2023 engine oil type, What is best today? |
ClayPerrine |
Feb 15 2023, 09:50 AM
Life's been good to me so far..... Group: Admin Posts: 15,594 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I use Valvoline VR1 in all the 914s. 20/50 in the 4.0L and straight 50 in the other two.
I get it at Oreilly auto parts. They have it on the shelf when I need a few quarts. When I do an oil change, I order a case or 4 (the 4.0 takes 22 quarts). |
vitamin914 |
Feb 15 2023, 02:32 PM
Member Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada |
I use Valvoline VR1 in all the 914s. 20/50 in the 4.0L and straight 50 in the other two. I get it at Oreilly auto parts. They have it on the shelf when I need a few quarts. When I do an oil change, I order a case or 4 (the 4.0 takes 22 quarts). Ouch!!! 22 quarts makes for a expensive oil change... Maybe buy 55 gallon drums? that would cover you for 10 oil changes... |
Badinfluence1 |
Feb 15 2023, 03:16 PM
Newbie Group: Members Posts: 32 Joined: 27-December 20 From: astoria oregon Member No.: 25,022 Region Association: Pacific Northwest |
20-50w with zinc- dont care the brand or the gas milage... I like to drive it hard
930cabman |
Feb 15 2023, 03:18 PM
Advanced Member Group: Members Posts: 3,220 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
22 quarts, WOW that's an oil change. Where does it all live?
ClayPerrine |
Feb 15 2023, 03:29 PM
mgphoto |
Feb 15 2023, 04:30 PM
"If there is a mistake it will find me" Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
ClayPerrine |
Feb 16 2023, 09:59 AM
22 quarts, WOW that's an oil change. Where does it all live? Oil tank, sump, two huge oil coolers, thermostat and all the lines connecting it together. At what interval and how much do you dump, all 22? With all the plumbing for the oil system, it doesn't completely empty out if you empty the tank and the sump. The left hand cooler has a plug in it that I use for a drain. It is for the temp sender on the 964, and I have that in the right cooler. The right cooler has to have the lines disconnected to drain it. After that, it takes about 20 quarts to refill. And I change the oil every 3K miles. Yea, it's expensive, but I spent a hell of a lot on that engine, and I want to take care of it. |
DennisV |
Dec 18 2023, 10:16 AM
Senior Member Group: Members Posts: 501 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
20-50w with zinc- dont care the brand or the gas milage... I like to drive it hard I'm surprised that no one seems to consider Swepco. I'm only aware of it because of Bruce Anderson's 911 Performance book. He was a fan of it, but that book is quite dated now. In general Swepco seems to have a good reputation and their 306 Supreme Formula says QUOTE Designed for Older Equipment Requiring Higher Zinc Levels Though I haven't found an indication of levels. Maybe their DIMONYL proprietary anti-wear additive is where the zinc comes in. Several of the Porsche parts vendors sell 20W-50 by the gallon. I don't have any experience with this. Just doing homework for my own build and was expecting to see Swepco in the debate. (IMG:style_emoticons/default/popcorn[1].gif) |
DennisV |
Dec 18 2023, 10:31 AM
There is a gentleman in one of the 356 forums that has oil industry experience. He suggests: QUOTE oil must contain at a minimum 1100 ppm ZDDP Only click that link if you have time to read. It is 275 posts long! |
technicalninja |
Dec 18 2023, 12:58 PM
Senior Member Group: Members Posts: 1,437 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Since my original post in February, I've "saved" three late model cars from MAJOR repairs (or maybe just put them off for a while) with the Lunati additive.
One guy had badly squeaking rocker arms on a 2012 Chrysler 5.7. 160k I said "Lets try this, it won't hurt anything but the cat and it might improve things." Put 4 oz of the ZDDP (while running) and my customer and I listened to each rocker go quiet over a period of about 90 seconds one at a time. He had 6 making noise and wanted an estimate for complete replacement. He tipped me $100! I've seen the car a couple of times since and it's still quiet. I'm currently trying to quiet hydraulic lash adjusters on a 300K Toyota V6. It will get MMO (1 qt Marvel Mystery oil) and 50 miles then oil change with additive. I'll post results. The customer advised "it's been making noise forever." I don't believe in "snake oil" additives. This stuff has worked surprisingly well in many applications for me. |
Geezer914 |
Dec 18 2023, 03:29 PM
Geezer914 Group: Members Posts: 1,482 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Driven 15w/50 from LN engineering.
hot_shoe914 |
Dec 18 2023, 04:40 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
You can always find Rotella. Has about 1267 ppm of zinc.
Dec 18 2023, 05:41 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Have you checked Rotella lately? I remember about 5-6 years ago (?) they reformulated, and dropped the ZDDP levels significantly...
--DD |
brant |
Dec 18 2023, 05:53 PM
914 Wizard Group: Members Posts: 11,645 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Royal purple in the race car
Valvolene vr1 in the street car Race car is 19 quarts but gets changed about every 3 hours of use Probably 150 miles between changes It also gets a valve adjustment at the same time/3 hours |
hot_shoe914 |
Dec 19 2023, 09:26 AM
Have you checked Rotella lately? I remember about 5-6 years ago (?) they reformulated, and dropped the ZDDP levels significantly... --DD Rotella is down some on Zinc, but there are several good options. From what I have read the last couple of days, Lucas Hot Rod or Classic Car oil has plenty of zinc, actually, almost too much at 2100 ppm. I have read that anything over 2000 ppm begins to have a reverse affect. Shoe (IMG:style_emoticons/default/beerchug.gif) |
infraredcalvin |
Dec 19 2023, 12:07 PM
Distracted Member Group: Members Posts: 1,533 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I’m surprised I haven’t seen anyone talk about it yet, but has anyone used fcp euro? Uses motul classic, 1800 ppm zddp, and once you make the initial purchase, you can return used oil and filter for replacement…for the cost of shipping the used stuff back…
VaccaRabite |
Dec 19 2023, 12:34 PM
En Garde! Group: Admin Posts: 13,479 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I still have a ton of Brad Penn Green/Racing oil that goes in all the aircooleds.
I used to be able to find it local but these days I buy it by the case from Amazon/wherever. And it does nt hurt that I have won a few cases at 914 events over the years. Zach |
VaccaRabite |
Dec 19 2023, 12:38 PM
I used to be able to find it local but these days I buy it by the case from Amazon/wherever. And it does not hurt that I have won a few cases at 914 events over the years. Zach |
Rufus |
Dec 20 2023, 08:13 PM
Member Group: Members Posts: 314 Joined: 8-April 06 From: Central NC Member No.: 5,840 Region Association: None |
Krieger |
Dec 20 2023, 08:54 PM
Advanced Member Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I use Swepco in my 4 and 6!
Lo-Fi Version | Time is now: 28th June 2024 - 01:49 PM |
