Parking Brake Cable end rubber covers, Source for both firewall end & caliper end |
jim_hoyland |
Aug 10 2022, 06:22 PM
Get that VIN ? Group: Members Posts: 9,603 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Are the rubber boots at the ends ( firewall and caliper ) different?
I’m trying to locate a set for both ends of each cable, |
StarBear |
Aug 10 2022, 06:36 PM
Advanced Member Group: Members Posts: 2,099 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Yes, they are different. The forward (firewall) ones come with the cables. The rearward (caliper) ones are from AA and 914 Rubber. Installing my rear ones tomorrow. A prior thread on this maybe two weeks ago. Tricky to get the boot over the cable clip onto the caliper hook.
Photos maybe tomorrow . |
fixer34 |
Aug 10 2022, 06:55 PM
Senior Member Group: Members Posts: 1,228 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Are the rubber boots at the ends ( firewall and caliper ) different? I’m trying to locate a set for both ends of each cable, Yes they are, and I have a extra set. Bought from 914Rubber earlier this year, then I bought the full cable special last month which came with new boots also. Pete |
robkammer |
Aug 11 2022, 07:02 AM
Member Group: Members Posts: 200 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States |
I can vouch for the 914 rubber boots. Slather a little Dawn dish soap on them, it's make installation much easier.
Rob |
mgphoto |
Aug 11 2022, 09:16 AM
"If there is a mistake it will find me" Group: Members Posts: 1,366 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
When you put the rubber boot over the clevis at the caliper use a blunted awl, slide it into the opening at the clevis side, as you push the clevis through the hole use the awl, being careful not to catch the tip on the boot, take the awl and spread the opening using the clevis for leverage, spin the awl around the clevis and the hole will open enough to push the clevis through the hole.
Works every time haven’t torn one yet done this about 10 times on my car in 40 years . |
StarBear |
Here are the pics! On to the other side…
Mikey914 |
Aug 11 2022, 03:16 PM
The rubber man Group: Members Posts: 12,745 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Very nice!
StarBear |
Aug 11 2022, 05:53 PM
The right side. Done!
It looks (?) like there’s a slot for a wire stay around the bigger end. |
Lo-Fi Version | Time is now: 6th February 2025 - 02:02 PM |
