Drex 914, Iowa 914 |
Drex |
Sep 27 2023, 04:19 PM
Member Group: Members Posts: 170 Joined: 1-December 22 From: Guthrie Center, Iowa Member No.: 27,003 Region Association: None |
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1695853156.1.jpg)
here are the cylinders and pistons probably will have cylinders honed and buy new rings should I buy new pistons? thanks Dave |
Drex |
Oct 4 2023, 08:26 AM
couple of questions for the 1.7 engine:
are the right and left heads identical? are all the cylinders identical? is there a good thread on this? i know that it is important to disassemble and reassemble all parts in the same place and orientation and i plan to mark this on all the parts. is it possible to mistakenly put the heads on the wrong sides or will they only fit one way? Dave |
Drex |
Oct 5 2023, 10:24 AM
More questions
I see when ordering pistons and cylinders etc. that they are listed as 90mm/93mm Does this mean that the piston is 90mm and the cylinder is bored out to 93mm? I have restored six vehicles but never performed engine work Thanks Dave |
Drex |
Oct 18 2023, 05:22 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1697671323.1.jpg)
took heads down to mechanic valves ok but will need new guides so will be sent away for 2-3 weeks of interest, mechanic's dad used to use this old honer! they don't use it now dave |
MikeK |
Oct 19 2023, 08:44 AM
Member Group: Members Posts: 132 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
All of the cylinders/pistons are the same. The heads are symmetrical from side to side. Keeping the cylinders with their piston isn't really necessary as things will change once honed. What is critical is piston fit to the bore. You may consider buying a new, big bore set of pistons which will get you closer to 2.0 l, if yours are scuffed or worn.
If I were in your shoes: Heads rebuilt with new guides, three angle valve job and a light flycut of the sealing surface. I'd consider new exhaust valves. CC the heads so they match. I'd do a little hand work to port match the manifolds, clean up the intake runners, etc.. Have the rods rebuilt and balanced, polish the crank, surface the flywheel, have the crank dynamically balanced with the fan, flywheel and clutch. Pin the clutch so it only goes on one way. Clean and measure the pistons. Hone the cylinders. Check ring gaps. Balance pistons to within a gram or less. Check the case to see if it needs a line bore and/or thrust cut. Have oversized bearings in hand before any cutting is done on the case. Deck the case bores so the cylinders have a nice surface to seat against. That will get you on your way. Plenty more detail to go into once you start on the motor, like blue printing the oil pump, ensuring bearing oiling hole alignment and correcting it and some measuring, deburring the cam, checking cam gear engagement, etc... Plenty of details, but getting a well balanced bottom end with the correct bearing clearances and a good set of heads is fundamental. |
Drex |
Oct 21 2023, 11:12 AM
lots of good things to do to an engine
i probably won't do some of them the heads and cylinders are at shop for rebuild think i will buy an ultrasonic parts cleaner thanks for advise dave |
krazykonrad |
Oct 22 2023, 12:48 PM
Senior Member Group: Members Posts: 1,141 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
lots of good things to do to an engine i probably won't do some of them the heads and cylinders are at shop for rebuild think i will buy an ultrasonic parts cleaner thanks for advise dave Ultrasonic parts cleaner is the way to go. I have been pleased with the one I got from Amazon, but the advertised volumes are significantly smaller in real life. |
Drex |
Oct 24 2023, 05:36 PM
i'm thinking about getting the 6L model
also https://www.youtube.com/watch?v=0mS1WNll3hs is it possible to have a 72,000 mile car this perfect and completely original? Dave |
vintagethunder |
Oct 25 2023, 02:21 PM
Newbie Group: Members Posts: 39 Joined: 7-January 22 From: Monmouth, IL Member No.: 26,225 Region Association: Upper MidWest |
Did you get an engine yoke yet? I noticed about half say the 2 arm ones are crap, and the other half say they use them with no issues. I just got the one from LJ Air-Cooled Engines and am satisfied.
