Throttle Body Rebuild Service, Who has experience/recommendations? |
Van B |
Apr 11 2022, 04:24 PM
Senior Member Group: Members Posts: 1,618 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None |
So, now that my 1.8L is running happy again, I’m able to notice small issues. Today I noticed that my throttle body appears to have some wear inside it. Idle was a little high and when I pushed on the linkage arm, it returned to normal.
So, I think a full rebuild is in order. And if it happens to come out a little larger, we that wouldn’t bother me a bit. (IMG:style_emoticons/default/shades.gif) Who would you recommend to make my throttle better than new? |
JamesJ |
Apr 11 2022, 04:35 PM
Member Group: Members Posts: 229 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Phil rebuilt mine and many other members here.
pbeslins@msn.com |
Jett |
Apr 11 2022, 05:16 PM
Senior Member Group: Members Posts: 1,672 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Van B |
Apr 11 2022, 05:32 PM
brant |
Apr 11 2022, 06:10 PM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Another happy customer of Phil
There is an old thread in the member vendor for him And he is active on samba also |
Rob-O |
Apr 11 2022, 06:15 PM
Senior Member Group: Members Posts: 1,256 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
And another happy customer of Phil. They look better than new. He blasts everything, plates everything, I believe makes a new throttle plate, slightly bores the TB and makes a stop so that the throttle plate closes against the stop instead of using the inside of the bore as the throttle plate stop.
Craigers17 |
Apr 11 2022, 06:53 PM
Senior Member Group: Members Posts: 809 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Phil rebuilt mine and many other members here. pbeslins@msn.com Any other info? User name, website, etc? I saw you recommended him on a thread last Nov but I didn’t see anything from him. I think that the Msn email is the best way to get in touch with him. His username here is Whip618. The following link shows many pictures of his work. http://www.914world.com/bbs2/index.php?sho...=344988&hl= |
jim_hoyland |
Apr 12 2022, 06:55 AM
Get that VIN ? Group: Members Posts: 9,561 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Also, check the gasket at the TB !
Bartlett 914 |
Apr 12 2022, 08:02 AM
Advanced Member Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I also do Throttle body repairs. PM me if interested
Van B |
Apr 12 2022, 08:06 AM
Mark are you able to do replating now? I saw last year that you didn't have the equipment for that yet.
Bartlett 914 |
Apr 12 2022, 05:26 PM
Mark are you able to do replating now? I saw last year that you didn't have the equipment for that yet. At this time I am not repalting parts. It is cosmetic. My price reflects a savings on the rebuild. I do plan later this summer to offer all parts replated. Really it is only a couple of parts. The actuator arm and the spring. I replace the washer and nut with new parts |
Van B |
May 9 2022, 09:03 AM
914 World,
Phil is out of the Throttle Body game. I finally got a response from him today, see below: "Good morning Van, Thank you very much for your interest in my re-machined throttle bodies however as of February of this year I am no longer providing this service and I apologize for the late reply. A word of advice, some of the people offering rebuilding services are just re-bushing the worn areas where the throttle shaft passes through the main housing, this will not cure the problem, try and find a rebuilder that will install bearings and seals and provide a positive vertical locking feature for the throttle shaft. Good luck in your search for a quality rebuilder. Regards Phil" |
Craigers17 |
May 9 2022, 04:09 PM
Damn....that's too bad. He's a true craftsman whose work looked as good as it functioned. I hope he's retiring and enjoying time with his friends and family.
wonkipop |
May 9 2022, 05:17 PM
Advanced Member Group: Members Posts: 4,670 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
914 World, Phil is out of the Throttle Body game. I finally got a response from him today, see below: "Good morning Van, Thank you very much for your interest in my re-machined throttle bodies however as of February of this year I am no longer providing this service and I apologize for the late reply. A word of advice, some of the people offering rebuilding services are just re-bushing the worn areas where the throttle shaft passes through the main housing, this will not cure the problem, try and find a rebuilder that will install bearings and seals and provide a positive vertical locking feature for the throttle shaft. Good luck in your search for a quality rebuilder. Regards Phil" bummer. --- replace with a vanagon throttle body? makes them go a bit better says @clayperrine . might be able to get hold of one of those without the throttle plate groove wear problem? |
Van B |
May 9 2022, 06:22 PM
I’m sure there aren’t any NOS of those either.
Bottom line, we need someone who can do a full service TB rebuild in the community. I just don’t understand why I can’t find anyone. |
Bartlett 914 |
May 9 2022, 06:24 PM
914 World, Phil is out of the Throttle Body game. I finally got a response from him today, see below: "Good morning Van, Thank you very much for your interest in my re-machined throttle bodies however as of February of this year I am no longer providing this service and I apologize for the late reply. A word of advice, some of the people offering rebuilding services are just re-bushing the worn areas where the throttle shaft passes through the main housing, this will not cure the problem, try and find a rebuilder that will install bearings and seals and provide a positive vertical locking feature for the throttle shaft. Good luck in your search for a quality rebuilder. Regards Phil" I cannot help but feel this comment was directed at me. I don't criticize others work and it would be unfair fore someone that does not know me, my business or has seen my work to criticize my efforts. 914 is a hobby for me and not a business. I do have a full service machine shop including lathes, manual milling machines CNC milling machines etc. Id make parts and repairs on many aspects for the 914. I had a really bad throttle body so I naturally repaired it. I went to the effort of making fixtures to do this in a precise and repeatable manner. I rebuilt several for friends and I decided to make this available to others here. I have rebuilt quite a few without complaints. I do a basic cleaning and I precisely bore out the TB throttle shaft. I install bronze bushings and ream them for smooth operation. I replace any seals. The actuator arm and the spring are cleaned. I do not plate them simply because of the volume of these that I do. I do replace the nut and washer so in the end, it is a nice looking part. Occasionally I have needed to bore out the large diameter as it can happen that a groove gets worn into the surface. I also can make the throttle plate. As a machinist, this is easy for me to do. I should note here that the plate is not a round disk. It is a special operation needed to properly create one. I plan on offering the service with plated parts and larger openings for those wanting a larger bore. |
Aerostatwv |
May 9 2022, 06:41 PM
Member Group: Members Posts: 128 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
Hello Mark, What's the typical turnaround time to rebuild one of these units? Thanks, Chris |
Van B |
May 9 2022, 06:59 PM
Yeah Mark, I can’t really say who he was talking about as there isn’t really anyone I can find that does this service professionally. I also don’t know what he means by adding a positive vertical locking feature for the shaft?
I understand your reluctance to invest in cad plating equipment given your “hobby” status. I’ve come close to buying a 5 gal bucket type setup myself, but I just don’t have enough use for it since I replace all the old bolts I take off. What do you think about stepping up to be the full service guy? Van |
Bartlett 914 |
May 9 2022, 08:39 PM
Bartlett 914 |
May 9 2022, 08:40 PM
Yeah Mark, I can’t really say who he was talking about as there isn’t really anyone I can find that does this service professionally. I also don’t know what he means by adding a positive vertical locking feature for the shaft? I understand your reluctance to invest in cad plating equipment given your “hobby” status. I’ve come close to buying a 5 gal bucket type setup myself, but I just don’t have enough use for it since I replace all the old bolts I take off. What do you think about stepping up to be the full service guy? Van Hi Van I have a plating kit I planned on setting up. Maybe this summer. |
Lo-Fi Version | Time is now: 26th December 2024 - 08:06 PM |
