3 Pages V < 1 2 3
> high idle, 3000rpm idle
rjames
post Mar 24 2024, 11:17 AM
Post #41
I'm made of metal
QUOTE(76-914 @ Mar 18 2023, 08:12 AM) *
Those can be re-bushed. Is there such a word? Any machinist can do it. It will need to be drilled out then reamed for a proper surface for the new bushings. Don't try this yourself because the surface must be perfect and final reamed with a reamer that is .001" undersized for a press fit. You can also go to a local airport and find the A&P who works on small aircraft that will do this for you. (IMG:style_emoticons/default/beerchug.gif)
I was able to do this at home. Not hard if you’re careful. If I can do it, anyone can.
emerygt350
post Mar 24 2024, 02:59 PM
Post #42
QUOTE(slotty008 @ Mar 24 2024, 09:33 AM) *
And this is the knob in the cockpit.
I like it!
rhodyguy
post Mar 25 2024, 11:18 AM
Post #43
Do not overlook the stacked elbow. Kind of an obscure part in an obscure location. The rubber portion can crack/split.
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 21st December 2024 - 06:12 AM