I did have a problem with the stand, as some (including the Samba guy who is no longer building his yokes) said the newer HF 1 ton stands had the 2 3/8" ID top tube that is required for many of them, but the stands at my local HF are more like 1 15/16". |
Drex |
Oct 27 2023, 05:07 AM
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1698404821.1.jpg)
i went with the more expensive QSC from amazon currently am waiting for all the parts to OH the heads also, ordered new rings and piston snap rings should come in the next few days from Auto Atlanta more later Dave |
Drex |
Nov 12 2023, 02:04 PM
My heads are at the machine shop
I ordered new valve guides from Auto Atlanta and was sent the oversize intake guides for 1.7 1.8 It turns out that their O.D.'s measure 13.06 mm and are too large The ones removed from my heads have an O.D. of 12.06 mm Also, the new guides have a lip at one end which is absent on my original guides I called AA and they told me that the 13's are the right ones! that the head would have to be heated up and the guides cooled down in order for them to be pressed into the heads!! Is this true, or do they make a 12.06 mm intake valve guide? What do you all think of this? Thanks Dave |
Shivers |
Nov 12 2023, 02:55 PM
Senior Member Group: Members Posts: 2,874 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I do not know for sure. But I asked google after looking at your heads. So I asked for valve guides for 1.7-1.8 heads and this was what I found.
https://sierramadrecollection.com/products/...AiABEgJJH_D_BwE |
Drex |
Nov 12 2023, 03:13 PM
yes, those are like the ones I received
But they are also 13.06 mm The ones that came out of my heads are definitely 12.06 mm |
Drex |
Nov 13 2023, 04:31 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1699914679.1.jpg)
this is the new intake valve guide AA sent me actually, they sent 6 exhaust VGs and 2 of these intake VGs surely my old ones are original am trying to talk to the shop mechanic at AA thanks dave |
Drex |
Nov 16 2023, 02:21 PM
Apparently no one makes the original 12.06 mm intake valve guides
this is because there was a problem with them slipping when engine warmed up So they went to the 13.06 mm guides with a collar on them one has to have the heads reamed out to 13.058 (VG O.D. - 0.002) heat the heads, cool the guides, and press them in The collar end goes on the spring side Thanks Dave |
porschetub |
Nov 17 2023, 09:21 PM
Advanced Member Group: Members Posts: 4,764 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Apparently no one makes the original 12.06 mm intake valve guides this is because there was a problem with them slipping when engine warmed up So they went to the 13.06 mm guides with a collar on them one has to have the heads reamed out to 13.058 (VG O.D. - 0.002) heat the heads, cool the guides, and press them in The collar end goes on the spring side Thanks Dave Strange way do it end result will be the same ,seem to remember running an internal bore mic down the heads and machining the guides in a lathe to correct interference fit then the only reaming required is to suit new valves you are fitting which I hope you are or @ least the exhaust valves . IMO re-ringing pistons is false economy unless they have ring grooves in spec and pistons that measure up for bore clearance after a hone which even with your lowish mileage will most likely not be great. Just don't want to see you disappointed with oil burning which is the main issue with worn pistons /bores ok. For the cost of all this checking and measuring go to 1.8 barrel and piston set with higher CR pistons ,a small increase in power and solves a lot BS later on . Good luck Dave. |
Drex |
Nov 19 2023, 07:04 PM
would a 1.7 case, heads and valves
except 1.8 pistons and cylinders? Dave |
Shivers |
Nov 19 2023, 08:56 PM
would a 1.7 case, heads and valves except 1.8 pistons and cylinders? Dave This is a Jake Raby quote: “The 2.0 (94 or 96mm) cylinders will fit into the 1.7 or 1.8 crankcase exactly as they do the 2.0!!!! NO MACHINE WORK IS NEEDED AS ALL REGISTERS ARE THE SAME SIZE!” So as long as the pin location is the same I see no reason it wouldn’t. |
Drex |
Apr 18 2024, 04:56 PM
Iowa is back...
had several non 914 issues to resolve this winter (a very mellow Iowa winter BTW) but now am ready to continue my restoration is the ultrasonic cleaner best for cleaning engine parts? what solution is best with this? also, what sealer is best for the ring that goes between the cylinder and the case? glad to be back Dave |
Lo-Fi Version | Time is now: 15th January 2025 - 12:52 AM |
