914 GT 3.6 Ferrari Build, - Mechanicals coming along, electronics soon! |
East coaster |
Aug 10 2024, 05:25 AM
Senior Member Group: Members Posts: 1,748 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
Headers are art!
tygaboy |
Aug 10 2024, 07:18 AM
914 Guru Group: Members Posts: 5,424 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Some details of what it's taking to make this exhaust. The fixture table earns its keep in this episode!
https://www.youtube.com/watch?v=YvXQ0mzQBBM |
technicalninja |
Aug 10 2024, 09:43 AM
Senior Member Group: Members Posts: 1,821 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Outstanding!
We need a DNA sample from Martin! Cloning should be investigated... (IMG:style_emoticons/default/beerchug.gif) Are you planning a heat shield for the starter and tranny linkage? I think you're going to need them. I'd mount the starter shield to the starter and the tranny linkage shield to the exhaust pipe. I believe the aluminum linkage bars will conduct heat bigtime into the cables themselves. Might not be a problem but I'd test for temperature. I'd expect the exhaust tubes to exceed 800 degrees at times. Love the fixture table! One thing I did notice... You have an upright belt sander. This tool is my nemesis! Yours is "beltless"! (IMG:style_emoticons/default/first.gif) Only way these puppies are safe IMO! I've been whipped RAW and BLEEDING too many times by those... We need a Kitty update! |
Montreal914 |
Aug 10 2024, 10:42 AM
Senior Member Group: Members Posts: 1,671 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
My favorite Saturday morning art show. (IMG:style_emoticons/default/pray.gif)
Simply amazing how this is coming together. (IMG:style_emoticons/default/wub.gif) Thank you for this great entertainment! (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
Dion |
Aug 10 2024, 04:36 PM
RN Group: Members Posts: 2,792 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
The Chris & Martin show! Simply the best. The crossover pipe build and jig table segment is a pleasure to see come together. Agree Martin should be cloned! (IMG:style_emoticons/default/lol-2.gif)
Glad you’re healing well Chris! Hope the kitties are well. |
bkrantz |
Aug 10 2024, 07:28 PM
914 Guru Group: Members Posts: 8,042 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
The headers look better upside down than right side up. Stainless? @bkrantz - You hurt my feelings. Clearly, you've not been watching the videos. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/happy11.gif) Yes, entire exhaust is 304 stainless. The header flanges are the original Ferrari cast stainless parts, sliced off the factory exhaust manifolds. Sorry, my bad. I guess I am old school and prefer old fashioned words and photos (and I usually browse 914World while watching TV with my wife). I promise to do better. |
tygaboy |
Aug 11 2024, 06:31 AM
Mocking up the header-to-X connection to verify clearance under the tube that runs to the muffler. I'm not wild about the look but I'm not sure I have much of a choice. I may play with a bit tighter radius at the header to see if like that any better.
The issue is that the quicker it turns at the front, the wider it has to be at the rear to get under the muffler tube as it drops. Attached thumbnail(s) |
tazz9924 |
Aug 11 2024, 07:29 AM
Senior Member Group: Members Posts: 715 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Some details of what it's taking to make this exhaust. The fixture table earns its keep in this episode! https://www.youtube.com/watch?v=YvXQ0mzQBBM Get yourself a gas lense for that stainless exhaust work! I use a 12 or a 14 cup on stainless, It keeps your welds from getting hot, reduces warping and makes it all look better. Plus ill do anything to avoid the look of burned stainless |
tygaboy |
Aug 13 2024, 10:09 PM
The X-pipe's connected to the mufflers. Unfortunately, this isn't the way it'll look when everything's in there. The tubes from the headers to the rear of the X-pipe will block part of this view. But you'll know it's there!
rick 918-S |
Aug 14 2024, 04:57 AM
Hey nice rack! -Celette Group: Members Posts: 20,667 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Nice Headers (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
930cabman |
Aug 14 2024, 04:59 AM
Advanced Member Group: Members Posts: 3,511 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
tygaboy |
Aug 14 2024, 05:19 PM
The 914 Ferrari now has a crossover exhaust. It turned out great and I couldn't resist a few arsty fartsy shots.
flxzcat |
Aug 14 2024, 05:30 PM
Newbie Group: Members Posts: 6 Joined: 13-June 11 From: lake forest socal Member No.: 13,188 Region Association: None |
Chris,
I know you are into the front end pretty deep, but you like doing things a couple of times (IMG:style_emoticons/default/laugh.gif) so, I'll throw this idea out there. Based on my Indy, IMSA, F1 and vintage racing fabricator experience I would tilt the radiator another 20-30 degrees forward and add diffuser surfaces to the top and bottom of the actual inlet area of the radiator that run all the way to the front sheet metal opening(s). This would improve and smooth the airflow to the radiator dramatically. For air exit, I don't like the often-used holes in the wheel wells concept (though they are indiscrete). The aero is way too messy. So, I would also suggest tilting the trailing edge of the hood up 2 or 3 inches so that most of the air exits into the low-pressure area at the base of the windshield. Plus, hey, when your idling, hot air rises, right? Some of that hot air will also exit the sides. And some may sneak back in through the sides even at speed, but not much. This also provides a unique (though pretty subtle) look to the front end. Just my .02 worth. Cheers, Paul VDL |
Shivers |
Aug 14 2024, 06:32 PM
Senior Member Group: Members Posts: 2,646 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Damn that is fine.
bkrantz |
Aug 14 2024, 07:01 PM
Sweet
Krieger |
Aug 14 2024, 09:25 PM
Advanced Member Group: Members Posts: 4,752 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Dang, that is really tidy! Good work!
napasteve |
Aug 14 2024, 09:41 PM
914 driving winemaker Group: Members Posts: 508 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
Wow. Artsy and fartsy. I can’t wait for the startup.
Cairo94507 |
Aug 15 2024, 05:45 AM
Michael Group: Members Posts: 10,001 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
(IMG:style_emoticons/default/first.gif) Chris just keeps raising the bar; that looks beautiful Chris. (IMG:style_emoticons/default/beerchug.gif)
technicalninja |
Aug 15 2024, 07:53 AM
Looks beautiful.
How does it SOUND? We want the howl... |
cali914 |
Aug 15 2024, 08:34 AM
cali914 Group: Members Posts: 452 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
That is Ferrari worthy
Lo-Fi Version | Time is now: 16th September 2024 - 12:56 PM |
