WTB - jack, 73 2.0 bilstein? |
Quinn Moore |
Nov 29 2022, 08:35 AM
Qmoore Group: Members Posts: 106 Joined: 13-July 21 From: Fox River Grove, IL Member No.: 25,718 Region Association: Upper MidWest |
Whoops, received an error on this post.
Here's some text. Looking for a jack...bilstein preferably?. In case I get a flat on the back roads of Wisconsin/ Illinois. Thoughts/comments appreciated. Thx, QM |
bdstone914 |
Nov 29 2022, 12:28 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
It is safer to use a scissors jack from a more modern car on the pinch weld. I have seen many original jacks allow the car to pitch forward and bend the jack and or the jack hole. Have also seen them tear the jack hole.
StarBear |
Nov 29 2022, 02:17 PM
Senior Member Group: Members Posts: 1,850 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
It is safer to use a scissors jack from a more modern car on the pinch weld. I have seen many original jacks allow the car to pitch forward and bend the jack and or the jack hole. Have also seen them tear the jack hole. Yep. AMHIK! Great to have for a "preservation" and "originality" piece, but not much else. If this, I have one for you (just shipping). |
Quinn Moore |
Nov 30 2022, 07:16 AM
Thanks guys, yes I do recall (mid 80's) my '72 would/could get a little "tippy" with the original jack. I'll go with the scissor jack advice. I'd also like to have a bilstein strapped in there for trips down memory lane. I'll PM starbear.....thank you both.
QM |
StarBear |
Nov 30 2022, 08:11 AM
Thanks guys, yes I do recall (mid 80's) my '72 would/could get a little "tippy" with the original jack. I'll go with the scissor jack advice. I'd also like to have a bilstein strapped in there for trips down memory lane. I'll PM starbear.....thank you both. QM Here’s the pic. I believe (?) it’s not a 73, but a late one, 75-76, as it has a single piece tongue and a painted, not chrome, cap. Has the green dot! PM me if you still want it. |
Quinn Moore |
Nov 30 2022, 08:34 AM
Thanks guys, yes I do recall (mid 80's) my '72 would/could get a little "tippy" with the original jack. I'll go with the scissor jack advice. I'd also like to have a bilstein strapped in there for trips down memory lane. I'll PM starbear.....thank you both. QM Here’s the pic. I believe (?) it’s not a 73, but a late one, 75-76, as it has a single piece tongue and a painted, not chrome, cap. Has the green dot! PM me if you still want it. I'll take it! (IMG:style_emoticons/default/beerchug.gif) Thank you, QM |
Literati914 |
Nov 30 2022, 12:20 PM
Senior Member Group: Members Posts: 1,437 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
It is safer to use a scissors jack from a more modern car on the pinch weld. I have seen many original jacks allow the car to pitch forward and bend the jack and or the jack hole. Have also seen them tear the jack hole. This is a subject/issue I’ve had in mind to address at some point… I really like the original jacks (mainly for the original and streamlined look when mounted and not in use) - and was wondering if there may be a way to improve them. What could be done? I’m thinking of some kind of a plate that would slide onto the bottom to make a more stable base.. then would come off for storage. Of course it still wouldn’t be ideal on a rusty car with weak jack points, but ok otherwise. Thoughts on a good design or in general? . |
StarBear |
Nov 30 2022, 01:49 PM
It is safer to use a scissors jack from a more modern car on the pinch weld. I have seen many original jacks allow the car to pitch forward and bend the jack and or the jack hole. Have also seen them tear the jack hole. This is a subject/issue I’ve had in mind to address at some point… I really like the original jacks (mainly for the original and streamlined look when mounted and not in use) - and was wondering if there may be a way to improve them. What could be done? I’m thinking of some kind of a plate that would slide onto the bottom to make a more stable base.. then would come off for storage. Of course it still wouldn’t be ideal on a rusty car with weak jack points, but ok otherwise. Thoughts on a good design or in general? . Certainly a bigger base would help but only if secured to base to prevent shifting though with the height and attachment hole issue not sure if even attempting a design fix is safe. IMHO these jacks are solely for show and originality. AMHIK! |
rhodyguy |
Dec 2 2022, 11:17 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
You have to carry a set of chocks for the wheels still on the ground if you intend on using a OEM jack. Pray the flat occurs on a level surface.
TheCabinetmaker |
Dec 3 2022, 08:28 AM
I'm one of those who have damaged my car with one of those. Will never use one again. Never!
TheCabinetmaker |
Dec 3 2022, 08:32 AM
Dupe post
Lo-Fi Version | Time is now: 25th April 2024 - 11:41 PM |
