> Wiring harness supplies, I'm looking for a source for wire.
Wadesbrain
post Sep 9 2022, 12:50 PM
I'm getting ready for winter time projects for my '70 1.7. My current harness is totally roached, burned, poorly spliced and painted over. Does anyone have a supplier for original color spools of wire and perhaps connectors, grommets, or plugs that I would need?
ClayPerrine
post Sep 9 2022, 12:53 PM
Someone here probably has the complete wiring harness from a car that was parted out. Just put a wanted to buy ad up in the classifieds.
FlacaProductions
post Sep 9 2022, 12:56 PM
I got great product from Restoration Design. Peter Kocandrle @ wiring@restoration-design.com helped me.
Wadesbrain
post Sep 9 2022, 01:14 PM
Thanks for the replies. Im actually looking to do the whole thing myself. I can't weld or grind in my garage over the winter and I have the space and time to lay out a new one. I just need parts. The only option if I can't find original colors is to make up new ones and keep a record to translate. I would rather not do that.
gord
post Sep 9 2022, 01:16 PM
QUOTE(Wadesbrain @ Sep 9 2022, 12:50 PM) *
Check out 4R Customs Wire — they're like the Belmetric of wiring.
https://4rcustomswire.com/
Wadesbrain
post Sep 9 2022, 01:25 PM
QUOTE(gord @ Sep 9 2022, 03:16 PM) *
That is what I'm looking for! Thanks.
914Sixer
post Sep 9 2022, 02:35 PM
NOS one at Asse Sales $1500 for 1971
Wadesbrain
post Sep 9 2022, 04:09 PM
QUOTE(914Sixer @ Sep 9 2022, 04:35 PM) *
Ok now you have my attention....
FlacaProductions
post Sep 9 2022, 04:21 PM
https://www.aasesales.com/products/f1n-1053...4d25a&_ss=r
914-Kazoo
post Sep 10 2022, 05:05 PM
Try
https://4rcustomswire.com/products
914-Kazoo
Or try
https://www.store.ynzyesterdaysparts.com/wi...ith-tracer.html
DennisV
post Sep 10 2022, 06:25 PM
QUOTE(Wadesbrain @ Sep 9 2022, 11:50 AM) *
When I decided to build my own wiring harness to add heated seats to my Boxster, I bought wire from Allied Wire and Cable. They offer TYPE TXL Extra Thin Wall (XLP) AUTOMOTIVE PRIMARY WIRE. It is a low tension primary cable that is meant for the following applications.
* For use in automotive applications where small diameter and minimal weight is desirable.
* Meets requirements of SAE J-1560 (now contained in J-1128).
* Recommended temperature range -51 C to +125 C.
* Available in solid colors and stripes with optional custom printing and/or numbering available.
* Also meets Ford (Mil-123A) and Chrysler (MS-8288)
That was a few years ago but I suspect it's still available.
waltonsm
post Sep 11 2022, 06:31 AM
I’ve got 99% of the wiring harness I pulled from my car that I was planning to sell to someone who needed a whole one. I took it out in one piece and it hasn’t been painted over. Came out in one piece, only thing I cut off was the fuel tank sender connector.
johnorm
post Sep 17 2022, 10:08 AM
QUOTE(Wadesbrain @ Sep 9 2022, 01:25 PM) *
Also check out ACDCSUPPLY on eBay (they and 4R both sell GXL/TXL striped wire). For connectors try Digi-key, I would suggest you want to try TE Connectivity AMP quick connection uninsulated crimp connectors. Some of the one's I have used are
Part # Gauge Tab Width and Style[/b][u]
180351-2 10-12ga. 0.25 Single Female
62998-1 8-10ga. 0.25 Single Female
63365-1 10-14ga. 0.25 Single Female
41727 12-16ga. 0.25 Single Female
41202 14-18ga. 0.25 Single Female
63093-1 14-18ga. 0.11 Single Female / Narrow Tab
42068 18-22ga. 0.11 Single Female / Narrow Tab
61944-2 14-18 0.25 RCPT/TAB (one Female / One Male TAB)
61988-1 18-22ga. 0.25 RCPT/TAB (one Female / One Male TAB)
61386-1 16-20ga. 0.25 Ring Connector 3mm stud
160163-2 10-12ga. 0.25 Ring Connector for 4mm stud
- Lo-Fi Version Time is now: 30th October 2024 - 09:44 PM
