20 Pages V « < 12 13 14 15 16 > »
> Safari 914 project, “Sufari”
East coaster
post Jan 23 2024, 07:29 PM
Post #261
QUOTE(Lof8 @ Jan 23 2024, 12:46 PM) *
what model BMW is the mirror from? I recently cracked my windhsield installing a mirror with the adhesive pad. Car look fantastic!
This one is from an early 3 series, but a 2002 works the same.
East coaster
post Jan 23 2024, 07:36 PM
Post #262
Today was the day to see if it made noise. It fired right up and idled down nicely. It’s a happy day in project land!
It’s alive!!!……..in my best Dr Frankenstein voice
I have a video but can’t seem to get it to upload……I’ll keep trying
strawman
post Jan 24 2024, 06:44 PM
Post #263
As a fellow Suby conversion addict, all I can say is congrats! The first start is always the greatest feeling ever. I've been driving my turbo Suby-powered 914 since about 2012, and I have successfully campaigned it at PCA and Vapor Trail Vettes autocrosses for several years now.
I recently bought out an estate here on the CA Central Coast back in September that included a sorta running/driving EG33 swapped 914 and a mostly complete parts car, five T4 engines, six transaxles and two pallets of 914, 912 and 911 parts that I've been slowly selling to fund my next project. I've been toying with the idea of building the parts car into a Safari 914 to cruise the gravel mountain roads around here. After reading through your build, I don't think there any question... now I just gotta find a running manual-equipped Suby parts car.
Enjoy driving it!
Geoff
East coaster
post Jan 25 2024, 06:21 AM
Post #264
Here’s a pic of the ball valve I added to the stock fuel port. I figured it’s a lot better than siphoning the tank if I ever need to pull the tank and it happens to be full (which is very likely due to Murphy’s law). I was able to get fittings that convert the stock tank Port threads to AN threads. One port is capped and one has the drain valve. I’ll be safety wiring the ball valve lever to ensure it never drains accidentally.
pek771
post Jan 25 2024, 06:32 AM
Post #265
Nice having a lathe isn’t it?
Are you above stock ride height?
East coaster
post Jan 25 2024, 09:31 AM
Post #266
QUOTE(pek771 @ Jan 25 2024, 05:32 AM) *
It’s awesome to have a lathe and mill. You can pretty much make anything. My lathe is over 100 years old and I can only imagine all the things it’s made over time.
I raised the suspension 2” with lowered spindles in the front and modified mount points in the rear.
East coaster
post Jan 26 2024, 09:41 PM
Post #267
Just some random pics of wrapping up the wiring harness (now that I know everything works), and playing with trying to get my carpet uncurled from packing. I also installed and final adjusted the shifter and cables.
East coaster
post Jan 29 2024, 07:48 PM
Post #268
Managed to get the hood on by myself today. I used some blankets to protect the cowl and went for it. Looks much better with a hood (IMG:style_emoticons/default/smile.gif)
Also fitted up the roof rack for some final work on the latches at the rear.
maddog
post Jan 30 2024, 08:09 AM
Post #269
I love this build! Cant wait to see it finished!
Retroracer
post Jan 30 2024, 08:07 PM
Post #270
Something to think about: How about coating the roof rack and brush bar a dark brown to match the backpad - gives the car a nice two tone contrast to the black targa top, bumper tops and flares? Little bit of a nuanced difference to the obvious "blackened" approach....
- Tony
PS. Still loving this build BTW. Nice job on the engine firing up!!
East coaster
post Feb 1 2024, 07:53 PM
Post #271
Worked on the final fitment of the roof rack today. It was pretty much finished a while ago except for a means of latching it down. I decided on a simple approach using some rubber rack straps.
I made some pins for the operating end of the straps and welded them to the support brackets. Then I welded mount points on the rack for the fixed end of the straps.
I’m calling it done (other than finishing and painting)!
East coaster
post Feb 2 2024, 06:39 AM
Post #272
QUOTE(Retroracer @ Jan 30 2024, 07:07 PM) *
- Tony
That would look good. I’m going to stay with black for touch up reasons though. I have a feeling there will be spots to touch up on the regular and there’s nothing like the ease of flat black spray cans.
rick 918-S
post Feb 2 2024, 07:21 AM
Post #273
Hey nice rack! -Celette
Like this build. Lots of detail. You will really enjoy the result.
DRPHIL914
post Feb 2 2024, 08:23 AM
Post #274
Dr. Phil
i am curious about where you sourced the flare material and how you came up with that design/shape? I like it especially your unique safari build.
Phil
ps awesome work btw, enjoying your unique approach with this yet using a lot of stock stuff like heater box for heat and so on, i am interested to see if that will provide enough air flow across the core to give you enough hot air for the cabin.
Phil
PSS - and i love the rack, i would like you to make me one when you are finishe with this build !!!
East coaster
post Feb 5 2024, 05:28 AM
Post #275
QUOTE(DRPHIL914 @ Feb 2 2024, 07:23 AM) *
Phil
Phil
Phil, The flares are just universal flares I picked up off eBay. I figured if I didn’t like them I could always GT flair it, but so far I think they’re right for the safari look.
I have let the car warm up and I seem to be getting good heat flow to the defrosters and floor vents. I put a new blower in the fresh air box and it really moves air. I’ll find out for sure when I start driving it in the cold.
pek771
post Feb 5 2024, 06:46 PM
Post #276
How much do you think this weighs? And have you driven it yet?
East coaster
post Feb 5 2024, 07:44 PM
Post #277
QUOTE(pek771 @ Feb 5 2024, 05:46 PM) *
No idea on the weight. I was pretty conscious of weight as I progressed though. All the roof rack and supporting parts are aluminum and really pretty light. The front “stinger” bar is also all aluminum and weights less than the stock bumper tits. It’s not ready to drive yet, but hopefully soon. The only major thing left is to make my driveshafts.
East coaster
post Feb 9 2024, 08:05 PM
Post #278
Made an air deflector for the Safari rack. Here’s fitting it up prior to final trimming/shaping/painting…..
I also finished and painted the trunk hinge supports/rook rack mounts and got them installed. Getting them through the grills and O-rings was a challenge but it came out clean looking.
tygaboy
post Feb 10 2024, 08:28 AM
Post #279
Nice. Very tidy. To me, it's those little details that make all the difference. (IMG:style_emoticons/default/smilie_pokal.gif)
East coaster
post Feb 11 2024, 05:45 AM
Post #280
Finished painting and installling the roof rack, looks so much better painted.
- Lo-Fi Version Time is now: 2nd April 2025 - 02:41 AM
