Drex 914, Iowa 914 |
Drex |
May 1 2023, 05:46 PM
Member Group: Members Posts: 170 Joined: 1-December 22 From: Guthrie Center, Iowa Member No.: 27,003 Region Association: None |
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1682984760.1.jpg)
working on the restoration now fuel tank out (there were no rubber buffers to support tank!!) here is pic inside tank is this where the bottom fuel lines enter the tank and where is the strainer located? thanks Drex |
930cabman |
May 2 2023, 06:01 AM
Advanced Member Group: Members Posts: 3,834 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Not the best lookin innards, might have her "boiled out". The brass (very fragile) sock is whats protruding. About 3/8" x 3" tall.
Drex |
May 2 2023, 07:48 AM
Called Tangerine Racing today
They recommend the SS kit with late market 2 way fuel pump with mounting on the firewall To test an old fuel pump Does one simply apply 12v to the terminals? and see if it spins ok? Drex |
rjames |
May 2 2023, 09:23 AM
I'm made of metal Group: Members Posts: 4,172 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1682984760.1.jpg) working on the restoration now fuel tank out (there were no rubber buffers to support tank!!) here is pic inside tank is this where the bottom fuel lines enter the tank and where is the strainer located? thanks Drex The search function is your friend. The built-in search function on the site is effective but can be a bit challenging to use, but you can also just use google and preface your search string with '914world'. http://www.914world.com/bbs2/index.php?showtopic=95677 And yes, boiling the tank will strip the paint, too, as well as leave it unprotected from rust. You'll want to treat the surface (both inside and out) fairly quickly afterwards to keep it from flash rusting. I think you can use denatured alcohol for that. I used Por15's Metal Prep product. |
Jamie |
May 2 2023, 12:23 PM
Senior Member Group: Members Posts: 1,078 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1682984760.1.jpg) working on the restoration now fuel tank out (there were no rubber buffers to support tank!!) here is pic inside tank is this where the bottom fuel lines enter the tank and where is the strainer located? thanks Drex Skip attempting to boil out the tank and replace with new replacement. I discovered too late that a new tank cost less than what I paid for boiling out and painting several years ago. I also skipped replacing the internal sock filter by installing an external filter in line before new pump installation near the steering rack up front, eliminating the vapor lock problem from original pump location in engine bay. (IMG:style_emoticons/default/aktion035.gif) |
Drex |
May 2 2023, 01:06 PM
JamieD
did you use a stock 3 port pump up front? thanks dave |
Jamie |
May 2 2023, 02:04 PM
rjames |
May 2 2023, 07:52 PM
If your tank is solid, why throw it out? I think I paid ~$40 to have my tank boiled. Even if prices have doubled since then, it's still a lot less than a new tank at ~$200 + shipping.
ThinAir |
May 2 2023, 10:48 PM
Best friends Group: Members Posts: 2,555 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Just discovered this thread. So glad you took on this project.
I'll be wandering through Iowa this summer. Expect a PM to come by and visit! |
Drex |
May 3 2023, 05:39 AM
Think I will go with boiling out original tank
and have them prep it as well (yet to find a place to do this around my area) Also, am planning to go with The a fuel line package with the 2 port pump and locate it up front. Which one is the best? Thanks Drex |
Drex |
May 3 2023, 09:50 AM
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1683129011.1.jpg)
having a heck of a time removing the hard lines out of the bottom of the fuel tank it almost looks like the inside of the flanges were sodered to the threaded part of the tank is this right or, is the fuel line tube just really frozen in there? thanks Drex |
Drex |
May 3 2023, 05:02 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1683154939.1.jpg)
there was no soder applied a little heat and it twisted right out tanks going to radiator shop in Story City, Iowa tomorrow yep, its gonna cost about what a new tank would cost (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) he does a lot of classic car fuel tank restorations out of Des Moines apparently he will get to it in two weeks it'll give me time to install the SS lines thru tunnel etc. and also the pump, filter, up front is there a diagram showing the exact location of where best to install these parts? BTW, will have an extra original fuel tank! thanks Drex |
Drex |
May 3 2023, 05:06 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1683155172.1.jpg)
what's left of the tank filter Drex |
930cabman |
May 3 2023, 05:17 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1683155172.1.jpg) what's left of the tank filter Drex Typical, after a 1/2 century and being soo fragile the socks get weak |
SKL1 |
May 3 2023, 07:09 PM
Senior Member Group: Members Posts: 1,652 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Dave, I used a place in Knoxville a few years ago to do the tank on my '73- not sure they're still around, but it was called Gas Tank Renu and number was 641 8422822. Good luck.
Jamie |
May 3 2023, 07:30 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1683155172.1.jpg) what's left of the tank filter Drex Don't bother replacing the in tank sock filter, I damaged 2 trying to install and decided on external in line filters that can be serviced much more easily and are better filters. (IMG:style_emoticons/default/poke.gif) . |
Drex |
May 4 2023, 03:50 PM
just got back from Story City
they'll call when it is done my tank strainer was intact but was destroyed by the time I extracted it out i'll probably try to put a new one in but like the idea of an extra filter inline took this picture to see angle of bottom fuel lines (IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1683237042.1.jpg) |
Drex |
May 10 2023, 04:08 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1683756530.1.jpg)
picked up my cleaned and treated fuel tank today! still waiting on my SS fuel lines Drex |
930cabman |
May 10 2023, 04:27 PM
After 1/2 century the sock gets tired, it's very fine brass wire. I would assume new one's are available, but have been able to salvage a couple recently. Will you be running FI or carbs?
Drex |
May 10 2023, 04:29 PM
from reading past threads on the EGR system
i gather that it is kept in place but the actual charcoal cannister in not restored is this right, or is there a way to do this? thanks Drex |
Lo-Fi Version | Time is now: 15th January 2025 - 11:10 AM |
