> Wheel Fitment Question, '73 narrow body
76-914
post Feb 1 2023, 08:58 PM
I'm in the process of collecting parts for my 5 lug conversion and wanted to ask if a 71.6mm Bore. 52mm Offset 5 x 130mm Bolt Pattern 17" x 7" wheel would fit. I believe they were on the 968's, maybe Boxters. TIA, Kent
rick 918-S
post Feb 1 2023, 09:16 PM
Hey nice rack! -Celette
QUOTE(76-914 @ Feb 1 2023, 08:58 PM) *
(IMG:style_emoticons/default/icon_bump.gif) not sure about that but I thought I remember someone with Boxster wheels on their14.
NARP74
post Feb 2 2023, 09:32 AM
I have some printed pics of mine with what I think are Boxster wheels installed before I bought it. By the time I got it, Fuchs were installed. The pics were from a for sale ad that is gone now. It is a narrow body.
Chris H.
post Feb 2 2023, 09:39 AM
Should fit Kent. Mine are 17x7, 55 offset (I think they're same wheels you have on your orange car). You will need some spacers and longer studs. I have 15mm on mine. You can use the orange car wheels as test mules.
post Feb 2 2023, 10:52 AM
QUOTE(Chris H. @ Feb 2 2023, 07:39 AM) *
The orange/red car has flares so I was doubtful but I'll check. (IMG:style_emoticons/default/beerchug.gif)
Chris H.
post Feb 2 2023, 12:24 PM
I should mention that the original set that came on a Boxster would be 7x17 front, 8.5x17 rear. Mine are all "fronts" so make sure you verify that (IMG:style_emoticons/default/beerchug.gif) . They're snug but they fit.
Chris914n6
post Feb 2 2023, 12:46 PM
Jackstands are my life.
What kind of fool would want to do that?? (IMG:style_emoticons/default/av-943.gif)
All studs are 944 rear. I'll have to look at what spacers I ended up with. 15mm and 21mm I think. 225/45-17
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1659214723.1.jpg)
Chris H.
post Feb 2 2023, 05:26 PM
Yeah those are exactly the wheels I have Chris. They look cool in red! 225s must BARELY fit in the rear. I'm @ 215/45/17 and there's very little space.
Cairo94507
post Feb 2 2023, 06:08 PM
Michael
Just be careful with the rear fender clearance; static they might be fine, but once you are driving and in a sweeper at speed, you might experience some rub. Of course check the fronts for full turning clearance and make sure if the front suspension is compressed in a turn at speed you don''t catch a lip. (IMG:style_emoticons/default/beerchug.gif)
post Feb 2 2023, 06:33 PM
Great info from the 2 Chris' and Cairo.Thx for the tire sizes as that would have come up eventually (IMG:style_emoticons/default/beerchug.gif) . Thx
Chris914n6
post Feb 2 2023, 09:16 PM
The Indy500 are a tad narrow at the tread which is good as the fronts are tight.
The rears are fine as I got a bit carried away with the roller.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675394178.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675394179.2.jpg)
235/70-15 anyone? (IMG:style_emoticons/default/w00t.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675394179.3.jpg)
post Feb 2 2023, 11:18 PM
QUOTE(Chris914n6 @ Feb 2 2023, 07:16 PM) *
Chris, do you have a pic showing the clearance between the front tire at the rear of the front wheel? And yes, you did get carried away with those rear wheels. (IMG:style_emoticons/default/biggrin.gif)
Chris914n6
post Feb 6 2023, 06:12 PM
Spacers:
21mm front (944 early rear)
21+5mm rear
Factory alignment. I figured the short sidewall preferred minimal camber.
- Lo-Fi Version Time is now: 14th January 2025 - 10:25 PM
