to run the tank vent under the car. The vapors still managed to get inside the car and in the garage which annoyed my wife and kids. No more vapors after installing the expansion tank and charcoal canister. With these devices installed it is a closed system. Got it. Cheers. |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,535 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
I had a bad fuel smell last year when build was done. My fuel tank setup just has the vent hose (center under fuel cap) go down to outside of car. Little later I found a leaking hose clamp on the fuel pump, fix that and the smell is gone. Again this is with 40 PMO's with fuel line in only, no return. Best, Mark
aturboman |
Member ![]() ![]() Group: Members Posts: 136 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 03:56 AM |
