East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
East coaster |
Machined a conversion part for the clutch clevis. Just turned a piece of 1/2” steel to make the clevis end the diameter of the stock clevis threaded area so the pin will still clip on, then a radius to the larger diameter to provide enough beef for the 8mm thread of the Honda master cylinder. Welded the new part to the stock clevis and all lines up and functions well.
East coaster |
With radiator mount completed, it was on to the fabrication of the exit plenum. A little foam and filler to create a “buck”, then on to a little carbon/Kevlar layup. It came out well and I’m now laying up an entrance plenum to go between radiator and inlet opening. The plenums will have a thick rubber seal to isolate the plenum from the radiator and keep a tight seal.
Attached thumbnail(s) ![]() ![]() ![]() |
East coaster |
East coaster |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,795 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
I am still in admiration with your fiberglass duct work on your silver six (avatar), but now, even more! (IMG:style_emoticons/default/pray.gif)
A few questions: What type of foam is this? What type of adhesive are you using to bond the foam pieces? What type of filler are you using? Are you putting any protective layer on the filler prior to laying the CF over? Are you using polyester resin with CF as you would for fiberglass? Would all of this buck preparation process be the same for fiberglass? I think this is such cool fabrication work! (IMG:style_emoticons/default/beer.gif) Sorry for all the question... (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/beerchug.gif) |
Blue6 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,055 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California ![]() ![]() |
I am still in admiration with your fiberglass duct work on your silver six (avatar), but now, even more! (IMG:style_emoticons/default/pray.gif) A few questions: What type of foam is this? What type of adhesive are you using to bond the foam pieces? What type of filler are you using? Are you putting any protective layer on the filler prior to laying the CF over? Are you using polyester resin with CF as you would for fiberglass? Would all of this buck preparation process be the same for fiberglass? I think this is such cool fabrication work! (IMG:style_emoticons/default/beer.gif) Sorry for all the question... (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/beerchug.gif) What he said…. |
East coaster |
I am still in admiration with your fiberglass duct work on your silver six (avatar), but now, even more! (IMG:style_emoticons/default/pray.gif) A few questions: What type of foam is this? (Just some foam board from Home Depot) What type of adhesive are you using to bond the foam pieces? (Hot glue gun) What type of filler are you using? (A coating of joint compound, then a little bondo where needed) Are you putting any protective layer on the filler prior to laying the CF over? ( I usually do but didn’t here. The foam breaks out of the finished piece and it leaves a layer of joint compound which sands off very easily) Are you using polyester resin with CF as you would for fiberglass? ( I used West System epoxy) Would all of this buck preparation process be the same for fiberglass? (Same for glass. In fact, this has a single layer of fiberglass mat under the carbon. If you use polyester resin you would need to use different foam, as poly will eat this type of foam) I think this is such cool fabrication work! (IMG:style_emoticons/default/beer.gif) Sorry for all the question... (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/beerchug.gif) |
slowrodent |
Member ![]() ![]() Group: Members Posts: 173 Joined: 29-February 20 From: Tucson/Oro Valley Member No.: 23,981 Region Association: Southwest Region ![]() ![]() |
Super metal fab work.. And that plenum is wondrous. I love that solution. And your choice of footwear... the list goes on and on.. (IMG:style_emoticons/default/smile.gif)
Retroracer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 636 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest ![]() ![]() |
Another nod to the excellent footwear - but adding to the composite questions:
- who do use as a supplier for the carbon/kevlar? - are you using dye in the gel coat to give it that red coloring? Great thread BTW! - Tony |
East coaster |
Another nod to the excellent footwear - but adding to the composite questions: - who do use as a supplier for the carbon/kevlar? - are you using dye in the gel coat to give it that red coloring? Great thread BTW! - Tony I got the carbon Kevlar material from US Composites. The red is actually orange Kevlar woven with the black carbon. It was a left over from one of my jetski projects. |
East coaster |
Finished up the entrance plenum. Final fitting/trimming will be held for final install, but it fits up pretty damn close now (leaving a little room for sealing). Now on to figuring out my cooling lines.
I added a piece of 1/4” chromoly tubing to the top of the radiator opening to stiffen things up a bit. It was pretty flexy at the top once the hole was cut. ![]() ![]() ![]() |
East coaster |
East coaster |
East coaster |
East coaster |
East coaster |
Got more done on the cradle today. Bent some 1-1/2” DOM for the longitudinal section and fabricated mount plates for the motor mount and trans mount body points. Got the longitudinals welded up and got the engine mount cross bar tacked for finish welding tomorrow. Next will be figuring out my trans mount to cradle interface.
East coaster |
East coaster |
East coaster |
My focus on my project has been all over the map, mostly driven by our crazy Northeast weather. Today was an inside shop day and I started working my intake manifold flip. I stripped my intake and glass beaded the intake to clean it up. The flip is mechanically pretty straight forward, need just an 8mm spacer to raise the manifold enough to provide clearance for the fuel hard lines. The harder part will be re-wiring the harness a bit to account for the movement of the sensors, but even that shouldn’t be too difficult.
Lo-Fi Version | Time is now: 2nd April 2025 - 02:41 AM |
