Van914 |
Van914 ![]() ![]() ![]() Group: Members Posts: 702 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest ![]() ![]() |
Saw this one in Indy a few years ago
East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
East coaster |
East coaster |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,725 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
love the trunk lid hinging.
(IMG:style_emoticons/default/beerchug.gif) |
Optimusglen |
Senior Member ![]() ![]() ![]() Group: Members Posts: 922 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest ![]() ![]() |
Do you need a winch to lift the rear trunk? (IMG:style_emoticons/default/biggrin.gif)
kidding, really love the idea. |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,939 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Well, this rocks (pun intended}. The rack sure makes this a great build in my head, the border here has seen the beginning of some great adventures in similar vehicles. Very cool dude
East coaster |
Do you need a winch to lift the rear trunk? (IMG:style_emoticons/default/biggrin.gif) kidding, really love the idea. Was worried about that, that’s why I made it all from 1” aluminum tube. It’s actually pretty light. |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,797 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Very nice work! (IMG:style_emoticons/default/smile.gif)
Based on the quality of the craftmanship, clearly you have an idea as to how to hold it open, in order to easily set the roof in? (IMG:style_emoticons/default/popcorn[1].gif) |
East coaster |
East coaster |
Decided to go with something different for my headlights. I’m using heavily modified 928 headlights in a fixed position. I made a support frame that goes below the 914 headlight doors and incorporated the eyebrow into the door. Still need to do a little finishing work, and the repeat for the passenger side, but I thought I’d share the progress…..
brubou |
Bruce Bouchard ![]() ![]() Group: Members Posts: 92 Joined: 29-February 16 From: West Bradford, PA Member No.: 19,716 Region Association: MidAtlantic Region ![]() ![]() |
Forget Cibie's!!! Mount a couple 928 headlights on the hood!!
Retroracer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 636 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest ![]() ![]() |
Cool idea with the fixed 928 headlight buckets. Can't wait to see the design for the front safari "animal & small tree" deflection bars....
And, presumably, more spotlights! - Tony |
East coaster |
A few detail pics of headlight framing…..
Attached thumbnail(s) ![]() ![]() ![]() |
East coaster |
More….
East coaster |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,054 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Your fab skills are really next level. You're making exactly what you want which is awesome. Love the 928 lights and I literally copied your frunk floor venting idea. Just another day of grinding, welding pin holes, grinding, welding, grinding and then some paint and mine should be done (IMG:style_emoticons/default/biggrin.gif) .
East coaster |
Thanks for the kind words Chris. You’re one of the folks to blame when it came to choice of drivetrain (IMG:style_emoticons/default/wink.gif)
This is a pretty far departure from most builds, but I’m actually trying to do the safari mods so that it could be fairly easily put back to stock. Most of my mods either use stock mounting points, or at least leave stock mounting points intact. I’m pretty sure I’m going to enjoy the safari mods, along with Subaru drivetrain, but if someday post my ownership someone wanted to revert to stock it shouldn’t be too difficult. |
Chris H. |
Thanks for the kind words Chris. You’re one of the folks to blame when it came to choice of drivetrain (IMG:style_emoticons/default/wink.gif) This is a pretty far departure from most builds, but I’m actually trying to do the safari mods so that it could be fairly easily put back to stock. Most of my mods either use stock mounting points, or at least leave stock mounting points intact. I’m pretty sure I’m going to enjoy the safari mods, along with Subaru drivetrain, but if someday post my ownership someone wanted to revert to stock it shouldn’t be too difficult. Guilty as charged sir (IMG:style_emoticons/default/biggrin.gif). You'll like the Subaru drive train. The engine mounts for most of them are the same configuration so in the future you can update/swap as needed with very little effort. Seems like you saved that car, which had the usual fixable rusty areas and mods for a V8 swap. Enjoy it! Hope to see it someday. |
East coaster |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:37 AM |
