Door jamb vin sticker replace? |
TonyA |
Jan 14 2023, 07:06 AM
Nachmal Group: Members Posts: 580 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Doing a complete paint job. Should I preserve the original sticker or replace? Where should I get the replacement?
StarBear |
Jan 14 2023, 07:37 AM
Advanced Member Group: Members Posts: 2,093 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Doing a complete paint job. Should I preserve the original sticker or replace? Where should I get the replacement? Tony; try to preserve if possible. Difficult due to cutouts, but can be done. Replacements are available but Len and I were really pleased with the ones from the outfit in Poland that include the perforations and semi circle cutouts. Don’t have the info at my fingertips but will post later today with pics. |
Dion |
Jan 14 2023, 08:01 AM
RN Group: Members Posts: 2,807 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Sent you a text Tony. Agree with Steve.
Cairo94507 |
Jan 14 2023, 09:28 AM
Michael Group: Members Posts: 10,173 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
If that sticker is perfect I would try to preserve it. If it is already damaged, I would remove and replace it. There are nice replacements available. I have only seen a very few where the car was repainted and the sticker preserved and it was not obviously a repaint. (IMG:style_emoticons/default/beerchug.gif)
Jett |
Jan 14 2023, 09:40 AM
Senior Member Group: Members Posts: 1,675 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
sixaddict |
Jan 14 2023, 09:46 AM
Senior Member Group: Members Posts: 870 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Was facing same issue……Car-bone (Poland) produces great product ( no experience with Aase)…….Easy to do business with…..
Possible that Sierra Madre does as well. Make sure to tell them background color (silver or black) |
StarBear |
Jan 14 2023, 09:48 AM
Yep; Carbone. Very happy with result. Went in with Len as he didn’t have one; saved on mailing cost by ordering both at same time. (IMG:style_emoticons/default/biggrin.gif) |
ClayPerrine |
Jan 14 2023, 11:58 AM
Life's been good to me so far..... Group: Admin Posts: 15,981 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Yep; Carbone. Very happy with result. Went in with Len as he didn’t have one; saved on mailing cost by ordering both at same time. (IMG:style_emoticons/default/biggrin.gif) On my 73, the door jamb sticker was removed in 2000 during the repaint. I got one from Carbone last summer. It is excellent. First time in 22 years its had a door jamb sticker. |
scallyk9 |
Jan 14 2023, 05:11 PM
Member Group: Members Posts: 343 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
I replaced the orginal because of replacing the jamb placement with a Carbone replacement, then kept the cut-out rectangle of the sticker for posterity. I keep it in the glovebox. Carbone did a great job. Not sure but my guess is that they make them to order for Aase as I've seen both.
TonyA |
Jan 14 2023, 09:57 PM
Thanks. I think I’ll keep the original. I could always replace it later.
bbrock |
Jan 15 2023, 09:50 AM
+1 for carbone. The stickers are purposely impossible to remove without damaging them and I don't see how you can mask the sticker and repaint without it being obvious you did so. The carbone stickers are an exact match.
rudedude |
Jan 15 2023, 09:53 AM
Senior Member Group: Members Posts: 518 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
I have tried in the past to remove them without much luck. Does anyone have a good method for removing it intact? I have carbone replacements that are very good but would like to save the original if possible.
