20 Pages V « < 8 9 10 11 12 > »
> Safari 914 project, “Sufari”
jd74914
post Aug 8 2023, 08:25 AM
Post #181
Its alive
Very cool!
What's the deal with the mill? Is that an automated 4th axis?
Unsolicited feedback: You might want to relieve on the back of the splines (cut down the axle and then fillet into the splines). I've done the same cutting you're showing and twisted then sheared at the stress concentration where the splines land in the main axle on two occasions and now always put a neck down like shown in the below image.
(IMG:http://www.914world.com/bbs2/uploads_offsite/bloozeown.weebly.com-1659-1691504744.1.jpg)
East coaster
post Aug 8 2023, 01:01 PM
Post #182
Thanks for the feedback Jim. The mill is just an old Bridgeport that I put a DRO on. It’s awesome to have in the shop. I also have a 100 year old LeBlond lathe, and between the two of them you can make almost anything if you have the skills (I’m working on it).
The piece I machined was just a practice piece I was using to test out the process. I plan to mimic the Subaru shaft when I cut and spline the real shaft and I think the Subaru shaft has a relief like you mention.
jd74914
post Aug 8 2023, 08:58 PM
Post #183
Its alive
Cool! Sounds like a nice set! I love my Clausing lathe and can't wait to get a new [to me] mill.
You can get a lot of work done with just a DRO. And TBH full manual is probably a better starting point, at least from what I learned from the master machinists who taught me. It's nice to be able to be able to assess a cut by sight/sound/touch all at once while you're working the machine.
Sounds good on the half shafts. The car I twisted/spiral sheared almost exactly like the below picture and when we analyzed saw that the cracking actually started at the root of the spline.
In my case is was a 25mm diameter shaft on a 120ish hp car formula car which did launch so perhaps more load than you'll see, but still something you don't forget. (IMG:style_emoticons/default/bootyshake.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/ars.els-cdn.com-1659-1691549938.1.jpg)
Can't wait to see the final product! Your whole project is awesome BTW! (IMG:style_emoticons/default/first.gif)
East coaster
post Aug 15 2023, 06:37 PM
Post #184
Working on things I can do in the air conditioned portion of my shop. Decided to tackle my fuel tank. I’m using a complete Subaru fuel pump and sender so I fitted that to the tank. The pickup sits in the sump and I made a backing plate with studs to mount the unit. I also cleaned the tank with a vinegar soak for a few days, followed my baking soda and water. All that is left is giving it a coat of paint.
East coaster
post Aug 15 2023, 06:38 PM
Post #185
Backing plate….
East coaster
post Aug 15 2023, 06:39 PM
Post #186
Backing plate welded to tank….
East coaster
post Aug 15 2023, 06:41 PM
Post #187
Pickup in sump…….I had to turn the sock filter around 180 degrees to have it fit in the sump.
East coaster
post Aug 24 2023, 07:32 PM
Post #188
Wrapped up the fresh air box/heater today. All new seals from 914 Rubber, new fan and motor from URO, and mods to house the heater core and the Subaru resistor pack.
East coaster
Post #189
East coaster
post Sep 2 2023, 01:58 PM
Post #190
Rolled it out of the paint booth to began sanding off my perfect new paint job and repaint (in the correct color this time!). It’s been a while since I painted it and I was truly just waiting for cooler weather to tackle sanding and respray, but I think I needed this much time to get over the disappointment and frustration of being supplied with the wrong paint. I wished they had given me the wrong color and not just the wrong tone, at least I would’ve noticed before spraying.
East coaster
post Sep 2 2023, 01:59 PM
Post #191
East coaster
post Oct 3 2023, 04:35 PM
Post #192
Got back from a two week trip and decided to get a little done on the car while I’m waiting for cooler weather for sanding and paint. I’ve bounced around numerous ideas on a front push bar and here’s what I came up with. It’s all aluminum and pretty darn light so it’s not adding much weight (I think it’s lighter than the bumper tits that it eliminated).
Here are mounts. They’re 4” alum tube shaped to fit the bumper with a 1/4” plate welded at the back for mounting.
East coaster
post Oct 3 2023, 04:36 PM
Post #193
East coaster
Post #194
East coaster
post Oct 3 2023, 04:38 PM
Post #195
And welded up and mounted with 4” led fog lights
East coaster
Post #196
Nuther…..
East coaster
post Oct 3 2023, 04:42 PM
Post #197
I may still add a cross bar towards the bottom, but that’s for another day.
tygaboy
post Oct 3 2023, 06:02 PM
Post #198
Love it. That looks great! (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
Shivers
post Oct 3 2023, 06:08 PM
Post #199
QUOTE(East coaster @ Oct 3 2023, 03:38 PM) *
Nuther…..
Awesome (IMG:style_emoticons/default/smile.gif)
gereed75
post Oct 4 2023, 09:01 AM
Post #200
You are doing some incredible work on this car. Mastercraftmens level.
That heater box is just so trick, Wow.
- Lo-Fi Version Time is now: 31st March 2025 - 06:17 PM
