Drex 914, Iowa 914 |
Drex |
Dec 22 2022, 04:30 PM
Member Group: Members Posts: 170 Joined: 1-December 22 From: Guthrie Center, Iowa Member No.: 27,003 Region Association: None |
Hello Everyone
My name is Dave and middle name Rex...thus D Rex A nickname my office girls gave to me as a play on 'T Rex' It was quite a process to get signed up on this forum But it appears I finally on I'm in the process of buying a 1971 914 It was hit in the R front fender and now Sat for > 40 years in a barn but was covered up (see pic) I own a '62 VW Beatle and had a '71 911 at one time So am familiar with air cooled engines Before the accident, it was apparently a running car I know its hard to tell without a thorough inspection But assuming it does not have much rust How much should I be offering for it? Thanks for all your expect advise Drex (IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1671748247.1.jpg) |
Drex |
Aug 3 2023, 08:28 AM
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1691072883.1.jpg)
hell hole is rusty with a few holes but very bottom is solid of course the battery tray will have to be replaced D Rex |
krazykonrad |
Aug 4 2023, 01:00 PM
Senior Member Group: Members Posts: 1,141 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Actually, that's not bad at all. Check the suspension ear underneath to be sure.
930cabman |
Aug 4 2023, 01:23 PM
Advanced Member Group: Members Posts: 3,834 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
She's been parked since 1974
rjames |
Aug 4 2023, 01:41 PM
I'm made of metal Group: Members Posts: 4,171 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Wirewheel the brown away and see what's left. Doesn't look too bad from here.
930cabman |
Aug 4 2023, 04:27 PM
rjames |
Aug 4 2023, 11:16 PM
Wirewheel the brown away and see what's left. Doesn't look too bad from here. Or Ospho Just putting Ospho on the rust isn’t going to tell you if there’s solid metal underneath. Given how easy it is to access the area, there’s no reason to not do it right. |
wonkipop |
Aug 5 2023, 12:38 AM
Advanced Member Group: Members Posts: 4,670 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1691072883.1.jpg) hell hole is rusty with a few holes but very bottom is solid of course the battery tray will have to be replaced D Rex gee they rusted fast didnt they. i mean thats 4 years worth. but it still looks ok. pretty straightforward to pull her back from the brink. go for it. great little car. fab color. (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer3.gif) |
Drex |
Aug 5 2023, 09:27 AM
where is the suspension ear?
i'll wire brush the hell hole down and re-post picture thanks D Rex |
MikeK |
Aug 5 2023, 09:41 AM
Member Group: Members Posts: 132 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
Do you know what brand of exhaust you have? I have the same setup on mine. Neat project. Cool color. |
Drex |
Aug 5 2023, 11:28 AM
i don't know muffler brand
or if it is even original still need to match the paint color to re-paint the hell hole when repaired D Rex |
930cabman |
Aug 5 2023, 03:07 PM
i don't know muffler brand or if it is even original still need to match the paint color to re-paint the hell hole when repaired D Rex I am restoring a '75 Palma Green example, original Cali car with minimal rusting. There was some hell hole work I completed and when done I used a brush on oil based enamel available from True Value. The color is reasonably close to Palma and actually still looking for Palma in single stage acrylic enamel. Any progress with the engine? or too busy cruising in the vette |
Drex |
Aug 6 2023, 02:22 PM
between my daughter getting married (7/22)
and my partner gone all last week, i've been too busy and tired to do much the last couple of weeks. i have most of this coming week off and plan to work on 914 then. hell hole work 1st (hopefully no surprises) then new jack support plates welded in then will turn to the engine on FI engines besides new hoses what are the essential new parts i will need to purchase? plan new coil, distributor cap n rotor, oil cooler seals, air intake collars fuel pump, etc do i need a new MPS, fuel pressure regulator and what else? thanks D Rex |
JeffBowlsby |
Aug 6 2023, 02:50 PM
914 Wiring Harnesses Group: Members Posts: 8,806 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
between my daughter getting married (7/22) and my partner gone all last week, i've been too busy and tired to do much the last couple of weeks. i have most of this coming week off and plan to work on 914 then. hell hole work 1st (hopefully no surprises) then new jack support plates welded in then will turn to the engine on FI engines besides new hoses what are the essential new parts i will need to purchase? plan new coil, distributor cap n rotor, oil cooler seals, air intake collars fuel pump, etc do i need a new MPS, fuel pressure regulator and what else? thanks D Rex Dave, you may need some of the FI parts, or none of them, other than gaskets, hoses and filters. It fully depends on the condition and completeness of what you have to start with. The great thing about D-jet is that each component can be tested individually, and the tests are not hard if you understand how each item functions. Here is an excellent resource for the correct parts needed: https://members.rennlist.com/pbanders/ Your main concerns should probably focus on confirming a functional ECU, MPS, TPS, TS2, the trigger points, fuel pump, relay board, and the engine bay harnesses - FI, Ignition, and Alternator, as well as fuel injectors including the fifth injector (CSV). Lay out what parts you have, post photos, and lets see where to go from here. Your FI system is one of the simplest on a 914 ,it should look like this: Attached image(s) |
Drex |
Aug 6 2023, 04:01 PM
thanks Jeff
lots of material to digest will dive in Dave |
krazykonrad |
Aug 6 2023, 05:52 PM
Drex |
Aug 7 2023, 12:08 PM
thanks Krazy!
i'll check it out. D Rex |
SKL1 |
Aug 8 2023, 09:59 AM
Senior Member Group: Members Posts: 1,652 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
You mean Steve gets time off??????
Drex |
Aug 8 2023, 10:46 AM
Steve is my partner
he's been gone for the last 8 days to California Will be working on 914 tomorrow D Rex |
Drex |
Aug 10 2023, 10:00 AM
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1691683222.1.jpg)
here is the area below the hell hole also, today i took a piece of metal into our local body shop to see if they can match the willow green paint D Rex |
SKL1 |
Aug 10 2023, 07:39 PM
Doesn't look that bad from that angle but what does it look like at the jack receiver and longitudinal opposite to that?
Lo-Fi Version | Time is now: 15th January 2025 - 05:01 AM |