bbrock |
Jan 15 2023, 10:25 AM
I have tried in the past to remove them without much luck. Does anyone have a good method for removing it intact? I have carbone replacements that are very good but would like to save the original if possible. I can only say what NOT to do. I thought maybe a little heat could soften the adhesive enough to slip a razor blade underneath to lift it. I turned my heat gun to the lowest setting to start and as soon as I warmed the sticker, the sticker plastic melted and curled. Between the low melting point and perforations preventing the sticker to be peeled off, it is not an easy task. BTW, I was able to successfully remove and salvage all other decals on my car but this one defeated me. |
76-914 |
Jan 15 2023, 01:24 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,654 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OK, call me stupid but I tried to locate the sticker on carbone searching 914/decals& stickers. Found every damned decal & sticker except this one. I found it quickly on the AASE sight. (IMG:style_emoticons/default/headbang.gif)
wonkipop |
Jan 15 2023, 04:06 PM
Advanced Member Group: Members Posts: 4,670 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
OK, call me stupid but I tried to locate the sticker on carbone searching 914/decals& stickers. Found every damned decal & sticker except this one. I found it quickly on the AASE sight. (IMG:style_emoticons/default/headbang.gif) if you want to be pedantic replace the VIN with one the same colour. they were either black or silver. and they did vary slightly in layout over the years. as a side discovery from 74 1.8 L jet research we found the combos of specific paint colours to Vin stickers. they were not just randomly different colours. about halfway down this page. http://www.914world.com/bbs2/index.php?sho...7407&st=100 but its only info for 74 cars. were not looking further afield. |
76-914 |
Jan 15 2023, 04:23 PM
OK, call me stupid but I tried to locate the sticker on carbone searching 914/decals& stickers. Found every damned decal & sticker except this one. I found it quickly on the AASE sight. (IMG:style_emoticons/default/headbang.gif) if you want to be pedantic replace the VIN with one the same colour. they were either black or silver. and they did vary slightly in layout over the years. as a side discovery from 74 1.8 L jet research we found the combos of specific paint colours to Vin stickers. they were not just randomly different colours. about halfway down this page. http://www.914world.com/bbs2/index.php?sho...7407&st=100 but its only info for 74 cars. were not looking further afield. Mine was silver before I toasted it in 2009. My question was where on the carbone site is this sticker located. I know where to place it in the jamb. Tia, Kent |
Cairo94507 |
Jan 15 2023, 04:31 PM
I just emailed them and attached a picture of my old sticker and they made the replacement. Great people to work with. (IMG:style_emoticons/default/beerchug.gif)
wonkipop |
Jan 15 2023, 04:46 PM
OK, call me stupid but I tried to locate the sticker on carbone searching 914/decals& stickers. Found every damned decal & sticker except this one. I found it quickly on the AASE sight. (IMG:style_emoticons/default/headbang.gif) if you want to be pedantic replace the VIN with one the same colour. they were either black or silver. and they did vary slightly in layout over the years. as a side discovery from 74 1.8 L jet research we found the combos of specific paint colours to Vin stickers. they were not just randomly different colours. about halfway down this page. http://www.914world.com/bbs2/index.php?sho...7407&st=100 but its only info for 74 cars. were not looking further afield. Mine was silver before I toasted it in 2009. My question was where on the carbone site is this sticker located. I know where to place it in the jamb. Tia, Kent i just had a look on carbone. i think you are correct. they would appear not to make them anymore. old links to vin page of carbone on pelican parts forums are dead links now as well. AASE appears to have the VIN labels for 911s. they have dr porsche ing. etc written on them. 914/6s might have had those types of Vins. the 4s have VW written on them. AA appears to have the correct ones for the 4s. not sure if they have the little circles etc or how close a copy they are. http://www.autoatlanta.com/porsche-parts/a...LS-AND-STICKERS what year is yours? the typography does vary very slightly if you are super fussy. somewhere here there was a thread about them a little while back. with some of the variations. |
StarBear |
Jan 15 2023, 04:56 PM
OK, call me stupid but I tried to locate the sticker on carbone searching 914/decals& stickers. Found every damned decal & sticker except this one. I found it quickly on the AASE sight. (IMG:style_emoticons/default/headbang.gif) Yes, IIRC not on site but they do them on request via email. |
bbrock |
Jan 15 2023, 06:56 PM
OK, call me stupid but I tried to locate the sticker on carbone searching 914/decals& stickers. Found every damned decal & sticker except this one. I found it quickly on the AASE sight. (IMG:style_emoticons/default/headbang.gif) Yes, IIRC not on site but they do them on request via email. Yes, just email them. Like @Cairo94507 said, they'll have you send a pic of your old oe so they can do an exact match. Then they will send an electronic proof to approve. Check to make sure the tamper proof stamping is visible in the proof if you want the perfect match. It wasn't showing on my first proof but they quickly fixed it. Whenever I get a replica decal, I hold it side by side with the original if possible and search until I find a flaw. I couldn't find a flaw on the carbone VIN sticker. That was the only time I couldn't. |
Lo-Fi Version | Time is now: 15th January 2025 - 04:26 AM |
