rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,115 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
When you remove the oil temp sensor the oil will pour out. The oil pressure switch can be removed with the oil in.
Lockwodo |
Member ![]() ![]() Group: Members Posts: 202 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California ![]() ![]() |
With respect to the temperature gauge, here are the graphics for rough calibration points depending on which oil temperature sender your using (i.e. in the taco plate). 039919268 is the OEM sender (200 C) for 914's. Many have had the wrong (120C or 150C) senders installed over the years which is why the graphic contains the gauge calibrations for those as well. Normal oil temps for an air cooled engine are much hotter than water pumpers. Oil sump temps in range of 240 - 280 F are not outside the norm for air cooled motorcycles and air cooled T4 engines. You can see this was reflected on the OEM gauge calibration which doesn't start the red zone until 300F. The photo below is the temp gauge on my '74 2.0, engine fully warmed up and thermostat and flap system operating properly. Engine is off. Looking at Figure 1 above, my gauge looks the most like the two gauges on the left side of the diagram. My question is, does it look like the gauge needle is registering accurately somewhere in the 210 to 250 degrees F range? I haven't looked at the sender yet to see if it is correct for the '74, but it does at least appear to be working. ![]() |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,993 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
[. . . does it look like the gauge needle is registering accurately somewhere in the 210 to 250 degrees F range? To answer the question straightaway - Looks good. I'd guess closer to 210 but that's fine. I've never seen the calibration diagrams for the combo gauge but like you, I'd assume it is closer to the early calibration (top left - figure 1). Someday I'll do that calibration but right now I'm in the midst of a house sale so it won't happen soon. All my gauges are packed somewhere. . . . (IMG:style_emoticons/default/headbang.gif) Don't sweat the details. The bottom line of the gauge like most is to give trend data. It doesn't really matter if your oil is 214.5 degrees or 247. What matters is that you now where normal is and if you see a fast rise toward and/or into the red band, something is wrong. Just remember, oil sump temperature LAGS cylinder head temperature pretty substantially. So, don't expect that gauge to move around quickly. It is what it is . . . a general indication of overall engine temperature. |
Lockwodo |
[. . . does it look like the gauge needle is registering accurately somewhere in the 210 to 250 degrees F range? To answer the question straightaway - Looks good. I'd guess closer to 210 but that's fine. I've never seen the calibration diagrams for the combo gauge but like you, I'd assume it is closer to the early calibration (top left - figure 1). Someday I'll do that calibration but right now I'm in the midst of a house sale so it won't happen soon. All my gauges are packed somewhere. . . . (IMG:style_emoticons/default/headbang.gif) Don't sweat the details. The bottom line of the gauge like most is to give trend data. It doesn't really matter if your oil is 214.5 degrees or 247. What matters is that you now where normal is and if you see a fast rise toward and/or into the red band, something is wrong. Just remember, oil sump temperature LAGS cylinder head temperature pretty substantially. So, don't expect that gauge to move around quickly. It is what it is . . . a general indication of overall engine temperature. Awesome (IMG:style_emoticons/default/agree.gif) thanks Superhawk996, one less thing to fix (IMG:style_emoticons/default/beerchug.gif) |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,314 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
If it helps for confidence in the gauge...I am running a separate calibrated oil temp sensor in the return line from my oil cooler (rear mounted Tangerine cooler) which dumps directly back into the sump. The sensor feeds into my Microsquirt where I can use a tablet to display temps (among other engine parameters) if desired.
The temperature I'm reading there directly correlates, to within single-digits degrees, to the bottom left illustration in post #14 (1973 gauge with 150C sender)*. That illustration also works with the oil temp gauge in the left combo (which is what I have). I've found that when I'm showing around 220F on the MS then I'm right at halfway between the left hashmark and the left side of the wide red graphic. That's my baseline sweet spot fromw which to judge too hot/cold* GA *To explain, I removed my console as redundant (and sometimes misleading) info, plus I wanted the leg room. However I was able to compare MS to the center console before doing so; I installed the fuel/combo oil temp to use as a running guideline, since I don't run the tablet often. **I have the MS switching on the cooler fan at 220 and off at 190...maybe I should bump that up a tad; though, on summer days it stays toward the high side anyway, won't come down to 190 unless I'm idling. |
Lockwodo |
If it helps for confidence in the gauge...I am running a separate calibrated oil temp sensor in the return line from my oil cooler (rear mounted Tangerine cooler) which dumps directly back into the sump. The sensor feeds into my Microsquirt where I can use a tablet to display temps (among other engine parameters) if desired. The temperature I'm reading there directly correlates, to within single-digits degrees, to the bottom left illustration in post #14 (1973 gauge with 150C sender)*. That illustration also works with the oil temp gauge in the left combo (which is what I have). I've found that when I'm showing around 220F on the MS then I'm right at halfway between the left hashmark and the left side of the wide red graphic. That's my baseline sweet spot fromw which to judge too hot/cold* GA *To explain, I removed my console as redundant (and sometimes misleading) info, plus I wanted the leg room. However I was able to compare MS to the center console before doing so; I installed the fuel/combo oil temp to use as a running guideline, since I don't run the tablet often. **I have the MS switching on the cooler fan at 220 and off at 190...maybe I should bump that up a tad; though, on summer days it stays toward the high side anyway, won't come down to 190 unless I'm idling. Thanks, good to know. This 914 is my first experience with an air cooled engine and it's great to have benchmarks for normal operating conditions. |
Lo-Fi Version | Time is now: 25th June 2024 - 09:14 PM |
