Blinking Red Dash Light, Can’t find the reset button |
jim_hoyland |
Jul 18 2022, 07:45 AM
Get that VIN ? Group: Members Posts: 9,557 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Bob and I bled the brakes Sunday and they work fine, fluid level is high. While bleeding the resivoir ran real low once.
Today, I just noticed the re light blinking even with the parking brake handle fully down. IIRC, there’s a reset button? But I don’t remember where it is. Attached image(s) |
Jett |
Jul 18 2022, 07:50 AM
Senior Member Group: Members Posts: 1,671 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Bob and I bled the brakes Sunday and they work fine, fluid level is high. While bleeding the resivoir ran real low once. Today, I just noticed the re light blinking even with the parking brake handle fully down. IIRC, there’s a reset button? But I don’t remember where it is. Try this: http://www.914world.com/bbs2/index.php?showtopic=293708 |
jim_hoyland |
Jul 18 2022, 08:07 AM
Thanks for that link; I’ll look for that reset button.
NARP74 |
Jul 18 2022, 09:40 AM
Senior Member Group: Members Posts: 1,300 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I have also had my parking brake button get flaky. With the brake handle in the up position, reach down and press the button several times and make sure the light goes on and off as it should.
jim_hoyland |
Jul 18 2022, 11:28 AM
I turned the front wheels full right but didn’t see it; does the belly pan have to be removed 1st ?
Here’s a pic of what I’m looking for….. Attached image(s) |
troth |
Jul 18 2022, 11:35 AM
Member Group: Members Posts: 155 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
It should have a rubber cap over it.
emerygt350 |
Jul 18 2022, 11:45 AM
Advanced Member Group: Members Posts: 2,514 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
It's visible through a small area where your tierod enters the wheel well. If I remember right...
jim_hoyland |
Jul 18 2022, 12:07 PM
sportlicherFahrer |
Jul 18 2022, 12:20 PM
Nothing to see here. Group: Members Posts: 1,109 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Shouldn't. Depending on ride height you might not even need to jack the car up. Turn the wheels full lock to the right and you should be able to see the left side of the master cylinder just under the left tie rod. Sensor is on the left side of the master with the reset button sticking out of it. Mine was under a boot. My steering pan also had a hole directly under the sensor that made it easier to see/reach the reset button.
jim_hoyland |
Jul 18 2022, 01:14 PM
Took the wheel off and found the rubber cap had to reach in with long needle nose plier to get it off.
Then I pushed the reset button. Problem now is I don’t have enough room to reach in to put the wire and cap back on. And, the bolts holding the pan on are frozen. Attached image(s) |
jim_hoyland |
Jul 18 2022, 02:05 PM
Mission accomplished (IMG:style_emoticons/default/smile.gif) still gotta get the car on a lift to remove the belly pan bolts. And I like the idea of a hole to access the switch
76-914 |
Jul 19 2022, 07:28 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Jim., I'm an hour and a half from you but your always welcome to use my lift. Just not this week. (IMG:style_emoticons/default/av-943.gif) I'll be at the WCR. (IMG:style_emoticons/default/beerchug.gif)
jim_hoyland |
Jul 19 2022, 08:19 AM
Thanks Kent; have a great WCR trip !
Lo-Fi Version | Time is now: 26th December 2024 - 05:30 AM |
