Dave-O |
Is winter done yet? ![]() ![]() ![]() Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 ![]() |
It's a stock VW part. My 1.7 has all stepped studs. Available here http://www.germansupply.com/xcart/customer...91a84f3b6a35bd6 |
mikelsr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 657 Joined: 2-January 05 From: Mahomet, IL Member No.: 3,390 Region Association: Southwest Region ![]() |
You should be able to buy individual screw-outs or screw-ups from sears. I did that not to long ago. REMEMBER to read and FOLLOW the directions or you will break the screw-out (that's why I had to buy another one). (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Mike |
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Yep
Don't break an EZ-out. I broke one in a tractor block one time. I used about $75 worth of dental diamond burs to drilll the sucker out. I never used that handpiece (drill) on another patient so it was about a 400 buck broken EZ-out. I saved the tractor though. I've learned enough times now that when things start going south just stop and take it to an expert. Fortunately, I've found a great machinist. My last "faux pas" was a broken headstud which I got out without damaging the case. The problem was it took 2 days. That's about 16 hours of work. The cost of the short block was $80 dollars and I had $80 in an align bore so I worked all weekend at 10 bucks an hour to save that case. I got the satisfaction of "I knew I could do it" (I never knew it until I it was done) but, the wife was mad as hell. Jack the machinist could have gotten it out for less than a hundred (estimate here) and I could have spent time with the family. My next career I want to be a machinist. Dave |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
thanks! *that* page is a bookmarked keeper ! |
Lo-Fi Version | Time is now: 30th June 2024 - 08:36 PM |
