broomhandle |
Member ![]() ![]() Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California ![]() |
Hello,
clearing out some parts. I have what I remember and think are 2.0 bus heads, and 1.8 heads. Can somebody help confirm? also.... I have a 2.0 block that I wanted to someda build a 2.0. I also have a set of 1.7 heads which I thought would be the best to convert. Anybody agree before I sell these? 2.0: ![]() ![]() |
broomhandle |
broomhandle |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,119 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Not seeing any number stamps on the heads. Should be some 022/039 numbers
broomhandle |
Not seeing any number stamps on the heads. Should be some 022 numbers where would the numbers be located? I found this, but still not helpful 2.0 bus vrs 2.0 914. https://ratwell.com/technical/Heads.html |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,799 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Not seeing any number stamps on the heads. Should be some 022 numbers where would the numbers be located? I found this, but still not helpful 2.0 bus vrs 2.0 914. https://ratwell.com/technical/Heads.html They will be small valve US speced heads that were fitted to the bus ,not much good as they look in poor condition besides,best to move on with these as they aren't worth the machining required. |
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 712 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
2.0 heads from a 914 always have only three (3) studs to hold the intake manifolds to the heads. On VW buses, regardless of engine size, the bus heads always have four (4) studs to hold the intake manifolds to the head. The last picture looks like a 1.7 head from the shape of the combustion chamber. The first pictures you posted are difficult to identify because the combustion chambers look like someone has ground out an area to increase the size of the combustion chambers. We need to see the casting numbers on the heads, or know the valve sizes to ID the heads.
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,363 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
broomhandle |
Thank you for the help, I have looked for casting numbers, and I do not see them. Where would they be located? Or my eyes are not as good as they were. (IMG:style_emoticons/default/smile.gif)
914Sixer |
Here is where number stamping should be
Attached image(s) ![]() ![]() |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,151 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The Buses had small valves, the 1.8 valves are larger.
The "ratwell" and archived "tunacan" pages should list the valve sizes for the Bus and 1.8 heads. --DD |
Lo-Fi Version | Time is now: 25th April 2025 - 12:31 AM |
