2 Pages V < 1 2
> Flapper Restoration (aka Flap Control Box), Springs and Sealing Rubber
Aerostatwv
post May 21 2023, 09:21 AM
Post #21
QUOTE(rgalla9146 @ Sep 11 2022, 09:03 AM) *
Yes, that grey
Stoddard sells it.
(IMG:style_emoticons/default/agree.gif) I've used the Stoddard paint and it is close to original color. The coverage is awesome so you don't need multiple coats.
Chris
DennisV
post May 21 2023, 10:05 AM
Post #22
QUOTE(Aerostatwv @ May 21 2023, 08:21 AM) *
I couldn't find the Stoddard paint available anywhere. I think it was discontinued.
I did find Wurth Zinc Weld Thru primer. I sprayed some out and it is very close color match to our 356 muffler. Their spec sheet says: - Heat resistant up to 914ºF
I am currently stuck on how to get them apart for painting without destroying them. (IMG:style_emoticons/default/smash.gif)
bdstone914
post May 21 2023, 10:46 AM
Post #23
bdstone914
[Just paint them assembled. I dig out the old seals and blast the inside. I have powder coayed sexeral pairs but it may be overkill.
post May 21 2023, 11:04 AM
Post #24
914-6 GT in waiting
I don’t take them apart. Just blast and powder coat.
914werke
post May 21 2023, 11:31 AM
Post #25
As has been mentioned there is no rubber in them & while their purpose is to route heated air to the cabin, they dont get that hot.
I only powder coat the ones that are in new/great shape with the fiber seal still intact, otherwise ..paint.
Oh & I did try to dissasemble one to see if it was possible to renew seals....once. (IMG:style_emoticons/default/headbang.gif)
DennisV
post May 22 2023, 05:32 PM
Post #26
QUOTE(914werke @ May 21 2023, 10:31 AM) *
When you say "paint", I assume you mean rattle can spray. Did you use special nozzle for that? I am having a hard time seeing how to get paint to the inside flange of the cap for example. The angle just isn't there for a regular rattle can.
(IMG:style_emoticons/default/ar15.gif) I guess there's always spray the bejesus out of it and let it run.
I guess with powder coat, you'd get the benefit of the electronic charge that would draw some paint to unseen areas?
914sgofast2
post May 22 2023, 06:51 PM
Post #27
Someone asked if anyone has straightened the four tabs that hold the mushroom shaped air diffuser on. I did and the tabs are pretty strong. They straightened right out with no problems. I slipped a hose over them to do the factory “fix” for vapor lock on my 1970 model 914.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 3rd April 2025 - 01:12 AM
