LED Bubs |
LED Bubs |
Geezer914 |
Aug 29 2022, 11:54 AM
Geezer914 Group: Members Posts: 1,747 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Has anyone replaced their stop light/turn signal/back up light bulbs with Led bulbs? How do they look? Did you have to add a resistor or modify the flasher?
mgphoto |
Aug 29 2022, 12:15 PM
"If there is a mistake it will find me" Group: Members Posts: 1,364 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I did, and no to the resistor, I am going to try a set of headlight leds that I bought.
ps: I did my gauges too, I’m happy with the look. |
VaccaRabite |
Aug 29 2022, 12:28 PM
En Garde! Group: Admin Posts: 13,581 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Yes, every bulb in my car save the GEN bulb is now LED.
For my brakes and turns I used the SpokeWorks LED boards. Zach |
bbrock |
Aug 29 2022, 12:50 PM
I did too. Completely plug and play and way brighter than the incandescent bulbs. I used red bulbs for taillight and side markers so even with European amber lenses, they light up red and are DOT legal.
Geezer914 |
Aug 29 2022, 04:18 PM
Thanks for the replies. Ordered Sylvania Zevo bulbs, amber, white and red. already changed the dash and gauge lights with blue LED's.
Jamie |
Aug 29 2022, 05:20 PM
Senior Member Group: Members Posts: 1,068 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
bbrock |
Aug 29 2022, 06:55 PM
Thanks for the replies. Ordered Sylvania Zevo bulbs, amber, white and red. already changed the dash and gauge lights with blue LED's. So what is a preferred source for the variety of bulbs required for such a lighting upgrade? I buy mine from SuperBrightLEDs.com. They have a great tool that will list all the bulbs for a particular vehicle. The only one that was off for me was the interior courtesy light on the rear pad. The one they speced was just a tad too long for the aftermarket fixture most commonly sold. I had to exchange for a bulb a few mm shorter. |
FlacaProductions |
Aug 29 2022, 07:31 PM
Senior Member Group: Members Posts: 1,775 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Agreed on SuperBrightLEDs.com - I've done multiple vehicles through their online tool.
Spoke |
Aug 30 2022, 12:14 PM
Jerry Group: Members Posts: 7,079 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
...Did you have to add a resistor or modify the flasher? You save a lot of power going to LED turnsignals then re-burn the power in a power resistor. It's best to put in an LED-compatible flasher. EP26 is readily available and the C2 pin can be internally connect for either the early separate L and R tach indicators or the single L/R tach indicator in the later 914's. |
mgphoto |
Aug 30 2022, 03:17 PM
Thanks for the replies. Ordered Sylvania Zevo bulbs, amber, white and red. already changed the dash and gauge lights with blue LED's. So what is a preferred source for the variety of bulbs required for such a lighting upgrade? I buy mine from SuperBrightLEDs.com. They have a great tool that will list all the bulbs for a particular vehicle. The only one that was off for me was the interior courtesy light on the rear pad. The one they speced was just a tad too long for the aftermarket fixture most commonly sold. I had to exchange for a bulb a few mm shorter. Could you indicate which would be the bulb for the aftermarket fixture and a replacement for the original fixture? Thanks |
aharder |
Aug 30 2022, 03:27 PM
Advanced Member Group: Members Posts: 4,543 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
bbrock |
Aug 30 2022, 06:51 PM
Thanks for the replies. Ordered Sylvania Zevo bulbs, amber, white and red. already changed the dash and gauge lights with blue LED's. So what is a preferred source for the variety of bulbs required for such a lighting upgrade? I buy mine from SuperBrightLEDs.com. They have a great tool that will list all the bulbs for a particular vehicle. The only one that was off for me was the interior courtesy light on the rear pad. The one they speced was just a tad too long for the aftermarket fixture most commonly sold. I had to exchange for a bulb a few mm shorter. Could you indicate which would be the bulb for the aftermarket fixture and a replacement for the original fixture? Thanks I can't believe I was able to find my receipt so easily! Here's the bulb that worked for me: https://www.superbrightleds.com/3710-led-bu...olor-Warm~3300K and the interior fixture is the empi that is sold everywhere. I bought mine from 914Rubber: https://914rubber.com/interior-light-1. The online bulb tool specifies a 44mm bulb which is too long. |
Chris914n6 |
Aug 30 2022, 07:41 PM
Jackstands are my life. Group: Members Posts: 3,407 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
The resistor and flasher relay is for the modern cars that blink faster when a bulb burns out, or has the CANBUS/BCM that expects a certain resistance.
We already have the 'led spec' relay, that has a built in timer mechanism. I got my bulbs off Amazon, about $15 a pair. Plenty bright and nicely made. The front turns don't match up with the filament location so the refection is off but I only noticed it with the clear lenses. I went back to amber so the whole lens glows like stock. The other nice thing about led blinkers is the dash lights don't dim as much. |
Geezer914 |
Sep 2 2022, 06:24 AM
I replaced the bulbs with Sylvania ZEVO LED lights through Amazon.
1157A Amber front turn signals Rear Lights 1156R Red 1157R 1156 white BA9 white LED's for the rear side marker lights (Superbright) |
Lo-Fi Version | Time is now: 30th October 2024 - 09:44 PM |
